Best Gen 3 Ditch Light Bracket?
Discussion in 'Lighting' started by ProtoJ, May 28, 2019.
  1. Jun 10, 2019 at 6:03 PM
    #61
    ProtoJ
    ProtoJ [OP] New Member
    2018 Crewmax TRD Off-Road
    Wiring done. I used a caliraised LED harness (since the Baja Design’s harness is not long enough) and cut the ends off and spliced in the Baja connectors. I ran the wiring under the hood insulation. The only thing I didn’t get to is the illumination wire for the switch. The adjacent switch I was going to tap into had so much factory wire loom and tape covering every square inch I threw in the towel!
    F012E76A-0B98-4576-AFCD-7402ACB56E88.jpg 3B2B8087-3E8A-4A25-8023-6198E065A20F.jpg 4C80B1F3-9895-4556-9A99-03F691ACDD45.jpg
    vq35721 and sr5shark like this.
  2. Apr 3, 2021 at 4:34 PM
    #62
    NFARIDI
    NFARIDI New Member
    For those running a harness with relay, where did you all mount the relay?
    I have the Cali-raised harness, but not sure where to mount the relay. Does it need to be on a metal ground? Or can I mount it anywhere?
  3. May 30, 2021 at 4:13 PM
    #63
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    Yes old thread.
    So... What happens when you need to lift the hood? Do the lights clear the windshield/etc ? Do you need to remove the lights to lift the hood?
    I know - simple question. But I cannot find a simple picture or thread that answers this question. Yet.
  4. May 30, 2021 at 4:15 PM
    #64
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
  5. Jan 30, 2022 at 3:39 PM
    #65
    cclg041994
    cclg041994 New Member
    Zechariah
    Tundra TRD Off-Road Crewmax
    To the SDHQ users, I bought a pair back in Jun 2020 for my kc hilites. The coat started peeling on the left side and rust is developing (Dec 2021).. For the price, I was hoping the coat would last longer. I'm in WA state so rain is regular. Anybody have similar experiences?
  6. Jan 30, 2022 at 3:49 PM
    #66
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Contact sdhq see if they can warranty them. If not repaint them or go a different route. I’ve found most aftermarket things that are coated really don’t hold up long no matter which brand you go with. I’m in north Idaho so snow rain ice all that is common. Contact them see if they can help you out first.
  7. Jan 30, 2022 at 5:49 PM
    #67
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Yes, it will clear. Unless you put something like LP9s on there.
    Any "coating" is bound to chip, peel, etc. As stated above, contact SDHQ and see if you can get a warranty claim going. I never order anything "coated" as I've never had any luck with the coating. I always expect the coating on parts to peel or chip and rust to start forming.
