Best Gen 3 Ditch Light Bracket?
Discussion in 'Lighting' started by ProtoJ, May 28, 2019.
  1. Jun 5, 2019 at 7:02 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    PRETTY SWEET, JUST ORDERED SOME
    jlee[QUOTED] likes this.
  2. Jun 5, 2019 at 7:26 AM
    Cfincke
    San Antonio
    I have the first gen Rago brackets with some cheap lights (that suck). The new Rago brackets are powder coated stainless steel and come in standard height or low profile.
    All are bolt on with no trimming required.
  3. Jun 5, 2019 at 7:48 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    These are the Rago low profile brackets.
    joonbug and porkitt like this.
  4. Jun 5, 2019 at 8:05 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Anyone have the Cali raised low Pros?
  5. Jun 5, 2019 at 8:06 AM
    xtyfighterx
    Ty
    North Idaho
    Will they come black or silver?
  6. Jun 5, 2019 at 8:16 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    They are black and just about gone.
    xtyfighterx[QUOTED] likes this.
  7. Jun 5, 2019 at 8:41 AM
    ProtoJ
    ProtoJ [OP] New Member
    2018 Crewmax TRD Off-Road
    My rago brackets, Baja Squadrons and switch come today. Anyone have a good write up on wiring these to a stand alone switch? All the ones I’m reading talk about harnesses being too short, experimenting with what wire to splice the switch into, etc. anyone just have a solid write up with what parts i need and a diagram to actually wire this up right the first time?
  8. Jun 5, 2019 at 9:09 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    CF8A51CA-1B2A-4F46-834E-C6B94F2EE95B.jpg 485F31F9-DD0F-4B3C-A3B7-204F9EDE6681.jpg
  9. Jun 5, 2019 at 9:16 AM
    xtyfighterx
    Ty
    North Idaho
    I’ll get ahold of you Friday thanks!
  10. Jun 5, 2019 at 9:17 AM
    xtyfighterx
    Ty
    North Idaho
    How do you like those KC lights ?
  11. Jun 5, 2019 at 9:17 AM
    xtyfighterx
    Ty
    North Idaho
    What’s your switch Andy harness look like? I can help you out send me a message
  12. Jun 5, 2019 at 9:31 AM
    ProtoJ
    Will do when I unpack them here later today...thanks!
  13. Jun 5, 2019 at 9:34 AM
    jberry813
    Lake Tahoe
    Love them! Very low profile and bright.
  14. Jun 5, 2019 at 5:54 PM
    ProtoJ
    So here are my questions.
    1. Where do you run the wiring from the pod under the hood? Does not seem like much length to the end of the connector.
    2. Am I crazy or is the splitter not even close to long enough? Do I have to cut and extend?
    3. How close to the edge of the hood do I shift the bracket...where I have them now I would need to trim the rubber cover that it hits when is closed. I’m thinking I should move it closer to the edge of the hood.
    4. Pics of the wiring and Ditch light switch I have. Any good instructions? Any extra parts I need to wire this up?
    236A16F8-E6C0-43C8-AA6E-35824C22E651.jpg 236A16F8-E6C0-43C8-AA6E-35824C22E651.jpg AC7D1D5E-9FCD-4794-8588-481CBA78BED9.jpg
  15. Jun 5, 2019 at 5:59 PM
    TXTundra2722
    2015 Black Tundra
    I have a switch pro so length of the wiring was not an issue for me. That being said, you should have plenty of room for wiring. I ran my wiring right near the hood hinge (zip typing it out of the way) and then connected the wiring near the firewall.....I believe near the brake cylinder. It's completely up to you how far in or out you want the lights on the mounting bracket.
  16. Jun 5, 2019 at 7:23 PM
    ProtoJ
    A38ECBBA-9A87-41B1-9BF9-8E83F6ADF4E3.jpg The switch I got appears to be a little taller and skinnier than the spit I planned on using. I guess I need to figure out how to get from the hood into the engine bay . Wiring I’m guessing needs a relay added. The splitter wire needs to be cut and extended. Not sure where it is supposed to be routed.15B1D319-D08F-4283-AEBF-548BA6EE5A51.jpgAF9CA7BC-22F1-4CA8-95C0-9FC21062CCB5.jpg
  17. Jun 5, 2019 at 7:38 PM
    TXTundra2722
    2015 Black Tundra
    Everything you need comes with the lights. A portion of the wire will double back on itself in the engine bay, but there is enough to run all of the wiring. I just ran some Baja Designs lights from my bumper and that's a further run. I'll try and get pics later, unless someone else responds first
  18. Jun 5, 2019 at 7:44 PM
    TXTundra2722
    2015 Black Tundra
    Actually.....I just searched this in the threads(I have rigid lights for ditch lights) and I came across BD saying an extension is needed for their ditch lights which doesn't make sense, but there it is. Most of your questions have already been asked and answered if you search for them at the top of the screen and tap the magnifying glass. While your at it, I'd purchase some wire loom to protect your wiring when you do the install
  19. Jun 5, 2019 at 8:15 PM
    #49
    xtyfighterx
    Ty
    North Idaho
    #49
  20. Jun 5, 2019 at 8:23 PM
    #50
    ProtoJ
    #50
  21. Jun 5, 2019 at 8:25 PM
    #51
    xtyfighterx
    Ty
    North Idaho
    I have the same one for my light bar it fits perfect!
    #51
  22. Jun 5, 2019 at 10:36 PM
    #52
    Texas Bandit
    Texas Bandit New Member
    Amí
    Edinburg Texas
    2007 White 5.7 Tundra DC Limited 4x4
    295/70R18 Nitto Ridge Grappler Method Race Wheel NV Bronze Rigid Industries Radiance Pods Morimoto Xtorch 36” Light Bar SDHQ Pillar Light Mounts
    Using SDHQ and love them
  23. Jun 6, 2019 at 6:40 AM
    #53
    ProtoJ
    Bracket and lights mounted! I’ll save wiring for anther day....when I have time to watch some YouTube.
  24. Jun 6, 2019 at 7:32 AM
    #54
    xtyfighterx
    Ty
    North Idaho
    What brackets?
  25. Jun 6, 2019 at 11:43 AM
    #55
    ProtoJ
    Rago low pro
  26. Jun 9, 2019 at 6:28 PM
    #56
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    How you all wiring the BD to the factory style switch? 731EEAE2-3D35-4639-82EC-2C4A7A037BFB.jpg
  27. Jun 9, 2019 at 6:39 PM
    #57
    TXTundra2722
    2015 Black Tundra
    I have a switch pro that my lights are all ran to. Makes for a super easy install
    vq35721[QUOTED] likes this.
  28. Jun 9, 2019 at 7:46 PM
    #58
    ProtoJ
    Can I get someone to snap a pic of what the wire routing looks like under the hood to the pods? Im going to combine a caliraised harness with the connectors from the bajas. Did everyone run wiring up each hinge to the lights or just one side and run through the actual hood cavity?
  29. Jun 9, 2019 at 8:54 PM
    #59
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    The wire for the driver side light is attached to the bracket with zip ties and connects to one leg of the splitter. The other leg goes through the hood to the passenger side and then up to the other light.
  30. Jun 9, 2019 at 10:32 PM
    #60
    xtyfighterx
    Ty
    North Idaho
    Your BD switch Now has a main power, accessory, and a ground so. Use a meter find which two are positive. Then connect
    Your
    Main power to green, accessory to one of the red leads should be the one under the green lead, ground to black, and the last res lead connects to your illumination which I tapped the stock switch next to where mine was going it’s the blue wire on your stock switches.
