Best Battery Terminals for my Tundra?
Discussion in '2nd Gen Tundras (2007-2013)' started by mlong219, Apr 26, 2017.
  1. Apr 6, 2020 at 6:47 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    thats nice.. very clean.
    619Tundra[QUOTED] likes this.
  2. Apr 6, 2020 at 7:37 PM
    HaydenF
    HaydenF New Member
    Hayden
    2016 Limited Tundra Crewmax
    3.5 Zone Lift, 35x12.5x18 Nitto Ridge Grapplers, 18x9 Fuel hostage 3 Grey
    I just recently bought the NorthStar 27f and the GP audio terminals. Love the setup. Don’t forget to do the Alt-S fuse upgrade to allow for the correct charging profile for the AGM.
    Ely010606 likes this.
  3. Apr 6, 2020 at 8:38 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Looks good, if you don’t mind me asking what fuse did you use for the upgrade. Thanks.
    619Tundra likes this.
  4. Apr 6, 2020 at 8:55 PM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    What is the alt-s fuse upgrade and how is that done?
    Ely010606 and Flyinryank like this.
  5. Apr 6, 2020 at 8:57 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I’m curious too. First I’ve heard of this
    619Tundra, Platinum714 and Ely010606 like this.
  6. Apr 6, 2020 at 9:17 PM
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    2019 platinum 4x4 magnetic gray
    16 blue crewmax likes this.
  7. Apr 7, 2020 at 4:33 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    Definitely like the clean look.
    Looks like that style uses screws to clamp down on the cable ends.
    did you strip your factory connections?
  8. Apr 7, 2020 at 3:03 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I've had a set of GP terminals sitting on the workbench for a while now. I had the same concerns about something arcing onto the exposed terminal.
    I designed a quick something on fusion360 and printed it on some grey PLA i had in the printer.
    I'm fairly happy with how it turned out. It definately needs some revisions. It needs to be thicker on the outer walls (it split when putting it on). and the exposed holes on the bottom need better alignment.
    Once i get it dialed in, i'm going to try to use some red PTEG (never used it, but its supposed to be stronger)
    07 Tundie, Cfincke, Ltaco17 and 4 others like this.
  9. Apr 7, 2020 at 4:41 PM
    Danimal86
    Daniel
    Sacramento, CA
    V2.0
    I adjusted the wall thickness quite a bit and made it a little bit of a less tight fit. Only downside is that I'll need to figure out how to secure it.
  10. Apr 7, 2020 at 4:52 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    How about some large Heat Shrink tubing?
    BlueBottle[QUOTED] likes this.
  11. Apr 7, 2020 at 5:27 PM
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    Here are the Sdhq terminals and holder.
    Flyinryank and BlueBottle like this.
  12. Apr 7, 2020 at 5:42 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    very cool. what if you made it solid with no holes then used a rubber trim on inside and you just press the plastic over the terminal?
    NewImprovedRon likes this.
  13. Apr 7, 2020 at 6:12 PM
    HaydenF
    HaydenF New Member
    Hayden
    Here’s the one I bought... expensive for a fuse.. but it’s peace of mind. AGM batteries are required to be changed at 14.6v to achieve a “float” charge. Charging with 13.5-13.8v COULD damage the battery long term and never allow for 100% battery capacity.. If you check the NorthStar site you will see it’s recommended to be changed at 14.6v. Even the Odyssey website states the same. If you don’t want to do the fuse you can always pickup a new battery charger that can charge AGM batteries and go this route. You would need to plug it up at least once every 3 weeks. If you go the charger route I would recommend a ctek charger.
    Fuse: (recommended option)
    https://www.hkbelect.com/product/24...nic-fuse-version-micro-blade-compatible-2016/
    2nd option
    CTEK (56-353) MULTI US 7002 12-Volt Battery Charger https://www.amazon.com/dp/B000FRLO9Y/ref=cm_sw_r_cp_api_i_FssJEb7QY6TN4
  14. Apr 7, 2020 at 6:24 PM
    Danimal86
    Daniel
    Sacramento, CA
    I did think about coating the inside with some plastidip.
    Those holes need to be there (or a at least a divot) for the bolts to stick out the bottom
  15. Apr 7, 2020 at 7:14 PM
    Ely010606
    SPARKS, NV
    Thank you so much, you made it easier for me to order. I don’t need both , just one of them correct.
  16. Apr 7, 2020 at 7:21 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    ah, I didnt realize that was the bottom. couldnt you make a top plate as well and have it sit on top side under the bolts? anything you screw down will still make contact via the bolts. Just not sure if there would be any advantages to covering up the plate but not the bolts.
  17. Apr 7, 2020 at 7:29 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I cut my Gp audio terminals down to 4 posts, it made for a better overall fit and finish IMO. And the fuse replacement booster is the easiest remedy for the AGM .
  18. Apr 7, 2020 at 7:38 PM
    Danimal86
    Daniel
    Sacramento, CA
    That's an interesting thought....if it doesn't infringe with electronics, it could be a good option.
  19. Apr 7, 2020 at 8:08 PM
    #49
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Say what?
  20. Apr 7, 2020 at 8:10 PM
    #50
    619Tundra
    Yes I did. They come with allen wrench to tighten the screws. Very clean. I highly recommend these.
  21. Apr 8, 2020 at 6:58 AM
    #51
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Adding a Northstar, or the equivalent, has been on my to-do list for awhile. I hope my current battery makes it until the next group buy.
    I just read most of the posts, on this site and the Tacoma site, about removing the stock fuse and replacing it with a diode, opinions are very equivocal. Some people swear by it, and some people did the mod and removed it. Also, some of the same people who initially swore by it have removed it.
    There are also plenty of people who have the Northstar and have done nothing at all and who have gotten years of service from their battery.
    So, if you do nothing and run the Northstar at slightly less than the optimum level of charge are you defeating the purpose of having an AGM battery? Are you just as well off running a high quality lead-acid battery that is charged optimally?
    Or are there other advantages to a Northstar battery, even if it isn't optimally charged?
    Sorry for all the questions.
    Barrett50 likes this.
  22. Apr 8, 2020 at 7:02 AM
    #52
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Thanks. Just spent $50 on these
  23. Apr 8, 2020 at 9:15 AM
    #53
    Danimal86
    Daniel
    Sacramento, CA
    Anyone know if the tacoma HKB blade is the same as the tundra one? I used the link and accidentally bought the one for a 2010 tacoma :frusty:
    edit:
    I just looked, the tacoma one is a 7.5 amp, and the tundra is a 5 amp. I'll email them.
  24. Apr 8, 2020 at 10:52 AM
    #54
    HaydenF
    HaydenF New Member
    Hayden
    I think you have to look at it by the load you are putting on the battery. I have a 12k winch that requires at least 900 cold cranking amps. 50amp light bar, 25 amp fog lights, 15amp ditch lights. Now I most likely will never utilize the winch with all of the lights on. The 14.6v is what NorthStar recommends to charge the battery. By the time I invested $300+ for the battery and GP audio terminals. Might as well spend $50 and charge the battery correctly to get 10 years out of it. Also the 14.6v charges the battery a lot quicker which is nice when you have a demanding load. I’m sure the battery will be just fine with the stock alternator output voltage.
    myt1[QUOTED] likes this.
  25. Apr 8, 2020 at 5:44 PM
    #55
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I decided to swap to SDHQ terminals. They are on their way so if anyone wants to buy some slightly used gp pm me.
    shellshock likes this.
  26. Apr 9, 2020 at 8:25 PM
    #56
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @sdhq_offroad terminals are in. These are sweet. I like their size. And it still has enough extra connections for accessories I will ever need.
    DB575372-EFCF-4863-8A29-26FE2546D468.jpg 078812E0-FAE8-441F-A573-216EA606B4DB.jpg 8D9F4A70-8B72-40AF-8097-B026751B3A5D.jpg
  27. Apr 11, 2020 at 6:35 PM
    #57
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Finally got my sdhq ones on too :thumbsup:
    Kiddnapped Tundra and Ely010606 like this.
  28. Apr 12, 2020 at 4:18 PM
    #58
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    WOW those SDHQ terminals are nice! Been contemplating replacing my “mill spec” no name versions for awhile. Found them loose on a couple of occasions. Guess it’s time to do it.
    Platinum714 likes this.
  29. Jul 5, 2020 at 11:53 AM
    #59
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    Did you have any problems taking your factory cables and mounting them on the new sdqh terminals? No new new ends?
  30. Jul 5, 2020 at 12:31 PM
    #60
    BlueBottle
    '16 Platinum 4x4
    See fine print
    nope, its plug and play.
