Best and cheapest way to lift another 1-2in?
Discussion in '1st Gen Tundras (2000-2006)' started by 1stgenike, Dec 21, 2020.
  1. Dec 21, 2020 at 10:34 AM
    1stgenike
    1stgenike [OP] New Member
    '03 Tundra
    Yo guys.
    I have a 2003 4x4 Access cab that is currently leveled on the 4th notch with bilstein 5100s and a diff drop. All else is stock. (rear will be getting lifted, but I know how to go about that)
    I am looking to acquire about 1.5" more of lift in the front but want to make sure I do it correctly. Besides new UCA's, what is recommended to go about gaining this extra inch or two in the front without compromising reliability and ride quality? What are you guys running? Budget is ~$800.
    I am sure this is posted somewhere but I could not seem to find it, thanks a lot.
  2. Dec 21, 2020 at 10:40 AM
    Not sure there's much room for more lift upfront without really stressing the angles. You run out of droop up front eventually unless you relocate the lower control arms with a cradle. The RCD and TC lifts use a new cradle to accomplish more lift up front. Neither will be less than $800. 3-3.5" lift is max stretching it up front for the first Gen. It won't be ideal with that much lift, but some do it. 2.5-3" is where most people top out. New front springs can get you some additional lift. OME and I believe Eibach both make a spring that adds some lift up front. You can use them with your 5100's.
  3. Dec 21, 2020 at 10:54 AM
    1stgenike
    '03 Tundra
    Thanks for the info, I figured I would run into some major issues requiring me to make some major changes. I'll coninute to research with new springs.
  4. Dec 21, 2020 at 11:03 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You don't want to go that high with this method. Your cv axles won't last, your ball joints won'tlast, your alignmentwill be super twitchy. If you are on the 4th notch and want more your only options are a body lift or go with the RCD 6" lift. Body lift is within budget but isn't everybody's cup of tea.
    What are you looking to do with this truck? What is the reason to go higher?
    Stuck in the '00s and des2mtn like this.
  5. Dec 21, 2020 at 11:22 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'm curious to know the truck's purpose and reason for going higher as well. What size tires are you running?
    If you are wanting to lift for ground clearance - get taller tires. Going from a stock tire to a 31" or 33" diameter will give you some lift in addition to the ride height increase from the suspension.
    Body lifts also won't give you any more ground clearance. I looked into them briefly and quickly turned away, anything more than a one inch body lift on these trucks seems like a huge hassle.
    Stuck in the '00s likes this.
  6. Dec 21, 2020 at 11:27 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Body Lift - it is better because cost is very low, life is very long and center of gravity is raised about 1/3 only because heaviest components (engine/trans/TC/Diffs/frame) stay attached to frame and at same height, only the body and a few lighter components move Up, so a 2" body lift only raises center of gravity about 2/3". Luck.
    https://www.tundras.com/threads/body-lift-for-03-tundra.1858/
  7. Dec 21, 2020 at 1:55 PM
    Sunnier
    Sunny
    San Diego, CA
    Best OR cheapest? Like other have said, knowing why you want the lift and how you use your truck would help us make worthwhile suggestions. If you want increased ground clearance, you’ll need “best”, which > $800: larger tires, potentially different suspension components. But if you just want looks and don’t plan to do much off-road, you can do a body lift, < $800.
