Bed hop, has anyone found a solution?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Superbrad, Nov 16, 2018.
  1. Nov 20, 2018 at 7:06 PM
    #61
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Go ahead and take out your shocks just leaving the leafs. Settle her right down. If it doesn’t take all your leafs out of the pack except the top one :anonymous:
  2. Nov 20, 2018 at 7:12 PM
    #62
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    I have a 2018 DCLB 4x2 and the Coachbuilder bushings alone with stock shackles certainly helped. I have heard the stiffer CB shackles help also but I didn't want any lift as the truck is too damn tall as is to even try to work out of, you'd need a 2 foot stepladder to reach a saddle mounted toolbox or into the bed.
    Black Wolf, Superbrad[OP] and Rica25 like this.
  3. Nov 20, 2018 at 7:29 PM
    #63
    Superbrad
    Superbrad [OP] New Member
    Brad
    2018 Tundra SR 5.7 4x4 long-bed White
    You’re right, this truck is great on blacktop / asphalt. I’m comparing this excessive rear end bounce to my old truck, an ‘04 F150 Heritage, this was a continuation of the ‘97-‘03 model, not the next gen ‘04-‘09 model
    I use both trucks the same way on the same roads. Seems to me Toyota should address this issue, the Tundra is vastly superior in every other way, how did they not design it to cope with the roads it will encounter? Many western states use this concrete slab stuff and the Tundra is built in Texas, I know they have it there.
    Rica25 likes this.
  4. Nov 20, 2018 at 7:38 PM
    #64
    @ToyTec.............Might be a good time to discount a shackle /poly bushing set. Just sayin....
    Rica25 likes this.
  5. Nov 20, 2018 at 8:16 PM
    #65
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    This is what I have. When I installed my BOSS lift though, I saved the bushing replacement project for another day. Still running OEM bushings but I need to swap those out soon.
    Rica25 and Black Wolf[QUOTED] like this.
  6. Nov 20, 2018 at 8:21 PM
    #66
    You can go to Auto Zone or equivalent and they will have a special tool made specifically to remove leaf spring bushings that you can "borrow" with ID and deposit. Will still be a bitch. OEM bushings have zero play. Main cause with bounce due to trapezoidal layout of the springs.
    Rica25 likes this.
  7. Nov 20, 2018 at 8:23 PM
    #67
    Rica25
    Ricardo
    Tulare
    That's what I'm gonna have to do or take it to my shop at Honda dealer
  8. Nov 20, 2018 at 8:29 PM
    #68
    Rica25
    Ricardo
    Tulare
    Would it be easier to take whole leaf spring of to press them out?
  9. Nov 20, 2018 at 8:32 PM
    #69
    Absolutely...I wish I did, but you don't need to. If you removed them then all you need to do is use a press to get the bushings out. Less labor to get them out without taking them off but not a lot of space. Expect fucked up elbows and knuckles...
    Rica25[QUOTED] likes this.
  10. Nov 20, 2018 at 8:35 PM
    #70
    Rica25
    Ricardo
    Tulare
    What preparation if any should I do when installing anything that will make it easier to get them out?
  11. Nov 20, 2018 at 8:38 PM
    #71
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Black Wolf likes this.
  12. Nov 20, 2018 at 8:42 PM
    #72
    Remove the spare tire. Jack up the rear and support frame on both sides and remove the rear tires. Use a floor jack placed underneath the pumpkin for support and to raise and lower pumpkin as needed once the lower shackle bolts are removed. Once the lower shackle bolts are off use floor jack to lower pumpkin as low as you can to get enough space to use bushing removal tool. After you have put in the new poly bushings.. use the floor jack to lift the pumpkin to position the spring to line up with the shackle to make it easy to get the bolts in ...Tighten..
  13. Nov 20, 2018 at 8:43 PM
    #73
    That is the tool..............
    Rica25 likes this.
  14. Nov 20, 2018 at 8:50 PM
    #74
    I hate f'king spell check bs..
    Rica25 likes this.
  15. Nov 20, 2018 at 8:51 PM
    #75
    Rica25
    Ricardo
    Tulare
    I'll have to go borrow that tool
  16. Nov 20, 2018 at 8:52 PM
    #76
    Rica25
    Ricardo
    Tulare
    Spare tire was removed today because I need to purchase a matching one now but dont know if it will fit with shackles
  17. Nov 20, 2018 at 8:55 PM
    #77
    @Sterlinglwood's pic shows it being done with out jacking up and removing tires. Can be done but can be a bitch since our springs are in a trapezoidal position. Makes it hard to align everything just right. Easier to raise/lower pumpkin to position the spring to line up with the shackle.
  18. Nov 20, 2018 at 8:57 PM
    #78
    My ToyTec's do not interfere due to design. Plenty of room...
  19. Nov 20, 2018 at 9:00 PM
    #79
    15whtrd
    15whtrd Mr. Blonde
    Did you do both shackles at the same time? Or one side then the other.
    Rica25 likes this.
  20. Nov 20, 2018 at 9:19 PM
    #80
    Hoologan
    Hoologan New Member
    California
    I have a 20 ton press in the shop, a set of pulley pullers, or I could rent a ball joint puller lol. I just need to make the time to do it.
  21. Nov 20, 2018 at 9:21 PM
    #81
    Rica25
    Ricardo
    Tulare
    Looks like I'll be heading to your home for some work
    Hoologan[QUOTED] likes this.
  22. Nov 20, 2018 at 9:22 PM
    #82
    15whtrd
    15whtrd Mr. Blonde
    I saw a video of a guy using a small drill bit and drill to remove the bushings.
    Rica25 likes this.
  23. Nov 21, 2018 at 4:11 AM
    #83
    Same time. You have to otherwise you bind up things. It's a lot easier jacking the rear up and using a floor jack to maneuver the pumpkin. There are plenty of you tube vids on the methodology.
    15whtrd[QUOTED] likes this.
  24. Nov 21, 2018 at 4:45 AM
    #84
    15whtrd
    15whtrd Mr. Blonde
    That make total sense. Thanks Matt.
  25. Nov 21, 2018 at 5:04 AM
    #85
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    So are there any options to upgrade the bushing without adding a lift shackle? I too want to keep it stock height in the rear. I like the idea of the CB or Toytec shackles but I load dirtbikes and don't ever plan on wheeling the truck so no need to go up with the rear.
  26. Nov 21, 2018 at 5:12 AM
    #86
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    it's the road ant the seems normal for this. you can spend lots of money if you like when you change or beef up your suspension ride quality changes. good luck in your choice
    Rica25 likes this.
  27. Nov 21, 2018 at 5:13 AM
    #87
  28. Nov 21, 2018 at 8:59 AM
    #88
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
  29. Nov 21, 2018 at 9:39 AM
    #89
    Sterlinglwood
    Sterling
    Newbury Park, CA
    This is how I did it.
    Black Wolf[QUOTED] and Rica25 like this.
  30. Nov 22, 2018 at 4:33 AM
    #90
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    Just a observation, at 7:02 he pulled down on the leaf and moved the exhaust. I guess the +3 make the leafs come close to the tail pipe. Also just a thought, what about driveline angle? By just extending the rear portion of the leafs will that create more wear on the U-joint? Maybe not since the pumpkin would be inline more wth the driveshaft.
    If I do get a set I would give the +1 since I wouldn't want any more lift for my truck. Since these would take the hop out of the bed and these shackles are stronger has they're been more wear put on another part on the drivetrain? Like bushings?
