Bannock452 Build
Discussion in '2.5 Gen Builds (2014-2021)' started by Bannock452, Sep 26, 2016.
  1. May 6, 2018 at 1:02 PM
    #151
    Bannock452
    Bannock452 [OP] New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Some photos from Tundras to Sedona 2018 was a fun trip but it sure went by fast! Next year I’m going for a whole week!
    J&ATundra, dorton, Wallygator and 8 others like this.
  2. May 6, 2018 at 1:35 PM
    #152
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    looks like an awesome time!
  3. May 14, 2018 at 6:54 AM
    #153
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Awesome rig man! Would there be any sort of chance on purchasing a set of those hood bulge brackets from you? :) I was looking at that same bar, 30”?
  4. May 15, 2018 at 6:27 PM
    #154
    Bannock452
    Brandon
    Murrieta, CA
    Thanks man! The light bar in my hood budge is a 38”. Unfortunately I do not have any of my own fab tools at home. I work in a fab shop and the boss man doesn’t want me using the shop and his tools for other people. I hope you understand and I would be more than happy to help you out and make some of those brackets if it were possible. Maybe your local fab shop can make some real quick since they where pretty simple to bend up.
    SDHQ makes a hood budge mount kit. It’s made for the Baja Designs 40” s8 but it might work with the 38”.
  5. May 16, 2018 at 4:27 AM
    #155
    Js18tundra
    Dang, yea I saw those brackets by SDHQ, would you mind shooting a pic on where you mounted the light and how tall the brackets are? Fantastic job on the rig so far by the way!
  6. Sep 11, 2018 at 11:49 AM
    #156
    Michael Tregre
    Michael Tregre New Member
    '14 Tundra SR5 CM
    Notta
    Nice ride buddy, May I ask: How did you go about painting your chrome? I'm looking to de-chrome but none of the shops around me seem to want to touch them with paint....? PM me if need be, I wil patiently stand by.
  7. Sep 11, 2018 at 9:07 PM
    #157
    Bannock452
    Brandon
    Murrieta, CA
    Hey Mike! So it’s a wierd story but I had a friend who knew some guys a a body shop. They quoted me like $980 total. That was a little high for me so my friend asked the guys if they wanted to do it cheaper after hours for less.. one of the guys did it. So I gave my bumpers and grille to my friend and he dropped it off to that guy. I have no idea what he did to achieve the color match but it came out great!
    Also look into getting it wrapped. Ppl are having good results with that! Also a few doing powdercoat for much cheaper but comes down to what color you have since they don’t do color match powdercoat from what I understand.
    Hope that helps ya. Good luck!
  8. Sep 12, 2018 at 6:27 PM
    #158
    Michael Tregre
    '14 Tundra SR5 CM
    Notta
    Thanks for the reply.
    I have a shop lined up that's going to paint them. I won't know the prep process either!
  9. Sep 14, 2018 at 11:43 PM
    #159
    L3TT3RS
    L3TT3RS New Member
    Taylor
    19 Tundra
    Fox/Total Chaos/Coachbuilder
    I need these fog bezels in my life
  10. Jan 24, 2020 at 11:14 AM
    #160
    Overisland
    Overisland New Member
    Tony
    Polson, MT
    2020 Tundra Voodoo Blue Sport
    How are you liking your Switch-Pro? Do you use the 9100's app much? Any personal experience with SPod? I am leaning towards Switch-Pro 9100 with a console shifter mount from SDHQ but not sure. I spy a auxiliary fuse box mount on top of your factory fuse box, any info on this?
  11. Feb 15, 2020 at 7:51 PM
    #161
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Day Yum son. Your pictures just sold me on the Extreme LED light bars.
  12. Sep 19, 2020 at 8:45 AM
    #162
    Bannock452
    Brandon
    Murrieta, CA
    SO i haven't updated this build in a while. so going to add a few things that have changed in the past year or so.
    ARB Twin air compressor mount
    I previously had the ARB single and was making a single mount for sale. Due to the high demand for the twin compressor i redesigned and made a mount strong enough for the larger twin compressor. These mounts are still available for purchase. More info for the Twin Compressor in this other thread i created a while ago.
    https://www.tundras.com/threads/bolt-in-on-board-air-compressor-mount.23769/
    J&ATundra, Wallygator, 2Tall and 2 others like this.
  13. Sep 19, 2020 at 9:08 AM
    #163
    Bannock452
    Brandon
    Murrieta, CA
    KING Shock rebuild
    600lb springs were sagging and the springs were coil binding. I decided to switch to the 700lb springs to have same lift with less preload adjustment. I still kept my Coachbuilder shims. (2 driver 1 Pass)
    Since i had the shocks off i pulled them apart and changed the oil and stiffened up some of the valving shims.
    40,000 miles on these shocks and the oil was really bad! very easy to change the oil.
    Added the Total Chaos Spindle gusset while i was doing everything.
    High Quality Spring Compressor is a MUST!!! 700lb springs are no joke.
    Wallygator, Flyinryank, 2Tall and 2 others like this.
  14. Sep 19, 2020 at 9:22 AM
    #164
    Bannock452
    Brandon
    Murrieta, CA
    DUROBUMPS Bumpstops
    Switched my Wheelers offroad superbumps over to the Durobumps. Big difference when suspension is at full bump. Highly recommend upgrading the factory bumpstops if your doing any kind of offroad!
    Cfincke, Wallygator, TheBeast and 3 others like this.
  15. Sep 19, 2020 at 10:44 AM
    #165
    TheBeast The Beach
    very nice ! still running the same tires ?
  16. Sep 19, 2020 at 12:21 PM
    #166
    Redcon41318
    Redcon41318 New Member
    Do the larger stops limit or affect the motion of travel?
    Also when you installed your king shocks all around, was your truck all stock at the time? I plan on running kings but want my truck to be all stock.
  17. Sep 19, 2020 at 12:28 PM
    #167
    Bannock452
    Brandon
    Murrieta, CA
    Oh ya I haven’t updated that yet also! I switched to the BFG KM3 tires. I freakin love them. Seriously work very well on all types of terrain. Not that loud on the highway as well. Definitely recommend the tire for performance. They are wearing down pretty fast but I also have done a ton of offroad and abuse since I got them.
  18. Sep 19, 2020 at 12:36 PM
    #168
    Bannock452
    Brandon
    Murrieta, CA
    The aftermarket Bumpstops do not affect travel at all. They are a progressive rubber compound so it will actually fully compress down to the stock mount if it were hit hard enough. But by that time it’s already slowed down the force.
    Second yes my truck was fully stock when I installed the King’s. Even the UCA was stock. Drove like that for a while. Adding the Camburg UCA gained a lot of caster and it drives smoother now with they UCA but you should have no problem with stock setup. Any big coilover are way nice over stock shock.
    TheBeast likes this.
  19. Sep 19, 2020 at 12:46 PM
    #169
    Redcon41318
    Thanks! I could run aftermarket kings or foxes without any lift right?
  20. Sep 19, 2020 at 1:56 PM
    #170
    TheBeast The Beach
    how many threads showing on your coilovers now after switching to 700 lbs ?
  21. Sep 23, 2020 at 7:52 PM
    #171
    Bannock452
    Brandon
    Murrieta, CA
    I now have 7 threads drivers side along with 2 coachbuilder shims. Pass side I’m at 6ish with 1 shim. Sits pretty level now. I started out with zero preload and it rode very nice but sat down little low. Few turns stiffer it handles much nicer. Also I removed the front swaybar and that’s amazing when offroad. Huge improvement without the swaybar. But towing is a bit sketchy without it. I’ve since then added the swaybar back on since I am doing more towing than offroading with the truck.
    TheBeast[QUOTED] likes this.
  22. Oct 26, 2020 at 6:21 PM
    #172
    csgaddy
    csgaddy New Member
    How have your mirror caps held up? You wouldn't happen to remember what white spray paint you used would you?
  23. Dec 19, 2020 at 4:45 AM
    #173
    pug master
    pug master New Member
    kris
    2020 Tundra
  24. Dec 19, 2020 at 4:50 AM
    #174
    pug master
    kris
    2020 Tundra
    well your doing a great job on the Tundra but what is the website and the p/n of the mounting bracket for the ARB twin .. also when I lived in San Diego County people of escondildo always called it Gods Country. But for me . Colorado is heaven without the taxes..
  25. Dec 20, 2020 at 6:28 PM
    #175
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Bannock452[OP] likes this.
  26. Dec 21, 2020 at 9:52 AM
    #176
    Bannock452
    Brandon
    Murrieta, CA
    Hey Kris! Unfortunately I don’t have a website or a specific part number. I am just building these in my garage per order as a custom sale. If you would like to purchase a mount I can send you further info via PM.
    Also I can second that Escondido isn’t very special of a place haha. I have family in CO and it’s absolutely a beautiful place. With my work being in offroad fabrication and Baja racing SoCal is the prime spot for the offroad community.
    pug master[QUOTED] likes this.
  27. Dec 21, 2020 at 10:17 AM
    #177
    pug master
    kris
    2020 Tundra
    My first VW Baja was the first ever car .and it was no date car. Mom and Pops were happy about that. Let me see . King pin front end. turned up 1/4 in full roll 1600 duals with vw bus boxes to go faster on the flats .and of course Jackman wheels made in El Cajon . with twin Bilstein's in back . When I sold it the girl when with the Bug. Damn I miss that Baja bug ..Not the girl
    300BLK likes this.
  28. Dec 21, 2020 at 2:05 PM
    #178
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Love how purpose built this is. This was a while back in your build but how do you like the Magnaflow muffler?
  29. Dec 21, 2020 at 2:10 PM
    #179
    pug master
    kris
    2020 Tundra
    I would love to but I have a HARROP supercharger and the GUYs at exhaust pros told me it would ,Lean out the cylinder and cause unwanted wear on the rings so I'm still waiting on a after market tune . so i can adjust the fual mixture
  30. Nov 5, 2021 at 9:58 AM
    #180
    CoryShap09
    CoryShap09 New Member
    Cory
    2020 CM XP
    Is that how you did your grille too?
