Bannock452 Build
Discussion in '2.5 Gen Builds (2014-2021)' started by Bannock452, Sep 26, 2016.
  1. Jan 26, 2018 at 7:03 AM
    #121
    Bannock452
    Bannock452 [OP] New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    My front stock skid plate was starting to look pretty hammered and I counldnt stand removing the entire skid each time for an oil change. So it was time for a new skid.
    Went with RCI OFFROAD Steel since it was a great price and the steel would be strong! Thanks RCI!
    BE8C3408-9C3B-4AC9-8984-E40E9CD07D1A.jpg 5B064197-C33F-489C-965F-4DB079CBB627.jpg 1453BB4E-31BB-47D1-966B-08E8B3C9A673.jpg
    Sbrakeville, aperezsh and Black Wolf like this.
  2. Jan 26, 2018 at 7:59 AM
    #122
    Bannock452
    Brandon
    Murrieta, CA
    Added an ENGINE BAY LIGHT since Toyota opted not too. Fairly easy install. Used 1 15w rock light and dang it’s plenty bright.
    Hardest part was fishing the wires thru the hood.
    dcsleeper408 and Flyinryank like this.
  3. Feb 19, 2018 at 5:36 PM
    #123
    jHpowderhound
    jHpowderhound New Member
    Eric
    Jackson Wyoming
    Nice truck. You keep finding things to do to her.
    Eric
  4. Mar 23, 2018 at 12:15 PM
    #124
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Do our trucks come stock with a magnetic drain plug or is that aftermarket?
  5. Mar 23, 2018 at 2:35 PM
    #125
    Bannock452
    Brandon
    Murrieta, CA
    They come stock! Definitely the rear and front differential drain bolts are magnetic. Transfer case I can’t remeber if it was or not.
  6. Apr 13, 2018 at 12:48 PM
    #126
    Bannock452
    Brandon
    Murrieta, CA
    Wanted to add slightly more lift to my front so decided to get some UCA at the same time.
    Camburg Uniball
    Before adjusting the coil (stock setting from king)
    After adjusting (4 turns total)
    Final set up after arms and alignment
  7. Apr 13, 2018 at 1:06 PM
    #127
    Bannock452
    Brandon
    Murrieta, CA
    Switch-Pros 9100 install
    Wanted to do something different so fab’d up some custom mounts for the envelope holder location.
    Not sure how to explain how I made the mounts but bolted up some aluminum and tapped the 10-32 holes that I can mount a plate to with the switch panel. Used some ABS plastic for final touch.
    aperezsh, DaBoro54, Jsena and 7 others like this.
  8. Apr 13, 2018 at 1:33 PM
    #128
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    love the SP setup!
    when does that go for sale?
    TheBeast likes this.
  9. Apr 13, 2018 at 1:52 PM
    #129
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    My thoughts exactly. Hell of a good idea @Bannock452
  10. Apr 13, 2018 at 1:54 PM
    #130
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    I'll "third" that request. Love the way your truck is coming along.
    TheBeast and dcsleeper408 like this.
  11. Apr 13, 2018 at 2:03 PM
    #131
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    i'll take 10% for sales commission @Bannock452
    and probably a special request to accommodate a sunroof switch model for the baller trucks! i'll take 5% r&d + 10% sales commission :D
  12. Apr 13, 2018 at 2:13 PM
    #132
    TheBeast The Beach
    clean !
    for the KING adjustment, did you have any lean driver side and did you adjust for it ?
    dcsleeper408 likes this.
  13. Apr 13, 2018 at 2:13 PM
    #133
    Bannock452
    Brandon
    Murrieta, CA
    Thanks guys! this custom mount was honestly a PITA. trying to mount metal to plastic is very challenging esp when trying to keep things hidden and looking clean and factory. i really don't know if there is any way to make a bolt on mount like this without a lot of custom work. for now I'm happy to share my ideas and how i did it!
  14. Apr 13, 2018 at 2:17 PM
    #134
    Bannock452
    Brandon
    Murrieta, CA
    Negative. No drivers lean at all. Measurements came out with less than 1/4" difference each side. Both coils are adjusted exactly the same.
  15. Apr 13, 2018 at 2:17 PM
    #135
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    i got faith in you brandon! just charge more for the ballers with sunroofs.
  16. Apr 13, 2018 at 2:18 PM
    #136
    TheBeast The Beach
    you lucky, I have 5 more full turns driver side. I had almost 1" lean
  17. Apr 13, 2018 at 2:19 PM
    #137
    Bannock452
    Brandon
    Murrieta, CA
    haha sounds good man! ill just make the mounting plates and JB weld that S%$t up there and call it a day! ill include a free bottle of JB weld.
  18. Apr 13, 2018 at 2:41 PM
    #138
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :anonymous:
    You are not suppose to disclose that info.
    Just send it and let the customer deal with it..
  19. Apr 13, 2018 at 8:05 PM
    #139
    Tundra4us
    Tundra4us New Member
    "D"
    Dont want to be "negative nelly" here, is that out of the box new measurement? Wait a few and let things settle in. Pretty sure you will end up with dreaded "Tundra Lean"...
  20. Apr 13, 2018 at 8:13 PM
    #140
    TheBeast The Beach
    that's what happened to mine. After it settled. Tundra lean..no big deal..tacomas have it good too..lol
  21. Apr 13, 2018 at 10:35 PM
    #141
    Bannock452
    Brandon
    Murrieta, CA
    I had the king shocks for 2 years before readjusting the lift. I did before and after measurements when cranking down the coil. Still no lean. I always try to take measurements exactly the same way and most importantly to drive the truck down the road after adjustment to let things get back to normal then back to measure. Even if there was any sort of lean it can be adjusted in alignment to drive correct.
  22. Apr 14, 2018 at 9:10 AM
    #142
    Bannock452
    Brandon
    Murrieta, CA
    Full size spare
    Did this a while ago just haven’t added to my build. Picked up a used tire for cheap.
    I just drilled out the steel rivits holding the stock spare in place.
    Plenty of room on each side with the stock shackles
    Now that I have a full size spare I won’t ever need to use it! Right? Haha
    stolentricycle and Black Wolf like this.
  23. May 5, 2018 at 11:29 AM
    #143
    Bannock452
    Brandon
    Murrieta, CA
    Extreme Led Lighting
    38” X6S slim series
    4” falcon led pod for fogs
    Finally updated my lighting off the front. I wanted to mount a slim bar into my hood bulge. And I wanted to add pods in the fog location that point out not straight. So I made my own fog light bracket. I went with the large 4” pods and with the bracket I made they fit perfectly into the fog location while still looking very clean.
    No I’m not cool enough to buy the best Baja Designs lighting out but I have to say I’m very very impressed with my purchase. Extreme led has basically a Baja replica and the lumens and wattage is very similar. Love that I can have the side ambers on separate from the center spot beam.
    Way less money and honestly for a truck that is not racing or in need of high speed lighting these do the job very well!
    Here’s some photos of the backets I made myself to mount the bar and pods!
  24. May 5, 2018 at 11:37 AM
    #144
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Build is legit dude!
  25. May 5, 2018 at 11:42 AM
    #145
    Bannock452
    Brandon
    Murrieta, CA
    Few lighting output photos. All photos were taken with exactly the same setting to show the output difference.
    Sony a6300 kit lens
    0.5” f4 iso500
    Headlights only(low beam)
    Low beam + fogs
    Low beam+fogs+spot light bar
    Low beam+fogs+spot bar+amber bar
    Low beam+Light bar only
    Another spot with headlights only
    Headlights plus fogs
  26. May 5, 2018 at 11:43 AM
    #146
    TheBeast The Beach
    lighting up the road !
    Bannock452[OP] likes this.
  27. May 5, 2018 at 11:54 AM
    #147
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    man this truck is sexy and all the mods are well thought out and have a purpose. honestly this truck is one of the reasons i bout a white tundra. i have modeled after yours with some slight differences. well done and keep up the great work!
  28. May 5, 2018 at 11:58 AM
    #148
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    NIce build thread right here.. truck looks pretty damn good bros
  29. May 5, 2018 at 2:18 PM
    #149
    Bannock452
    Brandon
    Murrieta, CA
    Thanks man! My main goal when building this truck was to make it as functional as possible while still keeping it stock looking!
  30. May 5, 2018 at 2:19 PM
    #150
    Bannock452
    Brandon
    Murrieta, CA
    Thanks dude! Just trying to be like the cool kids!
