Ball joint!! Happy Friggen New Year to me!! Ugh
Discussion in '1st Gen Tundras (2000-2006)' started by Adventundra, Jan 11, 2023.
  1. Jan 15, 2023 at 6:52 AM
    #61
    Adventundra
    Adventundra [OP] New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    I am in Toms River, NJ.
    w666[QUOTED] likes this.
  2. Jan 15, 2023 at 12:35 PM
    #62
    Aerindel
    Aerindel New Member
    Montana
    Get a Harbor Freight high-lift, floor jack. Your driveway is practically a shop floor compared to where I have to work on my truck. I really don't think you will have a problem with even a halfway decent jack and stands.
    Its good to be cautious when lifting thousands of pounds of valuable vehicle...
    But from looking at your picture, I'm really not sure what you are worried about. Looks like a perfectly fine place to do the job. You don't have to jack it up any higher than you would to change a tire.
  3. Jan 15, 2023 at 12:41 PM
    #63
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks!!
  4. Jan 15, 2023 at 12:45 PM
    #64
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    If you have a piece of 3/4" plywood, you can toss it under there to give the floor jack something to roll it's back wheels forward upon a few inches as you lift the vehicle.
    I do this all the time in my folks asphalt driveway so the wheels won't make an impression upon it.
    w666 and Adventundra[OP] like this.
  5. Jan 15, 2023 at 1:13 PM
    #65
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Ah yes, I know it well. Too far for me, however, so I'm not your guy. Still, it will be easy. Just follow the suggestions you're given. If you manage to get it up in the air, then you may as well just replace the ball joint right then and there. You basically need two wrenches, and a BFH. And maybe some pliers to get the cotter pins out. There are two castle nuts, one on the LBJ, and one on the tie rod end. Remove the pins, then remove the nuts, then use the BFH to free the tapers. Then just 4 bolts to undo and replace the LBJ.
    I'm oversimplifying it, but not by much. Even if you wind up buying a new jack and LBJ you're in it for about the same $ as the flatbed tow ride. There are lots of YouTube videos available, this is just the first one I pulled up:
  6. Jan 15, 2023 at 1:51 PM
    #66
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Outstanding!! Thanks!! But what is a BFH…bald faced hammer?? Lol
    Leo's first and Randy Morton like this.
  7. Jan 15, 2023 at 2:11 PM
    #67
    Jack McCarthy
    Bill
    North of Boston
    BFH = Big Fucking Hammer
  8. Jan 15, 2023 at 2:18 PM
    #68
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Bald faced hammer? Would this qualify?
    Leo's first likes this.
  9. Jan 15, 2023 at 2:51 PM
    #69
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Lmfao!!!!
  10. Jan 15, 2023 at 3:07 PM
    #70
    That sir is an anvil on a stick!
  11. Jan 17, 2023 at 1:09 PM
    #71
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I used TRW LBJs while doing preventative maintenance in may of 2019 instead of OEM. :crapstorm:
    I will say they looked identical to the Toyota LBJs I removed (they are sealed w/o a grease zerk like most aftermarket options). I check them a couple times a year and they seem to be holding up fine after about 35K miles.
  12. Jan 17, 2023 at 3:22 PM
    #72
  13. Jan 17, 2023 at 4:49 PM
    #73
    Baller
    Baller New Member
    '05 Tundra SR5 DC
  14. Jan 17, 2023 at 7:53 PM
    #74
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Welp…mechanic came through and stopped by the house yesterday….bout 45 mins and it was done!! $90 for the part…& $60 for labor and the old girl is back on the roads of adventure!! First trip was to the woods to run the beagle for rabbits!! Tally-ho!!!!
    Hooked mechanic up w a good tip for his son who helped him…always good to see a father teaching his son his craft!
    Thanks for all of your insight!! We plan on doing the other side at his shop then some exhaust work on my boy’s 2000 Tundra.
    tvpierce, Randy Morton, w666 and 2 others like this.
  15. Jan 17, 2023 at 8:27 PM
    #75
    Aerindel
    Aerindel New Member
    Montana
    Told ya it wasn't a big job ;) Glad its fixed.
  16. Jan 18, 2023 at 5:17 AM
    #76
    Damn, that's cheap! Lowest I can get an OEM lower balljoint is ~$160. He did install a new OEM balljoint, right? With fresh bolts, so you don't have the exact same failure 5k miles down the road?
  17. Jan 18, 2023 at 5:39 AM
    #77
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    shifty`[QUOTED] likes this.
  18. Jan 18, 2023 at 5:46 AM
    #78
    2nd cheapest local stealership after tax, Rick Hendrick, runs me about $161. They don't allow local pickup. Most local dealerships near me are over $145-150 for the part.
  19. Jan 18, 2023 at 5:46 AM
    #79
    But I just re-ran, and it looks like Marietta Toyota is allowing local pickup. Still nearly $150. But that is really cool you earlier year dudes get your LBJs so cheap!
  20. Jan 18, 2023 at 6:08 AM
    #80
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Why wouldn't you order from McGeorge for $125 and free shipping?
    des2mtn and Aerindel like this.
  21. Jan 18, 2023 at 6:39 AM
    #81
    Uh, sorry, what were you saying? Toyota's standard promo code "FREESHIP" won't work here. Even if shipping was free, I'm out $140, nearly the same as local pickup.
  22. Jan 18, 2023 at 6:44 AM
    #82
    Cheapest I can get to is $130 ordering from Serra (of Birmingham AL, since that fuckhead Eric at Serra of Decatur AL is a lazy, shady, decrepit douchenozzle of a human)
    They don't charge tax, and FREESHIP coupon covers the 2hr ride to ATL.
    FirstGenVol likes this.
  23. Jan 18, 2023 at 6:45 AM
    #83
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
  24. Jan 18, 2023 at 6:46 AM
    #84
    Dunno what to tell you here.... This is literally using the exact link FGV posted above.
    EDIT: I forgot, McGeorge has that weird shit where they have 3 different parts websites. You must be on a different parts website for them.
  25. Jan 18, 2023 at 6:48 AM
    #85
    des2mtn
    Shady Grove
    Tonto cover
  26. Jan 18, 2023 at 6:49 AM
    #86
  27. Jan 18, 2023 at 6:49 AM
    #87
    des2mtn
    Shady Grove
    Tonto cover
    Edit: NVM
    shifty` likes this.
  28. Jan 18, 2023 at 7:16 AM
    #88
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think we're on the same page now. I wish they didn't have 3 different websites. McGeorge is likely who I'll use going forward since Serra is run by idiots.
    shifty` and des2mtn like this.
  29. Jan 18, 2023 at 7:30 AM
    #89
    Serra of Decatur definitely is. One of these days I'm going to give Serra Birmingham a shot, next time I have a couple of days to wait, and I don't feel like picking up.
    Toyota South Atlanta used to be my go-to dealership, it's really convenient to me and one or two other members, and the pricing was great. But the dealership changed hands recently, and they stopped participating in the Toyota Parts program not long after the change. Everything they sell now is by phone/OTC only, and full MSRP. I either need to find another way to get discounted parts, or drive north of town, which is typically a nightmare for any of us living south of downtown.
    des2mtn likes this.
  30. Jan 18, 2023 at 7:32 AM
    #90
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Thanks for posting the FreeShip information and dual websites from McGeorge. I have ordered exclusively from them the past couple of years but I'm kinda pissed one website charges shipping and the other does not. I've probably racked up over $200 in shipping charges.
