Ball joint!! Happy Friggen New Year to me!! Ugh
Discussion in '1st Gen Tundras (2000-2006)' started by Adventundra, Jan 11, 2023.
  1. Jan 11, 2023 at 6:37 PM
    Adventundra
    Adventundra [OP] New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Went to back out my 2001 to check some deer spots and drivers side dropped to the ground!! Good thing it didn’t happen while out driving around…especially the day before when me n my son were 45 mins from home out bird huntin in the woods!!
    I had scheduled the truck w a mechanic prior to this for front end work and he said after the holidays…now it sits in my driveway. He said he would come over and fix it in my driveway so towing it wouldn’t break anymore parts…but he been a no show so far. A tow truck can’t access the front of the truck….so they wud need to drag it onto a flat bed.
    If this mechanic is not a man of his word and fix it in the driveway…shud I have a tow truck drag it up a flat bed n bring it to a shop? I wud also try n do it myself but I have never done it before and wud need to jack it up somehow pretty high.
    Mr Badwrench likes this.
  2. Jan 11, 2023 at 6:45 PM
    Jack McCarthy
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Is it just the ball joint that snapped? Any damage to the spindle or upper control arm? You could get a jack in there if you have something stable to put it upon like a 2x10 or maybe 3 2x4s. You’d probably want to jack it under one of the front crossmembers to lift both sides of the truck and put jackstands underneath.
    Replace with OEM ball joints only. Most others are inferior and don’t last. Toyota even has a recall on them years back.
    Good luck.
    Adventundra[OP] and Aerindel like this.
  3. Jan 11, 2023 at 6:46 PM
    Aerindel
    Aerindel New Member
    Montana
    Its a pretty basic mechanical job if you are good at that stuff and have a decent jack. But really, I don't know you, so you have to figure out if your up to it or not yourself.
    Adventundra[OP] likes this.
  4. Jan 11, 2023 at 6:48 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    You could totally repair that ball joint. You got this.
    FrenchToasty and Adventundra[OP] like this.
  5. Jan 11, 2023 at 6:48 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks!! Just looks like ball came out of joint…I think no other damage.
  6. Jan 11, 2023 at 6:50 PM
    biebs96
    PA
    It looks like it punctured the tire? Hopefully it’s just an indentation…
    Randy Morton likes this.
  7. Jan 11, 2023 at 6:52 PM
    Are those the original factory shocks?
  8. Jan 11, 2023 at 6:53 PM
    LML 3500HD
    Thankfully you didn't have your 2001 TRD Pro cruising at 75 mph!
  9. Jan 11, 2023 at 6:54 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    Looks like it's just an indentation. If it punctured the tire, the rim would probably be closer to the ground.
    Shark Bait and Adventundra[OP] like this.
  10. Jan 11, 2023 at 6:55 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks! I think I can do it…seems basic enough…I have repaired boat motors and other mechanical stuff …just have to jack it up high enough somehow. I will try and find some videos on replacing it.
  11. Jan 11, 2023 at 6:58 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Yepper. I even took a different road the other day w less tandem dump truck traffic cuz I heard some squeaking down there…cud have drifted rt into oncoming lanes of those big rigs carrying fill dirt!! Wuda been a goner!!
  12. Jan 11, 2023 at 6:59 PM
    LML 3500HD
    Thankfully that didn't happen.
    Swap out all those joints and be good for another 200K.
  13. Jan 11, 2023 at 7:00 PM
    Randy Morton
    Randy
    Yikes!
  14. Jan 11, 2023 at 7:03 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Yup….just resting on the tire n causing an indentation….now I have to worry bout the integrity of that tire now. I knew I Shuda bought this LB a few wks ago!!! SMH
    Randy Morton[QUOTED] likes this.
  15. Jan 11, 2023 at 7:03 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    ^^^ THIS ^^^ Make sure to do both while you have in up in the air.
  16. Jan 11, 2023 at 7:07 PM
    shifty` One great big festering neon distraction
    Sorry, that sucks! That LBJ looks newer than all the frame and stuff around it. Has it been replaced before?
    Current one that snapped doesn't necessarily look like OEM.
  17. Jan 11, 2023 at 7:11 PM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Please use OEM replacements and buy new bolts while you're at it.
    BTBAKER and Adventundra[OP] like this.
  18. Jan 11, 2023 at 7:14 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    I think they were done many years ago…can’t remember much bout when
  19. Jan 11, 2023 at 7:15 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    WFD473 likes this.
  20. Jan 11, 2023 at 7:16 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    What front end work were you scheduled to have done?
  21. Jan 11, 2023 at 7:21 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Mechanic checked it out and said everything seemed “tight” but he could buy $500 in parts and $400 in labor to do a complete front end job….I imagine he was guna do both LBJs cuz the main issue was a horrible squeak while turning the steering wheel. Guys credibility dropped off big time since he been ghosting me
  22. Jan 11, 2023 at 7:22 PM
    Mr Badwrench
    Mr Badwrench New Member
    On new years day there was a Tacoma in a Dennys parking lot with a failed LBJ, in my town. I was thinking to myself... what a sh!tty way to start a new year.
  23. Jan 11, 2023 at 7:24 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Lol. Yup. That’s exactly how I felt…& it was actually on New Year’s Day n been sitting since waiting on this guy.
    I got the kind of luck that….if it was raining titties…I wud get hit in the head w a dick!!!
    JasonC., CodyP, 16CMTXED and 3 others like this.
  24. Jan 11, 2023 at 7:25 PM
    PenderBen
    2003 Tundra AC 4x4
    Yeah, sounds like maybe time for a different mechanic ;-)
    I was going to suggest throwing a cheap aftermarket LBJ on just to get it to the shop, depending on what was scheduled to replaced, still could be an option- just don’t leave it on there.
    LBJ is pretty easy diy if you’ve got the tools for it.
  25. Jan 11, 2023 at 7:27 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks! Tools are at a bare minimum…but my pal has a shop n cud probably borrow some jacks etc…fix it then get it in to his shop for other side
    PenderBen[QUOTED] likes this.
  26. Jan 11, 2023 at 7:31 PM
    Mr Badwrench
    It's not a terrible job, but it isn't fun. You don't really need any specialized tools besides a 36mm socket for the cv axle nut. You can pop the joint (what's left of it) out with a jack and two 3lbs.
    In the dead of winter, I'd probably opt to let someone else do it though, especially if the price was right.
  27. Jan 11, 2023 at 7:35 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    As others have stated make sure and get OEM parts from a reliable source like rockauto and not Amazon. Do both sides either yourself or let the mechanic do the other side. Best of luck to ya.
  28. Jan 11, 2023 at 7:37 PM
    PenderBen
    2003 Tundra AC 4x4
    I didn’t remove the axle or anything, basically just unbolted all the LBJ bolts, removed cotter pin and castle nut, used a pickle fork to separate the ball joint and reassembled in reverse, torque to spec. Get new bolts too, don’t reuse the old ones.
    It’s been a couple years since I did mine so I don’t remember it vividly, but it was no drama (unlike the upper balljoint…).
  29. Jan 11, 2023 at 7:49 PM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Good luck with the repairs. Really glad you weren’t hauling ass when it happened. :thumbsup:
  30. Jan 11, 2023 at 9:28 PM
    Aerindel
    Aerindel New Member
    Montana
    This is how I do it too. No need to take the axle off.
    Sunnier likes this.
