Ball joint!! Happy Friggen New Year to me!! Ugh
Discussion in '1st Gen Tundras (2000-2006)' started by Adventundra, Jan 11, 2023.
  1. Jan 12, 2023 at 3:13 AM
    Adventundra
    Adventundra [OP] New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Woke up feeling not too motivated….lol…any ideas to put the piece touching the ground on some type of rolling device n get it on a flat bed to a shop?
  2. Jan 12, 2023 at 6:25 AM
    txagg
    txagg New Member
    Central Texas
    2000 4x4 TRD Tundra access cab
    Stone cold stock
    Drink some coffee, and then rethink it. Watch a YouTube and write down the sockets you need, think it's two sizes. The ball joint is 4 bolts. Get some landscaping blocks and put the factory jack on top of them and get that sucker in the air. The best way to get it to roll is a movers dolly or with plywood and a rolling jack. Deal is, you don't want it moved like that with it on that tire. In the end, I estimate it to be more work and risk getting that thing ready for a flatbed than putting a new ball joint on it. When you finish, I bet you'll be pissed they were going to charge you so much in the first place.
  3. Jan 12, 2023 at 7:37 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks!! Coffee and this….I’m Feeling better already!! Lol
    txagg[QUOTED] and KNABORES like this.
  4. Jan 12, 2023 at 12:40 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    :facepalm:
    Sunnier and txagg like this.
  5. Jan 12, 2023 at 1:06 PM
    Huh, I’m only familiar with one first Gen TRD PROffessional hand model
    ColoradoTJ and txagg like this.
  6. Jan 12, 2023 at 1:22 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Anything can be a pro with a sticker on it. I tried that hybrid sticker for my Tundra to park in the hybrid only spots. Only got by the female parking enforcer and none of the guys. Most likely she didn't know much about trucks. Had to give up after the 2nd write up otherwise the 3rd would go to my supervisor. Short lived but epic.
  7. Jan 12, 2023 at 2:25 PM
    It’s the little details….
    texasrho83 and Jack McCarthy like this.
  8. Jan 12, 2023 at 2:25 PM
  9. Jan 12, 2023 at 5:17 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    :bananadead:
  10. Jan 12, 2023 at 5:25 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Alright, I'm sorry about poking fun of the 1st Gen TRD Pro. The ball joint is an easy job. A torque wrench is the only real specialty tool you need, if you even consider a torque wrench a specialty tool. Replace it and have fun getting to know your rig that much better.
  11. Jan 12, 2023 at 5:27 PM
    Aerindel
    Aerindel New Member
    Montana
    The typical off-road thing to do when this happens is use a heavy duty ratcheting tie down to pull the ball joint back up into place, more or less, so you can get off the mountain.
    But as mentioned, jerry rigging it enough to roll, is barely any easier than actually just fixing it for real.
  12. Jan 13, 2023 at 9:45 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Lol. Thanks! Yep…when I first found this site n created a log on…I put that on my profile not even following any of the trim levels closely! I even thought that rear decal said Pro! Lol. I certainly wasn’t trying to be a poser and fluff my 01 up anymore than it is…just wasn’t well versed in trim levels…& really still not well versed in em…but I know I have to stick with the SR to get the front bench seat for when I upgrade.
    txagg likes this.
  13. Jan 13, 2023 at 9:47 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Christ!!! That rig has “me” written all over it…probably wud wrap some electrical tape on it for some finishing touches! Lol
    Thanks!!
  14. Jan 14, 2023 at 6:21 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Any ideas how to do this ratchet strap rig? Can’t find any youtubes on it…and if I can do it just to roll it onto a flat bed then I can get it to my mechanic
  15. Jan 14, 2023 at 7:46 AM
    I would use at least 2 ratchet straps if your goal is to move it onto a wrecker. Around the Upper to lower control arm to get them close together. Either the front side or the back, front side may be easier. guide the ball joint back into alignment. Then wrap one around the whole knuckle end around the upper and lower arm there as well. Once they are all close together and in place, big zipties wherever you can to keep things lined up. Your ratchet straps may get ruined.
    Adventundra[OP] likes this.
  16. Jan 14, 2023 at 7:51 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks!! Will I actually be ratcheting these two components together…or just tying em together? Will they be moveable by hand once the truck is lifted up?
  17. Jan 14, 2023 at 7:52 AM
    Sunnier
    Sunny
    San Diego, CA
    @Adventundra
    this is all the good advice. If you don’t use OEM Toyota parts, you won’t know what you’re getting. LBJ failure on these 1st gens is common, but avoidable. Now that it’s happened to you, don’t let it happen again.
  18. Jan 14, 2023 at 7:56 AM
    They are under spring tension. Not easily moved together, hence the ratchet straps. You will be man handling the components together. May need a pry bar. A second set of hands would help too.
  19. Jan 14, 2023 at 8:02 AM
    #49
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Gotchya! Thanks!!
  20. Jan 14, 2023 at 8:06 AM
    #50
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks!! I touched base w my mechanic who has not made this a priority, no communication, ghosted a few scheduled days of doing it in my driveway….including today…& he said he bought “aftermarket” parts but they are not OEM…I think I need to cancel him n use someone else if I can get it on a flatbed
  21. Jan 14, 2023 at 8:21 AM
    #51
    You definitely need to cancel him.
  22. Jan 14, 2023 at 8:44 AM
    #52
    Need to get a local panhadlemonium stirred up. Maybe some local to you members here would be down to help.
  23. Jan 15, 2023 at 2:59 AM
    #53
    tvpierce
    tvpierce Formerly New Member
    Maine
    ^^^ +1 on this.
    To get the ratchet straps on you've got to jack up the truck and support it. Once you've done that, the job is half done... might as well replace the ball joint at that point.
    @Adventundra Did you watch the video in post #19? You just need 2 wrenches (17mm & 27mm) and a hammer. (you don't need to remove the axle nut, so you won't need a 36mm)
  24. Jan 15, 2023 at 3:11 AM
    #54
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Gotchya! Thanks!! Yep…I posted that video and have to watch it a few more times to soak it in. Any advice bout how to get this thing up to be able to work on it…it’s on uneven dirt…maybe a tall box made of landscape ties …or…any type of roller I can rest under the control arm then pull it back 20 ft to flat driveway? Or just do it where it sits?
  25. Jan 15, 2023 at 3:47 AM
    #55
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Hey there! Mechanic in the video I found in post #19 used TRW parts…any difference between OEM? Are you familiar with TRW LBJ parts? I think both run bout the same cost.
  26. Jan 15, 2023 at 5:47 AM
    #56
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Not familiar with them but I would stick with what we know works and buy from a dealer.
  27. Jan 15, 2023 at 5:50 AM
    #57
    tvpierce
    Maine
    I'd try to do it right where it sits.
    Do you have jacks and stands? RR ties would be good to support it once you got it off the ground. You may have to jack in stages: jack it up, set it down on blocks/stands, put blocks under the jack, jack it further, put in more blocking.
    Edit: I wouldn't use TRW ball joints.
  28. Jan 15, 2023 at 6:08 AM
    #58
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    @Adventundra - where in the land are you? Perhaps there's a member nearby who can help you out.
    Aerindel and Adventundra[OP] like this.
  29. Jan 15, 2023 at 6:49 AM
    #59
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Gotchya!! Thanks!!
  30. Jan 15, 2023 at 6:50 AM
    #60
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Great!! Thanks!!
