Bak Revolver x2, who has one?
Discussion in 'Tonneau Covers, Caps and Shells' started by Njmike13, Jan 13, 2018.
  1. Jan 16, 2018 at 9:03 AM
    Njmike13
    Njmike13 [OP] New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    If anyone is looking for something from autoanything do yourself a favor and check with @eccracer104 before you order.
    Pudge[QUOTED] and eccracer104 like this.
  2. Jan 18, 2018 at 8:15 AM
    Njmike13
    2021 PRO Lunar Rock
    Ordered the Revolver X4. Can't wait to get it on the truck! Huge thanks again to @eccracer104. I'll post pics once installed.
    eccracer104 likes this.
  3. Jan 18, 2018 at 8:16 AM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    :woot:
    Can't wait to see the end result!
  4. Jan 18, 2018 at 10:42 AM
    soarvet
    soarvet New Member
    2017 Silver Tundra Crewmax 4x4 XSP package
    I'm diggin' my x2. It works for what I need it for. If you want to use the bed extender. the locking bars will get in the way, so it won't rotate. You'll have to manually flip it and set it in the bracket.
    Njmike13[OP] likes this.
  5. Jan 18, 2018 at 11:00 AM
    Njmike13
    2021 PRO Lunar Rock
    Good to know. I plan on using a bed divider that mounts to the track system. Not sure if lowering the track system will be a problem for bed dividers. I will get a measurement after I install the cover.
    soarvet[QUOTED] likes this.
  6. Jan 19, 2018 at 1:13 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Judging from this picture of an older tundra with what I think is an oem bed divider and from seeing them on tacomas.... they don't hang down to the bed floor. There's at least and inch under them so I'm thinking you'll be ok even after lowering the rails.
  7. Jan 19, 2018 at 3:04 PM
    Njmike13
    2021 PRO Lunar Rock
    Sweet. Thanks for the pic.
    Pudge likes this.
  8. Feb 21, 2018 at 12:32 PM
    Njmike13
    2021 PRO Lunar Rock
    Finally got and installed my X4. Easy install and love the way it looks. Thanks for the pro's and cons of the X2. Had to wait 5 weeks because Bak was backlogged 2,000+ X4's!
  9. Feb 21, 2018 at 4:55 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Looks great, I like the matte look of the x4.
  10. Feb 21, 2018 at 4:58 PM
    Pudge
    CT
    How'd it work out with the bed divider?
  11. Feb 21, 2018 at 5:05 PM
    Njmike13
    2021 PRO Lunar Rock
    Didn't get one yet. Only lowered the rails about an inch. Looks like I won't have a problem from the pic you posted. Thanks again.
    Pudge[QUOTED] likes this.
  12. Feb 21, 2018 at 5:54 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I believe in the bed divider footnotes it stated that it will NOT work when the factory deck railing has been lowered. I only remember reading that (there was a link on here somewhere) and was disappointed about it. If anyone does try it, because I agree with you that it looks like it should work, let us know. I need a sliding divider desperately!
  13. Feb 23, 2018 at 7:46 AM
    kirk1963
    kirk1963 New Member
    Are these more or less water resistant than the MX$? looks great!
  14. Feb 23, 2018 at 8:32 AM
    Njmike13
    2021 PRO Lunar Rock
    I have never had the MX4 so I can't speak about it. This one however is great so far. It has been raining since the day I installed it and other than a tiny bit of water near the tailgate it's dry. That's because of the tailgate not the cover.
  15. Feb 23, 2018 at 8:39 AM
    Njmike13
    2021 PRO Lunar Rock
    New plan. I'm going to order a tailgate net and hook it to the rail system and the lower bed loops to keep stuff from sliding forward. It will also be easy to remove and store when not being used.
  16. Feb 3, 2019 at 7:42 AM
    RoadRacer19
    RoadRacer19 New Member
    2016 Tundra TRD Pro CrewMax
    -Magnum RT running boards -Revolver X2 cover
    So, I have the Revolver X2, but want to install the TracRac. I was told that this was not possible by a local Rack shop. I’m glad to see you have done this. How do you go about mounting the TracRac system w/ the Revolver installed?
    Toyotoholic[QUOTED] likes this.
  17. Feb 3, 2019 at 12:06 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    It is really straight forward. I don't understand why a shop would not know. When installing the Trac rails I used a flush router with a bearing to open the stake holes in the bed for the expansion blocks of the Trac rails to fit into. (This is if you have the newer one-piece rail covers that doesn't have the removable plugs). Drill a 1/2" hole right in the center of the fake knock out, then router it out to just the size of the metal underneath it. This way the hole in the plastic is not huge and you would see it from under the Trac rail.
    As far as the X2, it is not ever close to interfering with the rails... Doesn't touch at any point.
  18. Feb 3, 2019 at 1:45 PM
    RoadRacer19
    Agreed, which is why I started researching. Thanks so much for the feedback. Cheers
  19. Feb 12, 2019 at 6:58 AM
    #49
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Just to update my situation with my X2 that was starting to split. I contacted Bak warranty department who was very nice and informative. They requested my proof of purchase and pictures of the cover and to confirm my current shipping address. 1 days time and they email back stating they are sending me a replacement. Glad to see a company stand behind there product, well done!
    jmdaniel likes this.
  20. Feb 12, 2019 at 7:18 AM
    #50
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
  21. Mar 2, 2019 at 9:05 AM
    #51
    RoadRacer19
    Thanks for the guidance. I had the Thule rack installed + works great w/ my Revolver X2
  22. Mar 2, 2019 at 10:39 AM
    #52
    KenSeltzer
    KenSeltzer New Member
    My dad got one for his ram 1500 and it's been great for him. I'm going to get one for my tundra. Do you guys have any problems with yetis fitting underneath of it when closed?
  23. Mar 2, 2019 at 10:52 AM
    #53
    Njmike13
    2021 PRO Lunar Rock
    I have a yeti 65 and it fits fine underneath.
    KenSeltzer[QUOTED] likes this.
  24. Mar 2, 2019 at 11:12 AM
    #54
    RoadRacer19
  25. Mar 2, 2019 at 11:32 AM
    #55
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Very nice!
  26. Mar 7, 2019 at 6:49 AM
    #56
    B737
    Jersey Shore
  27. Mar 7, 2019 at 6:57 AM
    #57
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  28. Mar 7, 2019 at 3:47 PM
    #58
    KenSeltzer
    Just put it on today. Wont have to worry about it freezing and not opening. I live in Wilmington, DE. My dad lives in southeastern PA and have never had a problem with his on his ram. I could understand why they don’t work in below zero weather. But hell, I wouldn’t want to work in below zero weather.
    georgiey22 and jmdaniel like this.
  29. Mar 8, 2019 at 8:12 AM
    #59
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Same here; if it freezes in Central Texas, I'm not driving anyway.
  30. Mar 8, 2019 at 9:38 AM
    #60
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    I have the Revolver X4 with the BakBox. I do not reccomend the Bak Box:
    Construction is a bit "chincy"
    The Crewmax bed depth is already challedged at 5.5", the Bakbox takes more
    Bakbox folds out of the way, but it still takes up ~6" of depth and you have to remove everything in the box in order to get it to fold
    You have to lean over the bed or hop up into it to use it
    Personally for me, I wish I had gotten the Swing case. Doesn't take bed depth, you can easily get at it from the tailgate.
