Baja Designs Fog Lights Not Working
Discussion in 'Lighting' started by Hanzo, Mar 24, 2022.
  1. Mar 24, 2022 at 3:18 PM
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    I'm assuming there is no connector on the wires coming from the fogs then. If you haven't done so, I would verify the lights actually work by getting them connected to a 12V source. If you have a lawn mower battery around you could use that without having to remove the fogs. Otherwise I would just remove the fogs and touch the corresponding leads to your terminals. You could also run wire to jump the fogs to the battery but that may be more work than removing them.
    If your factory fogs worked and the BD SAEs check out okay, you should theoretically be fine. Silly question, but did you disconnect the battery when you unplugged the factory fogs and installed the new ones? I hear that has the potential to open up a can of worms.
    The fogs turn off when brights are engaged, FYI.
    joseph_womack likes this.
  2. Mar 24, 2022 at 3:20 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    U can just use a 9V battery.
  3. Mar 24, 2022 at 3:24 PM
    Hanzo
    Hanzo [OP] New Member
    My truck didn’t originally come with fogs but I did disconnect the battery for install.
  4. Mar 24, 2022 at 3:29 PM
    Hanzo
    Just did this and the lights are good! Now to work my way back to the switch.
    joseph_womack and TunsofFon like this.
  5. Mar 24, 2022 at 3:34 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Nice. Let us know what you find out.
  6. Mar 24, 2022 at 3:35 PM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    :yes: You got this.
  7. Mar 24, 2022 at 3:36 PM
    Hanzo
    Will do. I’m thinking my relay terminals might need to be cleaned. My trucks an 07 and that terminals just been empty the whole time.
  8. Mar 25, 2022 at 7:08 AM
    Hanzo
    Pinched my sciatic nerve this morning so going to have to wait on metering everything
  9. Mar 27, 2022 at 5:10 PM
    Hanzo
    So we found out the relay is not grounding. Everything else seems to be in order. Any ideas on where to find this wire?
  10. Mar 28, 2022 at 1:09 PM
    Hanzo
    So today I tried to do the “Eddie Fog Light Mod” to see if that could circumvent the grounding issue I had with the grey wire. The “Eddie Mod” takes the grey wire and connects to a pink wire running from the J3 connector in the main body ECU. This mod let’s you have your fog lights on with your brights as well, so I thought I could kill two birds with one stone.
    Cut to 15 minutes ago and I find out I don’t have a pink wire in the J3 connector.
    Any suggestions would be really appreciated at this point.
  11. Mar 28, 2022 at 1:13 PM
    Hanzo
    Photo of J3 connector
  12. Mar 28, 2022 at 1:13 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Make your own wire?
    des2mtn likes this.
  13. Mar 28, 2022 at 1:16 PM
    Hanzo
    What does that pink wire do?
  14. Mar 28, 2022 at 3:14 PM
    Hanzo
    So I grounded the grey wire from AJ10 to the ground point in the footwell and success!!!
  15. Mar 28, 2022 at 3:15 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Just realized I posted the pink wire response meant for you in the other thread, sorry lol
    Hanzo[QUOTED][OP] likes this.
  16. Mar 28, 2022 at 6:03 PM
    Hanzo
    We’ll now I can’t turn them off separate from my headlights…
  17. Mar 28, 2022 at 6:53 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Sounds like a ground activated circuit
  18. Mar 29, 2022 at 7:28 AM
    Hanzo
    Looks like my truck was wired for the fog light assembly but not for the switch. My game plan is to pin a wire into the stalk connector (J10 - pin 4) and connect to the grey wire.
    Does anyone know what kind of pin I need for this?
    joseph_womack and 14burrito like this.
  19. Mar 30, 2022 at 6:41 AM
    #49
    Hanzo
    I was able to call the local Toyota parts department and get a terminal repair kit for the fog light switch. Should be in next week and I can finish the wiring. I’ll let everyone know how it turns out.
    14burrito and joseph_womack like this.
  20. Mar 30, 2022 at 7:13 PM
    #50
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    did you get a part number for that? I'll be adding cruise control to my truck and I need to pin out a connector
  21. Mar 31, 2022 at 7:54 AM
    #51
    Hanzo
  22. Mar 31, 2022 at 9:44 AM
    #52
    joseph_womack
    Joe
    Louisiana
  23. Apr 9, 2022 at 6:11 AM
    #53
    Hanzo
    So I pinned into the connector and no joy…any thoughts?
  24. Apr 10, 2022 at 12:25 PM
    #54
    joseph_womack
    Joe
    Louisiana
    You still talking about the fog lights or now the cruise control?
  25. Apr 10, 2022 at 1:55 PM
    #55
    Hanzo
    Cruise is running great, I just can turn my fog lights off.
    Baja Designs likes this.
  26. Apr 12, 2022 at 10:03 AM
    #56
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Hello Hanzo,
    I just caught up on this thread, are you still having issues with the lights. What adaptor are you using and what wiring harness are you using. It sounds like the light is getting constant power or a backfeed in the line.
    Let me know if you are still having issues and I can help trouble shoot with you or point you in the right direction.
    Best,
    Brock Brunkhorst
  27. Apr 12, 2022 at 10:04 AM
    #57
    Baja Designs
    Bill
    San Marcos, CA
    Also did your light come with factory fog lights and if so are you wired in to that harness.
