Baja Designs 22+ Toyota Tundra Vent Kits
Discussion in '3rd Gen Tundras (2022+)' started by Baja Designs, Jan 6, 2023.
  1. Jan 6, 2023 at 9:58 AM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Baja Designs Toyota Tundra Vent Lighting Kits
    Baja Designs is proud to introduce our newly developed 3rd Generation Toyota Tundra Vent Lighting kits. At Baja Designs, we strive to innovate lighting options and mounting locations that go above and beyond. This lighting kit features two versions, Our triple S1 option, or our dual Squadron setup in the factory grill vent locations. This Lighting option will feature full vertical and horizontal adjustability to optimize your lighting output.
    Baja Designs Dual Squadron Vent Kit
    The dual Squadron setup will be available in 3 variants depending on the package and lighting output you seek. The photos below feature a Squadron Pro/ Squadron Sport per side allowing you to toggle between the two lights when needed.
    mpzUemzBS2TvABvIK6eXEFCnb1Eq_40UD65Q4K-W_4431791edcd0db3b8c6bd2647218692de0da2b95.jpg
    og5uq-TChXem8hogVD0ShS8SQ2rAH5sT3SxMWl8x_c2bffad019b28e892fb6674aeee403224040fe62.jpg
    Baja Designs Triple S1 Vent Kit
    The triple S1 kit will feature 3 S1 pushing out 2320 lumens per light or a whopping total of 13,920 lumens. This lighting kit will offer full horizontal and vertical adjustability giving you the option to aim these lights where desired.
    JuR0SUSZixX4XTKpNjd5biR5i7yPUPwHgNxtA_U5_905cdbd2df7ecf98ac98d3268fd13b641903298f.jpgZRVjGigmspWGBkxYa2yXPYOK5Tr190wtRg7cQFqL_39aded15314a5064c6b8cf6f76f3413de400d3cf.jpg
    All kits will have great accessibility for any lens changes or possible Rock Guard additions featuring our lighting Uservice
    Keep an eye out for these hitting the market in the future as well as more details to be released.
    For more information on our products or additional Tundra lighting kits visit the links below.
    https://www.bajadesigns.com/uservice/
    https://www.bajadesigns.com/vehicle-hub-lp/toyota-tundra-22-on-lighting-kits/?page=1&vid=159031
    kstateskier, xwarcat, AND and 6 others like this.
  2. Jan 6, 2023 at 10:02 AM
    Taco-Spike
    Two Trucks
    That's pretty badass
    1lowlife and Baja Designs[OP] like this.
  3. Jan 6, 2023 at 10:10 AM
    Baja Designs
    Bill
    San Marcos, CA
    Thanks @Taco-Spike, Our engineers definitely nailed it on this kit. This is just a pre-released teaser so some details and bracket fitment are possible to change.
    Best,
    Brandon
    Taco-Spike[QUOTED] likes this.
  4. Jan 6, 2023 at 10:24 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Don’t own the newest Gen but that triple S1 is really sweet!
  5. Jan 6, 2023 at 3:04 PM
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    Wow! I like! I will be watching for release =)
    Taco-Spike and Baja Designs[OP] like this.
  6. Jan 6, 2023 at 3:22 PM
    Duke_962
    Duke_962 New Member
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    How hard is it to get a high beam output signal to set these up as on/off/auto high beam configuration? Has anyone done this yet or dabbled in it? Kit looks awesome even if manually switched.
    Baja Designs[OP] likes this.
  7. Jan 6, 2023 at 3:29 PM
    AND
    AND New Member
    Washington, PNW
    Thats exactly what i was thinking.
    I too would like to wire it like that.
    TK1979 and Baja Designs[OP] like this.
  8. Jan 6, 2023 at 3:31 PM
    Baja Designs
    Bill
    San Marcos, CA
    Great questions, this is why we tease it before the final release. I will run this by our engineering team and see what they think regarding doing a High Beam tap in. @AND @Duke_962
    Best,
    Brandon
  9. Jan 6, 2023 at 5:28 PM
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    That's always easy. I have 3 squadron pairs on a raptor and all 3 have different switches. No problem.
    bulldog93 and Eurodriver[QUOTED] like this.
  10. Jan 6, 2023 at 6:14 PM
    Skidmarcx
    Skidmarcx New Member
    Glendale, AZ
    ‘22 SR5 CM
    I’m so glad I didn’t sell the squadrons from my Raptor yet! Hell yea! Now I need you to make brackets for double squadrons and S1 per side :)
  11. Jan 6, 2023 at 7:33 PM
    SecrITSociety
    SecrITSociety New Member
    Orlando, FL
    2023 Platinum Tundra / Blueprint / 4x4
    Share a closeup of the triple S1's and I might be in
  12. Jan 7, 2023 at 4:42 AM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    Definitely cool
  13. Jan 7, 2023 at 4:58 AM
    HooahMP12
    HooahMP12 New Member
    Justin
    2022 Tundra
    Oh wow, following!
  14. Jan 7, 2023 at 2:52 PM
    Duke_962
    Duke_962 New Member
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    Premium LEDHeadlight trucks or standard led headlight trucks it will be a can signal so if someone can make a module and show the wire intercept to get the trigger is all we need. I’m a buyer pending the info
    To
    Get the signal to grab.
  15. Jan 7, 2023 at 2:57 PM
    99ways2die
    99ways2die New Member
    Duke_962[QUOTED] and ryanwgregg like this.
  16. Jan 7, 2023 at 3:11 PM
    Duke_962
    Duke_962 New Member
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    Ok thanks I’ll go to the wiring diagram and test for signal then add these bad boys into it. Thanks and let’s see where this goes
  17. Jan 7, 2023 at 3:41 PM
    AND
    AND New Member
    Washington, PNW
  18. Jan 7, 2023 at 7:52 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Any info available on how much air flow interruption to the intercooler radiators those lights will cause?
    Reducing the cubic feet of air per minute to those rads seems like a poor idea.
  19. Jan 7, 2023 at 8:02 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    From my understanding and having the grill off those vents don’t direct flow into anything, the intercooler doesn’t even touch them- the scoops go into the massive grill
  20. Jan 7, 2023 at 9:37 PM
    Bbgunasassin
    Bbgunasassin New Member
    23 Tundra Limited Hybrid Trd Offroad LR
    295/65 r20 Icon Stage 7
    MateoAirborne likes this.
  21. Jan 8, 2023 at 6:37 AM
    Bbgunasassin
    ryanwgregg likes this.
  22. Jan 8, 2023 at 8:33 AM
    AND
    AND New Member
    Washington, PNW
    So basically, on a non premium headlights, you can tap into the 12volt HIbeam the old school way?
    Im confused as to why the person in the post did all that work :facepalm:
  23. Jan 8, 2023 at 8:45 AM
    AND
    AND New Member
    Washington, PNW
    Vent (in red) does not go to intercooler rads (in blue)
    Picture from another member
    @RaTBate hope you dont mind
  24. Jan 9, 2023 at 8:20 AM
    Baja Designs
    Bill
    San Marcos, CA
    From what we have collected from developing the kit, those vents don't have a direct flow to the intercooler. The difference in airflow will be limited to none after installing this kit @Coal Dragger.
    Best,
    Brandon
  25. Jan 10, 2023 at 1:26 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    Awesome! Are they DoT legal?
  26. Jan 10, 2023 at 7:59 AM
    nodak67
    nodak67 New Member
    JR
    if you look at how the IC plastic housing box is angled towards the vent, i would suspect that vent feeds the IC
  27. Jan 10, 2023 at 8:45 AM
    T315
    T315 New Member
    2022 Tundra Crewmax TRD Offroad
    I'm sure these are for off-road use, not to light up the road while you're driving.
  28. Jan 10, 2023 at 9:50 AM
    Baja Designs
    Bill
    San Marcos, CA
    The version seen in the post is not DOT-legal. There will be a version of the dual Squadrons that will feature our new Squadron SAE in on of the locations @Bourbonator.
    Best,
    Brandon
  29. Feb 13, 2023 at 4:19 PM
    AND
    AND New Member
    Washington, PNW
  30. Feb 13, 2023 at 4:36 PM
    Baja Designs
    Bill
    San Marcos, CA
    It is still in development. We are working out some kinks with the hardware but it will be released very soon.
    Best,
    Brandon
    Skidmarcx and AND[QUOTED] like this.
