Autoloc OneTouch on all my windows, including rear Crewmax
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020Platinum, Sep 7, 2020.
  1. Sep 12, 2021 at 6:32 PM
    #91
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    Yeah the low version is if you have one touch down on just the drivers side and the high is if its on driver and passenger. The constant power just gives you the ability to open and close your windows with the remote.
    Shanet421 and shawn474[QUOTED] like this.
  2. Sep 12, 2021 at 6:34 PM
    #92
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Yeah my remote won’t work to roll the wi does down….it tries and just jerks for a second and stops. But it doesn’t matter to me. I have no need for that feature
  3. Sep 12, 2021 at 6:36 PM
    #93
    jhardy1979
    Justin
    Yeah I rarely use it to roll the windows down but its really handy when you get out of the truck and your windows are down and you lock it and the windows go up automatically.
  4. Sep 12, 2021 at 6:49 PM
    #94
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    This makes sense. All the videos I’ve seen says run power to battery for constant 12v. I’m thinking there has to be 12v constant inside the door somewhere?
    The autoloc video shows constant power in the 2020 platinum. Is there constant somewhere in the door panel on my 2013 SR5 I can tap?
  5. Sep 12, 2021 at 7:18 PM
    #95
    Shanet421
    San Diego,CA
    Follow up question on the 3wliner low mod. After install do the passenger windows go up/down with one touch from the passenger door switches?
  6. Sep 13, 2021 at 6:48 AM
    #96
    shawn474
    MoCo, Maryland
    no they do not. Only from driver side switches
  7. Sep 15, 2021 at 6:42 AM
    #97
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    For people that have installed the 3Wliners low module...do you have to run the constant 12volt power if you don't plan on using the remote feature?
  8. Sep 19, 2021 at 7:36 AM
    #98
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    I just installed mine yesterday. I tested it without the power wire connected. It didn’t work so I tapped a constant 12v wire going to my mirror control module which is mounted on the door behind the door panel also. All good after that.
    It was really simple and plug and play except for the power wire. The features are nice and it works seamlessly. My biggest issue was trying to find a good spot for the window control module. There isn’t a lot of space between the door and door panel.
  9. Sep 19, 2021 at 7:57 AM
    #99
    Shanet421
    San Diego,CA
    Please let us know if any issues arise with the constant tap. I’m going to be doing the same thing.
    jc153[QUOTED] likes this.
  10. Sep 19, 2021 at 10:12 AM
    #100
    jc153
    San Diego
    Yeah man, if any issues arise I’ll post in here.
    831Tun and Shanet421[QUOTED] like this.
  11. Sep 19, 2021 at 1:43 PM
    #101
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    While it will work.
    I would suggest running it directly to the battery as they suggest. Window motors pull a lot of power and you are running two motors at a time when you use the remote.
    It’s likely best it be it’s own circuit and not shared with anything else in the event there is an issue it won’t harm any other electronics.
    It is easy enough to run it directly to the battery.
    jc153[QUOTED] and Shanet421 like this.
  12. Sep 19, 2021 at 2:47 PM
    #102
    jc153
    San Diego
    You are correct but laziness has gotten the better of me. I may run a dedicated wire to the battery at a later date.
  13. Sep 25, 2021 at 7:19 AM
    #103
    redrum448
    redrum448 New Member
    Has anyone found a good power source for doing the rear window one? Id rather not run a wire all the way to the battery. Also in the video he runs a ground to the battery why cant we just ground it at a bolt near the back window somewhere?
  14. Sep 25, 2021 at 7:43 AM
    #104
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The ground can go to any local grounded bolt.
  15. Sep 25, 2021 at 1:33 PM
    #105
    Shanet421
    San Diego,CA
