Autoloc OneTouch on all my windows, including rear Crewmax
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020Platinum, Sep 7, 2020.
  1. Jun 15, 2021 at 9:16 AM
    #61
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    Yeah it looked like it would be pretty easy to add this module to get it working.
  2. Jun 15, 2021 at 9:20 AM
    #62
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    No you have to use the module they are talking about in here and cut wires. I chose not to do that. Not worth cutting up my harness to save me from holding down the switch IMHO
    Edit - for the non 3wl option if I saw the vid correctly, to do the rear you'd have to buy another unit just for the rear, even if you had one up front.
    jhardy1979[QUOTED] likes this.
  3. Jun 15, 2021 at 8:42 PM
    #63
    2020Platinum
    2020Platinum [OP] www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Thanks John!…I appreciate it!
    Bammer[QUOTED] likes this.
  4. Jun 16, 2021 at 2:26 AM
    #64
    HarrazH
    HarrazH New Member
    Hany
    2019 Platinum Tundra
    TRD Pro Intake TRD Pro exhaust system Tail gate lights and lock LEDs everywhere 295/55-R20
    Great video, thanks for sharing.
    Anyway I can make it work with the car remote? say when I lock the car with a long press it closes all windows?
    2020Platinum[OP] likes this.
  5. Jun 16, 2021 at 5:19 AM
    #65
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Buy the 3WLiners module. You get auto up down on all the windows except the CrewMax rear. You also get control up and down from the factory remote.
    https://www.3wliners.com/product/toyota-tundra-window-control-module-low/
    1 plug and play module no wire cutting or splicing.
    Best $95 I have spent on the truck hands down.
    The autolocs are nice and all but you have to install one for each window and splice wires. A whole lot more work and more money.
    I want to add the autoloc unit for my rear window but have a pretty strict no cutting splicing of the factory wires policy.
    I bought the harness to move my rear window switch to the other side of the steering wheel. Wondering if I can tap into that harness and mount the module under the dash instead of doing in the rear?
    1lowlife, WFD473, 1UP and 2 others like this.
  6. Jun 16, 2021 at 5:32 AM
    #66
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Did you have to run a wire to the battery? I'm still a little confused on the high , low units?
  7. Jun 16, 2021 at 6:39 AM
    #67
    jhardy1979
    Justin
    Yes you have to run a power wire to the battery in order for the remote function to work properly. Its really not bad to do though. The low unit is for truck with drivers side auto only. The high is if both driver and passenger side are auto.
  8. Jun 16, 2021 at 7:13 AM
    #68
    Bammer
    Monroe, CT
    Thank you
    Running the wire is something he fails to show in the video, which is probably a no brainer, but I would like to see before pulling the trigger.
  9. Jun 16, 2021 at 7:17 AM
    #69
    HarrazH
    HarrazH New Member
    Hany
    This is exactly what I was looking for, thank you.
  10. Jun 16, 2021 at 7:21 AM
    #70
    jhardy1979
    Justin
    You just have to run it back through the door into the truck and there is a grommet going through the firewall right there on the drivers side.
  11. Jun 16, 2021 at 7:26 AM
    #71
    HarrazH
    HarrazH New Member
    Hany
    New I checked their website and they have only the low, there is no high which I'm guessing is what I need based on your explanation.
    Where can I get the high option?
  12. Jun 16, 2021 at 7:29 AM
    #72
    jhardy1979
    Justin
    I guess maybe they are out of stock of the High version. When I ordered mine a few months ago they offered both.
  13. Jun 16, 2021 at 7:48 AM
    #73
    HarrazH
    HarrazH New Member
    Hany
    I sent them an email asking if it will be back in stock anytime soon!
    Thank you
  14. Jun 16, 2021 at 12:54 PM
    #74
    2020Platinum
    Patrick
    Northeast PA
    That was part of the problem when I did this, their “high” option was out of stock every time I checked and they had no clue when it would come back in…these modules are definitely a little more work, but it’s not hard at all…can do all 4 doors, and the rear window in an hour or so if ya are familiar with wiring….if not it’ll take a little longer but following my video it’s super easy…the 3w is definitely more convenient if ya can get your hands on it…let me know if I can help!
  15. Jun 17, 2021 at 2:09 AM
    #75
    HarrazH
    HarrazH New Member
    Hany
    Thank you for your help. The modules you put are gonna be a great addition if they can be linked to the remote control, are you aware of a way to do so? or any other solution?
  16. Jun 19, 2021 at 12:04 AM
    #76
    2020Platinum
    Patrick
    Northeast PA
    No problem!…if I’m not mistaken I’m almost positive there is a way to link them to a remote, but I chose not to do it…their website says it’s linkable to any remote and there are 2 wires I didn’t use (blue and grey if I remember correctly, I know I show them in video)…those 2 wires I believe are how you hook them up with remotes, but let me try to do a little more research and find out for ya
    HarrazH[QUOTED] likes this.
  17. Jun 20, 2021 at 3:25 AM
    #77
    HarrazH
    HarrazH New Member
    Hany
    Thanks a lot man, much appreciated.
    I have taken a look at the instructions and seems there is a way, but I"m not sure if this will work for the two front windows as they comes with Auto function already!! and if so, that will mean that I have to buy two more units just for the integration, right?
    Remote Operation
    In most cases it is possible to roll up or down your windows by remote if your vehicle is equipped with an alarm or keyless entry unit. If you don't have a keyless entry unit, or alarm please contact us at 800-873-4038. (NOTE see box to right if you already have anAutoLoc, or Stellar alarm/keyless entry unit.)
    1. Locate your alarm/keyless entry unit's trigger wires. This wire will send a negative "-" charge when you pushyour alarm/keyless entry unit's remote.
    2. REMOTE UP: Connect the alarm/keyless entry unit's negative trigger wire to the GREY wire.
    3. REMOTE DOWN: Connect the alarm/keyless entry unit's negative trigger wire to the WHITE/BLUE wire.
    Remote Hook UP
    If you have already installed an AutoLoc, or Stellar Alarm Keyless Entry unit then do the following for remote windows.Install the window control modules on each window.ROLL UPStellar/AutoLoc's remote unit's PURPLE/WHITE wire to the GREY wire on the BMW1T unit.ROLL DOWN
    • Connect the Stellar/AutoLoc's remote unit's PURPLE/WHITE wire to the WHITE/BLUE wire on the BMW1T unit
  18. Jun 24, 2021 at 6:31 PM
    #78
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I just installed the 3wliners model and it works like a charm. Have not tried the remote yet but will tomorrow
    HarrazH and jhardy1979 like this.
  19. Jun 25, 2021 at 10:06 PM
    #79
    HarrazH
    HarrazH New Member
    Hany
    I'm guessing you installed the Low version, does your car already have automatic window for driver only? Or both?
  20. Jun 25, 2021 at 11:51 PM
    #80
    shawn474
    MoCo, Maryland
    yes I installed the low version - my sr5 only had the drivers side atuto down switch. Now all are auto up and auto down
  21. Jun 26, 2021 at 6:03 AM
    #81
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    I installed the low version also, but it blows a fuse everytime I hit a switch. I don't think I nicked a wire but I'll have to see if maybe something got pinched.
  22. Jun 26, 2021 at 6:12 AM
    #82
    shawn474
    MoCo, Maryland
    make sure each harness is seated properly as well…..and that no pins got bent when you plugged it in. Mine took a pretty good amount of force to “click” into place
    Djone27[QUOTED] likes this.
  23. Sep 12, 2021 at 11:55 AM
    #83
    FrozenTundra920
    FrozenTundra920 New Member
    Jose
    Wisconsin
    2018 SR5 TRD off-road Calvary blue
    X remote start, Interior LED Conversion, syeticusa retrac tonneau cover, Exterior Chrome delete, Clazzio seat covers/heated seats, tailgate lightbar, ditch lights, raptor lights, pop&lock tailgate harness, wireless charger.
    For those of you who ordered the 3wliner “low” module,
    how long did it take to receive it after placing your order?
    also for those of you who have installed it have you had any issues after a few months of use? Still recommend?
  24. Sep 12, 2021 at 11:56 AM
    #84
    shawn474
    MoCo, Maryland
    I very much recommend it; love mine and use it everyday especially with the fall weather approaching
    biebs96 likes this.
  25. Sep 12, 2021 at 12:15 PM
    #85
    biebs96
    PA
    do the other doors also now have auto up and down? or is it solely from the drivers seat?
  26. Sep 12, 2021 at 12:26 PM
    #86
    shawn474
    MoCo, Maryland
    All doors (NOT rear window)
  27. Sep 12, 2021 at 12:37 PM
    #87
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Can the 12v constant be tapped somewhere inside the door panel to avoid running all the way back to the battery?
  28. Sep 12, 2021 at 12:59 PM
    #88
    shawn474
    MoCo, Maryland
    The 3wliners module is plug and play; no need to run anything to battery
    Shanet421 likes this.
  29. Sep 12, 2021 at 6:19 PM
    #89
    jhardy1979
    Justin
    You do have to run a power wire to the battery but its really easy.
  30. Sep 12, 2021 at 6:28 PM
    #90
    shawn474
    MoCo, Maryland
    Oh my bad - I have the “low” version - but I will be damned if I didn’t remember that I had to run a power wire
