Autoloc OneTouch on all my windows, including rear Crewmax
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020Platinum, Sep 7, 2020.
  1. Sep 9, 2020 at 11:12 AM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    Does this module let you pause the up/down in the middle somewhere, or is it only all the way up/all the way down?
  2. Sep 9, 2020 at 11:18 AM
    2020Platinum
    2020Platinum [OP] www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    You can pause at any spot, just hit button again and it stops immediately!
    xJuice[QUOTED] likes this.
  3. Sep 9, 2020 at 11:56 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    So it sounds like these modules function exactly like OEM then. :thumbsup:
    My 2018 Tacoma TRD OR worked exactly like this also... and I sure miss it.
  4. Sep 9, 2020 at 2:27 PM
    2020Platinum
    Patrick
    Northeast PA
    Yes sir, you can stop these at any point just by hitting button a second time...they’ll stop right where they are
    Dragracer_Art[QUOTED] likes this.
  5. Sep 9, 2020 at 2:51 PM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    Do you know how it works with the two stage window switches? Like if I wanted to add this to a switch that has auto down, but not up, would the two stages of down behave differently or the same?
  6. Sep 9, 2020 at 3:18 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Instead of mounting the AutoLoc in the back for the rear window, do you think it would still be able to be installed at the switch in the dash instead? That way, you don’t have to run lengths of wiring and it’s all in one place
    2020Platinum[OP] and JayLo707 like this.
  7. Sep 9, 2020 at 3:22 PM
    JayLo707
    JayLo707 New Member
    Jayson
    2016 Tundra CM 4x4 Platinum
    TRD dual exhaust, wireless charger in center console
    Pretty cool.. thanks for the vid! I might look into adding one to my wifes passenger side door of her Subie. Both my tundra and audi have the driver and passenger side 1 touch..it bothers me when my wife holds the button up the entire time when all she has to do is flick it up and let it go..lol
    2020Platinum[OP] likes this.
  8. Sep 9, 2020 at 8:19 PM
    2020Platinum
    Patrick
    Northeast PA
    Hmm, that’s a good question...I’m honestly not sure, I’d have to test it out but I’m thinking that if you already have auto down, you may just have to hook up the “up wires” from the module...along with power and ground of course...I can’t confirm this since I’ve never done it, but it makes sense
  9. Sep 9, 2020 at 8:21 PM
    2020Platinum
    Patrick
    Northeast PA
    Yea absolutely, I don’t see why not!...it would be same as door switches so I don’t see why it wouldn’t work, not a bad idea!
  10. Sep 9, 2020 at 8:22 PM
    2020Platinum
    Patrick
    Northeast PA
    Thanks for watching!...and yea I hear ya, sounds stupid but I can’t stand holding the button in...lol...I know it’s ridiculous and minor but I love this one touch feature on all windows!
    JayLo707[QUOTED] likes this.
  11. Sep 12, 2020 at 9:30 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I did this on my 2014 SR5 that had driver only auto down. I hooked both ways up. It kinda bypasses the 2 stage of the switch. Auto down with a momentary press, and auto down with a complete press to the click. I would say like OP said , if you only hooked up the up wires, it may work different. But you may also need diodes or something because the window motor wires just flip flop polarity to reverse direction. At least in my 2014.
  12. Sep 12, 2020 at 9:33 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Back when I did this to my 2014, I believe there is an actual factory module in each door and the switches are 2 stage low current. Meaning they only tell the module what to do. Where as the standard switches are high current. Meaning the power goes through the switch.
  13. Oct 3, 2020 at 5:22 AM
    biebs96
    PA
    Anyone know what wires to snip for the rear window on a 2017?
  14. Oct 3, 2020 at 10:07 PM
    2020Platinum
    Patrick
    Northeast PA
    Not 100% sure, but should be the same...the wires should be in the same spot at least, let me know how ya make out
    biebs96[QUOTED] likes this.
  15. Oct 30, 2020 at 10:06 AM
    I just discovered that you lose the window lock feature once you add these. Keep that in mind if you have little ones that play with the windows.
  16. Oct 30, 2020 at 11:11 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Good to know. Thank you.
  17. Oct 30, 2020 at 11:54 AM
    I sent an email to Autoloc. I will advise once I hear back from them.
    2020Platinum[OP] and WFD473 like this.
  18. Oct 30, 2020 at 9:26 PM
    2020Platinum
    Patrick
    Northeast PA
    Thanks for the info!...maybe I’ll make an update video for the channel (giving you credit of course...lol), I didn’t realize that at all...that’s a pretty popular video on the channel and I like to give my viewers as much info as possible, I wonder if there’s a way around that
  19. Oct 30, 2020 at 10:23 PM
    #49
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Thanks to @Wynnded for showing me how to easily post pages from my wiring diagram..
  20. Oct 31, 2020 at 2:05 AM
    #50
    biebs96
    PA
    saving this!
  21. Oct 31, 2020 at 6:02 AM
    #51
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    On your DC + and - to the battery I'm hoping you fused the + lead at the battery. I would have just moved the fuse for the module near the battery.
  22. Nov 14, 2020 at 8:15 AM
    #52
    SDNY
    SDNY New Member
    Castleton NY
    2024 Sequoia Sonic Red
    Did some troubleshooting today on the rear door windows. Trying to figure out the window lock feature. My best guess is that the switch housing has a relay in it because another wire gets 12v when window lock is on. Hope this makes sense. I don't see a way to bypass to keep the window lock switch working. Hopefully someone smarter than me can figure it out.
  23. Nov 14, 2020 at 10:49 AM
    #53
    2020Platinum
    Patrick
    Northeast PA
    If I get some time and can stop doing other projects I’m gonna dive into this and see if I can figure it out...where there’s a will there’s a way...haha
  24. Nov 14, 2020 at 3:21 PM
    #54
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    Did not work for me. I have one unit for sale if anyone needs it
  25. May 29, 2021 at 10:39 AM
    #55
    SDNY
    SDNY New Member
    Castleton NY
    I finally fished my autoloc install. Attached is the wiring color code for 19 Tundra Crew Max. Please put it where members can find it easily. Thanks for the video on this, it was very helpful.
    TucsonTundra1794 likes this.
  26. May 29, 2021 at 3:36 PM
    #56
    BlancaLaGordita
    BlancaLaGordita New Member
    Blanca
    2021 Tundra TRD Sport
    this is crazy !! this is the reason why I have not bothered to go thru all the work of posting any mods I have done. the time it takes to film, make sure the camera has a good angle, sound, light, edit, post and plus make a step by step write up even though all the steps and all the details are on the video. all that work and all the effort this guy put on making this information available to us and 99% of you all busting his balls because he didnt spoon feed you the damn link to the product itself? so what if he gets something from the views or the clicks on his links? then go figure all this shit out on your own. crazy !! @2020Platinum good job and thanks for the info since everyone is too busy bitching about you not posting the link to even thank you. thank you. over 30 posts and only two people bothered to say "thank you" sad.
  27. May 29, 2021 at 3:49 PM
    #57
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    :monocle: little confused about who's complaining and needs to be spoon fed. Maybe I missed a post? Personally I like and installed the 3lw module instead of hacking up my wires for this option. But it was the OPs video that helped me decide this was not the mod for me. Very grateful for that.
    Regardless of opinions, I don't think anyone is being negative to the OP. He is on here a lot sharing knowledge and tutorials.
  28. Jun 15, 2021 at 8:21 AM
    #58
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    I also installed the 3lw module but I am looking for a way to make my rear window auto. Did you do anything for yours?
  29. Jun 15, 2021 at 8:39 AM
    #59
    2020Platinum
    Patrick
    Northeast PA
    Super easy to do rear window on the Crewmax using one of the modules in my video, literally a 20 minute job, if that…lemme know if ya need any help!
    jhardy1979[QUOTED] likes this.
  30. Jun 15, 2021 at 8:50 AM
    #60
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Well done yet again Patrick !
