Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Feb 13, 2021 at 12:11 PM
    #2071
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    On the back lower driver's side of the engine block, best accessed from the underside of the vehicle. A quarter dollar sized hole should be visible that looks just like the female version of the male shaped heating element. I would've thought a small pamphlet was included to assist, but who knows. Don't forget the heat transfering paste that should also be included.
    Funny how this is way too similar to the talk sometimes awkwardly given to pubescent offspring.
  2. Feb 13, 2021 at 12:23 PM
    #2072
    Pern
    Pern New Member
    Tundra 2017
    Thanks so much! LOL. I found it, I don’t think I will ever get my arm in there though.
    Wynnded[QUOTED] likes this.
  3. Feb 13, 2021 at 12:42 PM
    #2073
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Borrow a kid! :p
  4. Feb 13, 2021 at 12:50 PM
    #2074
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Some access can be had through the drivers side wheel well.
    NewImprovedRon and Wynnded like this.
  5. Feb 16, 2021 at 2:02 PM
    #2075
    Pern
    Pern New Member
    Tundra 2017
    I got it installed, is it ok to leave these operating all night every night, or is a timer recommended?
  6. Feb 16, 2021 at 2:25 PM
    #2076
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    They're about 400W, so if you're willing to pay for the electricity, I can't envision that there's any harm that could come of it. We leave our medium duty commercial vehicles plugged in for weeks at a time without running them, but they're frost plug heaters. If you have a timer, I would say an hour or two should do the trick.
    I don't really drive that much, so I just dash out an hour or two before I think I need to go somewhere and plug mine in.
    NewImprovedRon and Ruggybuggy like this.
  7. Feb 23, 2021 at 3:20 PM
    #2077
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Finally got my Falcons so going to assemble them. So bringing up a little bit of an old post.
    On my truck the bottom pig tails on both sides of the truck point to the drivers side and not the rear.
    The fella that posted a little bit after you shows his coils and his pigtails appear both to point at the drivers side as well and not the rear.
  8. Feb 23, 2021 at 4:41 PM
    #2078
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Every Tundra that I've ever work on has the coil end facing rearward from the factory. Yes it is possible to get them switch from left to right.
    Wynnded likes this.
  9. Feb 23, 2021 at 5:12 PM
    #2079
    Black
    Interesting. I watched the Falcon install video and it is hard to tell and they only do the driver’s side but looks like their pigtail faces to the drivers side as well.
    Does the pigtail orientation really matter?
  10. Feb 23, 2021 at 6:37 PM
    #2080
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's the million dollar question. As a tech you put it back exactly as you found it. It's also a way to make sure the left and right sides don't get mixed up. The front springs have a different spring rate because of more weight on the left side (driver and fuel tank).
  11. Feb 23, 2021 at 8:14 PM
    #2081
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    So the owners who have commented that their trucks lean, should check their pigtails?:angrygirl:
    Ruggybuggy[QUOTED] likes this.
  12. Mar 11, 2021 at 11:50 AM
    #2082
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    How hard is it to access the 2019 Tundra blend door actuator? Does the whole dash have to com apart and can you access it to the right of the steering wheel near the gas pedal?
  13. Mar 11, 2021 at 11:59 AM
    #2083
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I believe the dash has to come out. What's wrong with the blend door?
  14. Mar 11, 2021 at 1:27 PM
    #2084
    Ronin73
    Ronin73 New Member
    Heat and air works perfectly, but when I change the selectors, there is an audible loud, moan or whine. I have had it happening for a year. I took it in when I was under warranty and they said the if it got worse to bring it back. If it was out of warranty and that happened the it was documented so they would cover it. It has gotten worse (does it more often) and I have an appointment next week. I'm just worried if they have to tear into the dash, it will never be the same and will rattle! Lol.
  15. Mar 11, 2021 at 2:05 PM
    #2085
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The dash comes out fairly easily. I'm sure it will go in find. I've never done one personally on a Tundra but a buddy tech of mine does them and its about a days work. He had to do a few leaking AC evaporators.
    Ronin73[QUOTED] likes this.
  16. Mar 11, 2021 at 5:30 PM
    #2086
    Ronin73
    Ronin73 New Member
    Since this just makes an annoying sound, that doesn't mean it is going to out out and make me lose heat and/or air? If it is just noisy, I can live with it if that doesn't mean it is going bad. My heat and air work just fine. What are the odds?
  17. Mar 11, 2021 at 5:51 PM
    #2087
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Toyota is paying for it so I would let them do it. I pretty sure they service the whole air box, just not the actuator door. If it fails it's going to be a huge bill. Why risk it? Even if it doesn't fail before you sell it, it's going to effect your resale value. Would you by a truck that made a noise in the heater box?
  18. Mar 12, 2021 at 10:40 AM
    #2088
    Ronin73
    Ronin73 New Member
    Yes. Service manager verified they would cover the repairs today even though I am out of warranty because I had it documented. He also made me feel better by saying that they have done this several times and I won't even notice they had the dash out. Said it will take three days once all approvals have gone through and they get the part in. And they are going to put me in a loaner. So, I'm happy. Thanks for the advice!
  19. Mar 12, 2021 at 12:17 PM
    #2089
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Nice!
  20. Mar 12, 2021 at 12:33 PM
    #2090
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Do you have a link to this^^. I’ve been noticing the extended cranks on my 2020 and then after the restart it’s fine...thanks.
  21. Mar 12, 2021 at 4:03 PM
    #2091
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Sorry there's no link. Just what I noticed in the shop. You should still be under warranty?
    Oey12[QUOTED] likes this.
  22. Mar 12, 2021 at 4:06 PM
    #2092
    Oey12
    Oey12 New Member
    Joey
    New York
    I am going in for the side marker recall and my first free oil change next month. I was going to let them know about the long cranking. Fortunately I am at 5k miles. Thanks anyway...
  23. Mar 12, 2021 at 4:26 PM
    #2093
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I remember one coming into the shop a few times for the extended crank. It was found after "T"ing in a fuel pressure gauge and watching how long it took the fuel pressure to bleed off. It didn't meet the spec so the pump was replaced and the problem was gone. The anti drain back valve was the issue and is part of the pump assembly.
  24. Mar 23, 2021 at 8:12 PM
    #2094
    Kung
    KG, VA
    Anyone know what that trim piece immediately behind the windshield is called? Mine is rattling some after having a part replaced for my HVAC system; and I'd like to know if it's just easier for me to pull it out myself and put some dampening material in there.
  25. Mar 23, 2021 at 8:20 PM
    #2095
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I wouldn't mess with it. Your under warranty. If you play with it and can't repair it yourself they may deny you warranty and blame you as the cause.
  26. Mar 24, 2021 at 5:34 AM
    #2096
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    This x1000. As long as my truck is in warranty ('til May 2028 or 120k miles), I will use the dealer to diagnose and repair any issues I have. I am also being careful to ensure that I can easily remove my mods from the system so they are not used as an excuse to not cover an issue under warranty.
  27. Mar 24, 2021 at 6:40 AM
    #2097
    Kung
    KG, VA
    Good point; I’ll make an appointment to have them look at it and state this in case I get any pushback.
  28. Mar 24, 2021 at 6:41 AM
    #2098
    Kung
    KG, VA
    Well, I do know my dealership isn’t that bad. I’ve got a custom sound system; and yet they could have cared less about that when they replaced the HVAC damper or whatever it was.
    But still - good point.
  29. Mar 24, 2021 at 8:15 AM
    #2099
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    And remember that warranty coverage for, say, a suspension issue will not be affected in any way by a custom sound system. The example I was thinking of for my truck is my FRAC harness front camera setup. If my head unit starts having major issues, I will remove that harness and put everything back to stock before I take it in for a warranty evaluation.
  30. Mar 24, 2021 at 9:13 AM
    #2100
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
