  1. Jan 12, 2021 at 8:29 AM
    ADV4R
    ADV4R New Member
    Kevin
    2021 MGM Tundra TRD OR
    Transmission cooler on a '21. Temps pushed passed 255... I'd like to keep this truck for awhile. PXL_20210108_185952823.jpg
  2. Jan 12, 2021 at 8:39 AM
    Doccountry69
    Doccountry69 New Member
    Mark
    Little Elm
    2020 Tundra Voodoo Blue
    Would that do anything as far as voiding the warranty?
    ADV4R[QUOTED] likes this.
  3. Jan 12, 2021 at 8:55 AM
    French Avocado
    Utah / Wyo
    The addition of a part to your truck does not void the warranty. The Magnusson-Moss Act (federal law) permits you to use non-manufacturer parts without invalidating your warranty. However, IF the manufacturer can prove that the non-manufacturer part caused the malfunction then it is not required to honor the warranty. For example, you install a lift kit and your radio fails. Your warranty on the radio has nothing to do with the lift kit and the manufacturer must honor its radio warranty. If you install a lift kit and the tie rod fails AND the manufacturer can prove that the lift kit caused the tie rod failure then it need not honor the warranty.
    Practical reality - If you have your dealer do the install and there is a failure then the manufacturer looks to the dealer to decide whether to honor the warranty and the dealer will most likely say it did not do faulty work and tell the manufacturer to honor the warranty.
  4. Jan 12, 2021 at 10:05 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Were is your antenna
  5. Jan 12, 2021 at 10:09 AM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    Black blade above the rear brakelight should be his antenna.
    RainMan_PNW, GianLaGatta and heyacker like this.
  6. Jan 12, 2021 at 10:10 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Did you do that yourself or have the dealer do it? If you did it yourself which kit was it?
    I'm about to start hauling a trailer around and this is on my 'to do' list. Which grows and grows as I want more and more stuff.
    Astom22 likes this.
  7. Jan 12, 2021 at 10:43 AM
    itstorbs
    itstorbs New Member
    Jack
    Fort Bragg
    2021 SR5 Trail
    My steering wheel control issue was corrected by the dealership today. Symptoms were intermittent control responsiveness. Turning the wheel either direction was what caused it to go in and out. Took them 4 days to get the assembly, and about 1 hour to install it. Covered under warranty.
  8. Jan 12, 2021 at 10:44 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Luckily simple fix and all. Hope it doesn't come back or anything. good to hear
    itstorbs[QUOTED] likes this.
  9. Jan 12, 2021 at 10:57 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks for the update!
  10. Jan 12, 2021 at 11:13 AM
    Cthulhu
    I’ve grown increasingly patient as the years have flown by, but still struggled with waiting on that guy’s 3D printer to get operational again. Plus, I’m not big on having a bunch of lighted switches all over the place (different strokes for different folks); I get enough ambient light from my Android HU! So, I built my own switch panel. The switch on the left goes to my (4) front LED bars, the switch on the right goes to my rear LED bar. The switch in the middle...you get it. Yes, so much easier to use these switches in this location vs. my hidden ledge location for the LED switches and the factory location for the rear window switch. Allen bolts to match the AJT theme. Well worth the $50 cost. Fun project to boot.
  11. Jan 12, 2021 at 11:20 AM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    Looks like they're apart of the local track team or something
  12. Jan 12, 2021 at 11:42 AM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    I really like the style of the TRD shifter than the OEM. I don't own a TRD, so I picked one up without the TRD stamping. The weight difference between this one and the stock OEM shifter is world's apart.
    Waiting for the weather to heat up a bit before I tackle the tail light install.
  13. Jan 12, 2021 at 12:38 PM
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
  14. Jan 12, 2021 at 12:38 PM
    YotaBro
    Calvin
    FL
    Monumental...
  15. Jan 12, 2021 at 12:42 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    That's like mine from last week. i was 2 degrees away from all 6's. you're 1 degree away from all 4's! shoulda went 44 mph just to add to it. lol
    YotaBro[QUOTED] likes this.
  16. Jan 12, 2021 at 12:51 PM
    itstorbs
    itstorbs New Member
    Jack
    Fort Bragg
    2021 SR5 Trail
    The world's most funded track team. Those are the "improved" army fitness uniforms. They were trying to get out of our work parking lot without having to wait in traffic for the 1 exit we have for 3000+ soldiers to use.
  17. Jan 12, 2021 at 12:56 PM
    itstorbs
    itstorbs New Member
    Jack
    Fort Bragg
    2021 SR5 Trail
    Installed paint matched BumperShellz bought through CaliRaised. Install took about 2-1/2 hours, first one took about 2 and the second one took only a half hour or so. Some notes:
    Covers go OVER the fog light housing. Meaning once these go on, the only option is to go through the wheel well or to remove the shell, and re-install it with new 3M tape.
    The holes for the 2 12mm bolts on the bottom of the shell/wheel well liner are very hard to line up. Pic 3 shows that it doesn't line up well.
    The install is much easier if you don't have parking sensors. No need to remove the liner, only 2 bolts to undo, clean the chrome, and install it. I took the grill off based off of recommendations that it makes it easier to apply full pressure to the 3m tape on the top of the shell.
  18. Jan 12, 2021 at 1:29 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Got the Lien Release paperwork in the mail yesterday!
  19. Jan 12, 2021 at 1:44 PM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I noticed the same thing on the fog lights. I wish I had realized it before, as I would have upgraded the fogs prior to installing the Bumpershellz. Not that it is the end of the world if they have to be removed and reinstalled, but just an inconvenience.
  20. Jan 12, 2021 at 1:45 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I’ve taken mine off a couple times now and it’s not that big of a deal. The 3m exterior mounting tape is like $5 at Walmart in the paint section :thumbsup:
    3xYOTA and jonclark96[QUOTED] like this.
  21. Jan 12, 2021 at 1:47 PM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    Good to know! No issues deforming the shells trying to get them un-stuck from the bumper?
  22. Jan 12, 2021 at 1:48 PM
    Squatting Pigeon
    Holden
    North Texas
    Not at all, the plastic has stayed very pliable in the nearly two years I’ve had them!
    Rica25 and NewImprovedRon like this.
  23. Jan 12, 2021 at 1:57 PM
    ADV4R
    ADV4R New Member
    Kevin
    I did it myself. And I sourced all my own parts. Aside from the transmission thermostat, outlet and inlet hoses and the hard lines (all OEM) that run along the engine, the rest is custom. I only needed a little less than 5ft of transmission hose and some AN fittings for the cooler. The bracket to mount the cooler is something I made with drawer slides I had laying around.
    co2owen, Rica25, Wallygator and 7 others like this.
  24. Jan 12, 2021 at 2:25 PM
    YotaBro
    Calvin
    FL
    Installed a fun button, gonna try it around the neighborhood
  25. Jan 12, 2021 at 2:27 PM
    YotaBro
    Calvin
    FL
    Geez, and I thought that the Air Force PT uniforms were bad
    mountain dweller likes this.
  26. Jan 12, 2021 at 2:33 PM
    Nominal993
    Nominal993 New Member
    Jesse
    2014 SR5 TRD4x4
    Rough Country level kit, wheel spacers, Leer shell, XT tires, running boards
    Drove it to Hardees for a breakfast biscuit. The new prime rib. Meh.
    JerryH likes this.
  27. Jan 12, 2021 at 2:45 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    ARMY... That explains everything. :tinfoilhat:
  28. Jan 12, 2021 at 3:26 PM
    He must have been taking a shortcut to drop it off at the scrap yard. :D
  29. Jan 12, 2021 at 3:49 PM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    Maisy and I went for a back roads roadie today.
    Metro14536, GODZILLA, Rica25 and 9 others like this.
  30. Jan 12, 2021 at 4:10 PM
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    What size of carrier bearing drop is that? Thanks.
