Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Nov 11, 2018 at 6:46 AM
    #1321
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Wasn't there a forgotten clip or something of that nature that was attributed to what you're describing? Maybe ask the dealer if the windshield of this truck needed to be replaced before delivery. It's not unheard of for a person to accidentally strike the windshield with a pressure washer wand when cleaning it prior to delivery, happened to mine. Otherwise take it to a dealer, it's under warranty....
  2. Nov 14, 2018 at 5:27 PM
    #1322
    MOSTTX13
    MOSTTX13 New Member
    2011 Toyota Tundra Crew MAx
    Memphis Audio 12s, Mayhem Beast 20S Amp Terrain Grippers
    Hello, I am sorry for this question as I read a very long ongoing thread similar but did not help my situation.
    So September 10th we received massive Rain Fall here I live in Lytle Texas "the Country" right outside of San Antonio. Well I was crossing right at bottom of Rim level in My Tundra, when a "nice Guy" tried to cross at the same time splashing a huge wave into my truck, The Truck stalled out, I have been fighting with the Geico, who told me not to move or attempt to fix well its been 2 months now and no resolution. I took the spark plugs out to attempt to force water out etc, but unfortunately there is no spark the engine is not cranking at all after 2 months and replacing the battery You can hear the fuel pump kick on and electrical components turn on lights etc but engine will not crank. Can anyone suggest where to begin? Due to where I live unfortunately 4 different "Diagnostic" guys have no showed on me and I def cant afford to have it taken to the dealership. If anyone can relate this has caused some major heartaches/depression and inconveniences as I live 40 min from my job and own a small business on top of that, over last couple of months we have taken in my wife's not so "fast" cousin his 2 kids so running 8 people in 8 diff directions everyday is mentally and physically almost in possible not o mention paying for a truck and oh full coverage ins that don't work. Any help or advice is highly appreciated, and I apologize for my vent session. Oh my truck is a 2011 Toyota Tundra Crew Max 5.7 ltr 305-55-20 2'' level
  3. Nov 15, 2018 at 3:54 AM
    #1323
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Crankshaft position sensor maybe? I don't know if the engine would turn over if this sensor is wonky or not. That would be a question for someone who's experienced it. I don't know exactly where it's located, but it's low on the front of the engine and I would think that it could easily get swamped and possibly create an open circuit.
  4. Nov 15, 2018 at 5:22 AM
    #1324
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    This might be a dumb question but I havent had this happen in any of my chevy trucks. Is it normal for for the 5.7 to run higher oil temps on initial startup in cold weather? After I drove it for a mile or 2 the gauge went back to normal. Was just curious
  5. Nov 15, 2018 at 5:25 AM
    #1325
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    CPS is on the back of the 5.7 drivers side. But that shouldnt effect it cranking. When you to crank does it click or do anything?
    Grab a long ratchet and try turning the crank shaft by hand using the front crank bolt. Let's see how much water go sucked in. Sounds like it hyrdrolocked
  6. Nov 15, 2018 at 5:26 AM
    #1326
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Pressures? yes.
  7. Nov 15, 2018 at 6:26 AM
    #1327
    JQ3
    JQ3 2005 XSP rwd
    First off, I am truly sorry for what you're going through. Also, I'm not a mechanic do I can't offer any mechanical advice. With that being said I know of 2 instances where the same thing happened, just recently to my nephew in his convertible Mercedes during Hurricane Florence. In both cases the cars were "totalled" by the insurance company. The engine sucked in water and hydrolocked. Can it be fixed? Probably. Depends on how much the insurance company is willing to pay before they just salvage it.
    You're gonna have to raise hell with the insurance company if it's been 2 weeks! Be calm, yet persistent...be firm but not out of control and lastly. BE PERSISTENT!!! The squeaky wheel gets the oil! Good luck!!!!!!
  8. Nov 15, 2018 at 7:14 AM
    #1328
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    @LOTSOFTOYS how hard is it to replace rear glass on a 3rd Gen CM? Back seat need to come out?
  9. Nov 15, 2018 at 7:46 AM
    #1329
    Lake.Life24
    Shawn
    Upstate, NY
    Yes sorry pressure! Thank you
  10. Nov 15, 2018 at 10:13 AM
    #1330
    fulanoderock
    fulanoderock New Member
    Ventura County
    2018 Toyota Tundra TRD Sport
    @LOTSOFTOYS I have a brand new Tundra. When is the first maintenance service recommended? I've seen mixed opinions.
  11. Nov 15, 2018 at 7:47 PM
    #1331
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Maybe engine mounts? Is it misfiring? Hard to say man
    Toyota knows about it and they are researching it. No fix for it yet.
    Yes, likely a few hour job.
    5k for a rotate oil changes every 10k
    Filthyphil and Pigglet222 like this.
  12. Nov 15, 2018 at 7:53 PM
    #1332
    mcroyo
    mcroyo New Member
    COS
    2017 MGM SR5 Crewmax
    Have a very occasional issue where I'll leave a/c or heat on when I turn off the truck then next time I start I have to turn the fan speed up or down for it to turn on again. Can post a video if need be.
  13. Nov 16, 2018 at 4:32 PM
    #1333
    Trebor57
    Trebor57 New Member
    Rob
    Sacramento, CA USA
    2018 Toyota Tundra SR Double Cab - 2-wheel drive
    A question, I have a 2018 Tundra SR, I got the TIS Software and noticed my security system was not turned on.
    So I went to Options and turned it On, then went back to Security and it gave me the exact same notice, that I needed to turn it on in Options.
    Am I missing something in what I did?
  14. Nov 16, 2018 at 6:52 PM
    #1334
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    My wife's 4runner is doing that randomly too. Curious
    mcroyo[QUOTED] likes this.
  15. Nov 16, 2018 at 6:52 PM
    #1335
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Does it stay back lit in the on box?
  16. Nov 17, 2018 at 7:23 AM
    #1336
    Trebor57
    Trebor57 New Member
    Rob
    Sacramento, CA USA
    I am not sure what you mean, but if you are asking when I turn it on does it stay, yes. But when I go back to security it says the same thing, that I need to go to the option and turn it on. But it is on because I already did it.
    So strange, I turned it on, but it isn't. Does that mean I don't have something installed on my tundra? Or will there be something else I am missing?
    Thank you
    Rob
  17. Nov 17, 2018 at 6:59 PM
    #1337
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    Thank you. :)
  18. Nov 18, 2018 at 9:12 PM
    #1338
    Tundra101
    Tundra101 New Member
    ODee
    Upstate NY
    2017 Quicksand Tundra SR5 4X4
    Pro Comp 6” Lift
    I don’t know if you found a solution but I’ll just chime in. I don’t know about the 2012 truck but the ‘17 seat has a separate yellow plug that’s only for the airbag but the rest of the plugs if many are for the movement of the seat, heat etc.
  19. Nov 19, 2018 at 1:35 PM
    #1339
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    That's a damn good question... I dont know, seems like your missing something not installed on the truck
  20. Nov 19, 2018 at 4:17 PM
    #1340
    Trebor57
    Trebor57 New Member
    Rob
    Sacramento, CA USA
    I just checked it, does not say anything about the alarm system. :( bummer
    Now to find out if it can be added and how much or if an after market alarm system will be cheaper to put in.
  21. Nov 20, 2018 at 4:40 AM
    #1341
    Professional Hand Model
    Hand Protectors
  22. Nov 20, 2018 at 7:10 AM
    #1342
    JQ3
    JQ3 2005 XSP rwd
    In my 05 notice that when I come to a stop I feel a bump in the back...like being hit lightly by something. I read about this in years past, but I can't remember exactly what the cause was/is. I do know that the previous owner pulled something, what I don't know, because he installed a trailer brake controller below the steering wheel to the right. What's causing this slight bump? It shifts fine though.
    I've had the truck for a month. So far I've found out I need a left rear wheel bearing. I plan to have the tranny fluid changed and I've ordered some NGK iridium plugs. The truck had less than 94K miles when I got it.
    Thanks!
  23. Nov 20, 2018 at 3:02 PM
    #1343
    Hand Protectors
  24. Nov 21, 2018 at 8:46 PM
    #1344
    Walters96
    Walters96 New Member
    Matthew
    2014 LTD Blue Ribbon
    TRD Grille
    Hey I just got an oem remote starter for my 2014 crew max, I installed my self following the directions printed directly from my dealer, I tried doing the magical dance to program it all and once I get to the remove and insert key 6 times the open and close the door 7 times the programming fails. What am I doing wrong @LOTSOFTOYS
  25. Nov 26, 2018 at 7:16 PM
    #1345
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Just need to lubricate the driveshaft
    Its a pita thats all i can say. It never goes smoothly
  26. Nov 27, 2018 at 3:22 AM
    #1346
    JQ3
    JQ3 2005 XSP rwd
    Is there a zerk fitting to lubricate the drive shaft? My truck is a 2wd by the way. Thanks!!!
  27. Nov 27, 2018 at 4:04 AM
    #1347
    Hand Protectors
    Yep. My rear drive shaft has 6 zerks (double cardan). If they haven’t been done in a while you may need to clean the gunk off around them to find them. Use a cloth and small screwdriver to get in and around.
  28. Nov 27, 2018 at 4:02 PM
    #1348
    Medic1
    Medic1 New Member
    Vann
    2011 tundra crew max 4x4 lifted.
    6in lift
    Ok this is a long forum and reading it all to find my issue is mind blowing. 2011 tundra has a Loss of power while driving. Almost like you shut the switch off momentarily and only a split second. This is rhythmic when it starts. It does not do it all the time. It acts like a rhythmic miss. I am also having issues with it taking gear when I first crank it. I put it in gear and have to wait for it to catch. This only happens every now and then, mostly when the truck is cold and only once when the truck was hot. Any ideas?
  29. Nov 28, 2018 at 4:46 AM
    #1349
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    With a 6 inch lift, and likely larger tires, I'd wonder if maybe the traction control is intervening. I'm not sure what to offer on the subject of the transmission though....
    Medic1[QUOTED] likes this.
  30. Nov 28, 2018 at 7:12 PM
    #1350
    JQ3
    JQ3 2005 XSP rwd
    I’m confused! Per my 2005 manual it appears that only 4wd Tundras have instructions on chassis lubrication. Where do I lube a 2wd driveshaft????942E6E39-9A51-4A23-B9B1-1851DA016D31.jpg
