Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Sep 21, 2020 at 5:24 AM
    #2881
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Nice I’ll take ya up on that. Just a small tester would be cool. I know I’ll like it shine supply is top notch
    Rica25 and War Machine[QUOTED] like this.
  2. Sep 21, 2020 at 6:08 AM
    #2882
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    Alright detailers.
    Last time I asked a question in this thread I wasn't committed enough to break out the polisher, so I just Iron-x, clay bar, washed, and beadmaker'd my truck. This didn't help what I was trying to fix which was a light haze left from using an eraser wheel to remove my emblems. It isn't burnt clear coat, just scratching on the black truck. You can only see it at certain times of day.
    I'm taking a couple of days off work soon with the goal of polishing the truck. Now I just need to figure out what I will use.
    I have a Porter Cable DA polisher.
    I was thinking of using CarPro Essence as the polish. I saw some youtube videos that said this may be a one pass solution to some light scratching/swirls. Do you agree?
    I was thinking of using the Lake Country CCS Orange pad to apply the Essence. Do you agree?
    I would love to do it in one pass, but if I am committing to this, I'll do two if I have to. Can I do spots of a heavier compound if the essence doesn't get the haze off of the bad spots, or do I have to do a full panel/side/truck?
    Planning on finishing with BeadMaker, but I have a bottle of Chemical Guys Butter Wet Wax that I could put on with a wax application pad if that is more reccommended.
    HELP! :D
  3. Sep 21, 2020 at 7:41 AM
    #2883
    briarpatch
    briarpatch New Member
    Limited experience with Essence, but my expectation is that combo will work fine. Both Beadmaker and Butter Wet Wax will last about the same amount of time......2-3 weeks if you're lucky. I'd be a lot more inclined to apply Griots Ceramic 3 in 1 rather than either of those two products. It will not give you the slickness or gloss of Beadmaker, but will definitely last a lot longer for the same level of effort. Once cured,you can always apply BM and get that slickness it's famous for.
    ToyoMafia likes this.
  4. Sep 21, 2020 at 7:49 AM
    #2884
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Essense itself will give you great gloss and sickness. It also contains sio2 so its a legitimate sealant that will last months. I would top with a silica based sealant if you want to layer it
  5. Sep 21, 2020 at 8:12 AM
    #2885
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    I'd try some shine supply but shipping to Canada is just too much money.
    Cerakote is on my list after my DLux runs out (that's what I replaced Pearl with for ourside plastic)
    I have some time to figure out what I'll use next on interiors as I still have lots of pearl.
    And as usual, all of the suggestions from you all are appreciated.
    ToyoMafia and Fotnot like this.
  6. Sep 21, 2020 at 9:27 AM
    #2886
    bradleykd
    Brad
    Kentucky
    2016 Limited-BLACK
    So you're saying that if I use Essense, I don't even have to use the Beadmaker, or anything else, after? Just buff it off with microfiber?
    Pudge[QUOTED] likes this.
  7. Sep 21, 2020 at 10:01 AM
    #2887
    ToyoMafia
    Magic carpet.
    Hey Jason. How has the dlux done for you on the exterior. I have both cerakote and dlux and next full clean up on the truck I’m using one of them on the blacks. I’ve used dlux on wheels and cerakote on the fj steps so far. Just wondering the life span on dlux.
  8. Sep 21, 2020 at 10:20 AM
    #2888
    jpod
    London Canada
    So far so good but we haven't had a lot of rain and my truck is now dusty. I'm planning on doing a good look after I have the chance to wash it. The last two washes it's been perfect but even a mediocre coating should last two washes...
    It has a very nice dark mid-satin finish to it that is marginally shiny but not too glossy. It looks more clean and new than the old armour all look. Which is good.
    ToyoMafia[QUOTED] likes this.
  9. Sep 21, 2020 at 10:45 AM
    #2889
    ToyoMafia
    Magic carpet.
    Thank u. Cerakote is really good on durability so I think I may go that route. I’m looking for a long tirm solution. Trim shield by Shine lasts a couple washes as well and it’s been my go to so far. I bought dlux for the wheels when I got them new and it has preformed well but if it fails anytime soon I’ll be disappointed because it’s a lot of work to coat wheels.
    War Machine and jpod[QUOTED] like this.
  10. Sep 21, 2020 at 1:33 PM
    #2890
    Pudge
    CT
  11. Sep 22, 2020 at 4:53 AM
    #2891
    War Machine
    War Machine SSEM # 5 3MW
    I’ve only done a few test spots with DLux, but my impression is that Cerakote will last longer.
  12. Sep 23, 2020 at 8:33 AM
    #2892
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    I'm wanting to do a decon and remove whatever waxes or substances are on the truck from a few drive-thru car washes. What's the best way to remove it? Wash with Purple Power?
  13. Sep 23, 2020 at 9:48 AM
    #2893
    Bust
    Bust New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    Purple power will strip a lot of waxes and sealants, if you want a full decon and clear paint, ironx and clay will ensure there are no contaminants
  14. Sep 23, 2020 at 1:25 PM
    #2894
    itsmerh85
    Gilbert, AZ
    2020 Black TRDPro
    yeah I'll be doing those, as well. I assumed I needed to use purple power first, then iron x and clay. If i'm doing those two things can I just skip the purple power then?
  15. Sep 23, 2020 at 1:36 PM
    #2895
    War Machine
    Those two will take everything off. No need for anything else. Wash it, use iron x and clay, wash again, then apply a sealant or wax.
    ToyoMafia and itsmerh85[QUOTED] like this.
  16. Sep 23, 2020 at 1:40 PM
    #2896
    itsmerh85
    Gilbert, AZ
    2020 Black TRDPro
    perfect, saves me a couple bucks to 'justify' another purchase
    :spending:
    War Machine[QUOTED] likes this.
  17. Sep 27, 2020 at 9:01 AM
    #2897
    YotaFan05
    YotaFan05 New Member
    NE OH
    2011 Tundra Crewmax
    What's a good spray on and rinse wheel cleaner? Something that'll loosen the brake dust up. I've used Sonax wheel cleaner and really like it, but it's a bit pricey.
  18. Sep 27, 2020 at 9:20 AM
    #2898
    ToyoMafia
    Magic carpet.
    Sonax is great. Brake buster is what I typically use it’s just about as good and a lot less expensive by the gallon which you can always get on sale through one of the top detail suppliers we always recommend here.
    YotaFan05[QUOTED] likes this.
  19. Sep 27, 2020 at 7:33 PM
    #2899
    YotaFan05
    NE OH
    2011 Tundra Crewmax
    Before winter, I want to do one last detail on the truck. I've been a big fan of the blackfire aio after a claybar, so I will do that. What can I top it with that will give me good winter protection for a good 4-5 months. Would Griot's 3-1 work? I have wolfgang deep gloss sealant on hand, but contemplating trying something new.
  20. Sep 28, 2020 at 4:45 AM
    #2900
    War Machine
    3-in-1 will definitely work. I got 5 months through the Texas summer, so it should make it through the winter no problem. Other than that, the only long lasting sealant I have enough experience to recommend is Jescar Powerlock. I believe @Pudge used that before the winter last year, so he can give you first hand experience. He’s in the northeast so he definitely knows what the best practices are for that type of environment.
  21. Sep 28, 2020 at 6:00 AM
    #2901
    YotaFan05
    NE OH
    2011 Tundra Crewmax
    Thanks! I am anxious to try the 3-1.
    I've got a bottle of the turtle wax hybrid ceramic wet wax. You use it as you're drying your car after washing. That's different than the 3-1 right? I take it that it's more of a spray ceramic maintainer after washes....like you would use a spray wax. Not really for a long term protection vs the 3-1 that adds the sealant protection.
    Rica25 and ToyoMafia like this.
  22. Sep 28, 2020 at 6:33 AM
    #2902
    Pudge
    CT
    Powerlock definitely is amazing and worked through winter for a rarely driven but stored outside truck. It's one of the best sealants I have used for sure. I assume 3 in 1 will do just as well from what i have read but can't make a claim based off experience
  23. Sep 28, 2020 at 7:44 AM
    #2903
    Rica25
    Ricardo
    Tulare
    I handed down my mom a 2005 Camry SE V6 we bought since it had 12 miles. Has been a great vehicle. No issues since day one. Now the paint seem to have absolutely no shine to it. How can I revive it. For the past few months on weekends or when I feel like it I've been doing some detailing jobs so I have certain products. But I really need some help for this one. Paint looks very bad.
  24. Sep 28, 2020 at 8:01 AM
    #2904
    Pudge
    CT
    Let's see some pictures of the paint if you can. I'd try an all in ine first, something with fillers maybe. Carpro Essense may be a good choice, it'll polish, fill, and leave several months of Sio2 protection
  25. Sep 28, 2020 at 8:16 AM
    #2905
    Rica25
    Ricardo
    Tulare
  26. Sep 28, 2020 at 8:30 AM
    #2906
    ToyoMafia
    Magic carpet.
    I see a little shine on that paint still you should have no issues getting this back in shape with a good aio and the right pads. I’ve been using 3d one with great results. Just make sure you do it in a garage early or late in the day.
    Rica25[QUOTED] and War Machine like this.
  27. Sep 28, 2020 at 8:40 AM
    #2907
    War Machine
    @Pudge and @Swfltoyomafia are on the right track here. Only thing I’d add is to try a paint decontamination with IronX and a clay bar / mitt first. You’ll probably see a good bit of improvement from that alone. It’s a good idea to do that before polishing anyway.
    Pudge, Rica25[QUOTED] and ToyoMafia like this.
  28. Sep 28, 2020 at 8:42 AM
    #2908
    War Machine
    It’s a different approach to the same goal. I haven’t used the Turtle Wax, but have used a similar product by Meguair’s. It worked well, but didn’t last long enough to be noteworthy, so your comment is spot on.
    3-in-1 does go on like a spray wax. Definitely a much longer lasting product than a spray wax though.
  29. Sep 28, 2020 at 8:58 AM
    #2909
    ToyoMafia
    Magic carpet.
    Ricardo let us know what you have on the shelf. No need to buy a bunch of stuff if you already have something similar. I know you have gotten into detailing rides for the family. I absolutely agree with @War Machine a good decon is the way to a great finish. When we cut out steps it effects the end results. I will say nothing beats ironX when it comes to decon. I like using griots synthetic clay and speed for that process and both are available at autozone.
    Rica25[QUOTED] likes this.
  30. Sep 28, 2020 at 9:32 AM
    #2910
    Rica25
    Ricardo
    Tulare
    I have the clay mit and clay bars. Also have 3m compound and VSS from chemical guys. Griots compounds as well as sealants. Then recently purchased Beadmaker
