Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Sep 6, 2020 at 8:33 AM
    #2821
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    War Machine[QUOTED] likes this.
  2. Sep 6, 2020 at 8:44 AM
    #2822
    Singhv497
    Singhv497 New Member
    Vikash
    2019 Toyota Tundra Platinum
    How can I remove hard water stains off my windshield and other car glass. Some of those Amazon products work but leave small scratches if you use a hard sponge. What do you guys recommend? Thanks
    ToyoMafia likes this.
  3. Sep 6, 2020 at 10:57 AM
    #2823
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    You can try a clay bar. If you really want to do the job get glass polish pads and a DA with griots glass polish. This works really well. I use a g9 griots pads griots glass polish and griots glass sealer
    War Machine likes this.
  4. Sep 6, 2020 at 11:00 AM
    #2824
    Singhv497
    Vikash
    Thanks I’ll give it a shot
  5. Sep 6, 2020 at 11:39 AM
    #2825
    briarpatch
    briarpatch New Member
    Depending on how bad those water spots are, you may have to go all the way to Ceriglass(by CarPro). I have some seriously bad etched water spots on my windows, and had to get the CarPro Rayon pads and use them along with Ceriglass....and even that combo took some work to get them off
    ToyoMafia and War Machine like this.
  6. Sep 6, 2020 at 12:30 PM
    #2826
    Azblue
    The Dirty T ( ^_^)_且
    I saw discussions on the Griots 3-in-1 in this thread, but not this particular question. I've mentioned that my go-to is Power Lock, I've also mentioned how horribly hot it is here in Tucson during the summer.
    So, my question (probably a stupid one) is would the 3-in-one be a good, easier thing to use as a refresher between the 3 or 4 times a year that I use the Power Lock?. I know that they are a different type of product, so my thought is no, it wouldn't.
  7. Sep 8, 2020 at 5:29 AM
    #2827
    War Machine
    War Machine SSEM # 5 3MW
    A cheap and easy option is barkeepers friend in liquid form. It works very well on cleaning glass. I use it on my shower doors when they get a lot of hard water build up, and it’s done wonders on windshields. Only thing is you have to make damned sure you don’t get it on anything but the glass. Don’t let it get on your paint.
  8. Sep 8, 2020 at 5:33 AM
    #2828
    War Machine
    Not sure how well it will bond to Powerlock, as I haven’t tried it. I know Beadmaker doesn’t work well with Powerlock. It just wipes off. The only thing I’ve tried or even heard about that works well with Powerlock is Collinite 845.
    3-in-1 is a stronger sealant than Beadmaker, so it may work, but until someone tries it I’m doubtful.
    If you’re using Powerlock 3 or 4 times a year, you’re keeping a really good level of protection on your truck. I don’t know that you’ll get any benefit. I really think adding some wax to increase gloss would be all you’d want or need to do.
    Azblue[QUOTED] likes this.
  9. Sep 8, 2020 at 9:02 AM
    #2829
    owb2gp
    owb2gp New Member
    ID
    This stuff is straight up amazing on hard water spots. Used on the shower door first and was impressed. Used it on my truck glass and it worked just as well. I taped off all the rubber trim before I applied it and was very careful not to get it anywhere but the glass. Hardly any effort to remove the hard water spots.
    Beesta and War Machine like this.
  10. Sep 8, 2020 at 7:28 PM
    #2830
    briarpatch
    Thank you for the tip....will have to try some of that
  11. Sep 12, 2020 at 11:49 AM
    #2831
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
  12. Sep 13, 2020 at 12:09 PM
    #2832
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    Bought my son a Honda civic. Low miles and in powertrain great mechanical condition. Unfortunately on the back two fenders it looks like the cleat coat is gone and the paint is starting to "crows foot". I believe that is the term. Anyway my question is what can be done to prevent it from getting worse (besides taking it to the paint shop) or possible improve the situation?
  13. Sep 14, 2020 at 4:43 PM
    #2833
    PNW1794
    PNW1794 New Member
    Woodinville, WA
    2019 Smoked Mesquite 1794
    Go Rhino Running Boards - RB20 Bedliner Coating Line-X Spray-in Bed Liner Tanneau Cover - BAKFlip MX4 Fuel Sledge 20x9 Wheels Toyo Open Range 275/70 R20 1.5" Front Level - Ruff Country Coil Spacers Front Window Tint TRD Air Intake Ronin Short antenna Console Organizer Back-seat USB charger De-chrome Black door handles Color match Mirror Caps Color matched Grill assembly/bulge Platinum Grill swap Wireless Charging Tray A Pillar Handle Rear TRD Sway Bar Engine Light LEDs (Warm White) from Matt Gecko LEDs
    Question about what you all might recommend to buff our minor scratches. They are small cosmetic scratches from branches, kids backpacks, etc. I looked through this thread but didn't see anything specifically called out.
    Any suggestions? I'm a novice at this and figured I better treat my truck a little better than an occasional trip to the car wash. :D
    Really appreciate this thread and all the recommendations and will also get some of the products on this one https://www.tundras.com/threads/detailing-top-products.70949/
  14. Sep 15, 2020 at 5:31 AM
    #2834
    War Machine
    Not sure there’s any way to improve it without a repaint. I’m afraid machine polishing would make it worse. As for keeping it from getting worse, just keep some wax or a good sealant on it. Even that’s probably not going to help a ton. Wax may hide the issue a little.
    Heath423[QUOTED] and ToyoMafia like this.
  15. Sep 15, 2020 at 5:36 AM
    #2835
    War Machine
    Best bet is to get a DA polisher, but between the machine and supplies it’ll run you a few hundred bucks. If you go that route, I’d recommend the Griots G9 along with some good pads from Lake Country and or Urofiber. Griots Boss line of polishes are great, but there are plenty of good options.
    If you don’t want to spend the money, you can find Meguair’s line of polishes at Walmart or any auto parts. They work well, but it’s a ton of work to do by hand. Meguair’s Scratch X is also pretty good for light scratches and scuffs. Not a bad idea to follow that up with a polish also, but I’ve had success with it by itself in small spots.
  16. Sep 15, 2020 at 8:09 AM
    #2836
    PNW1794
    PNW1794 New Member
    Woodinville, WA
    Thanks for the info. Might start with a Meguairs product, and go from there. Its a just a few spots, so might have enough energy to do it by hand!
    Appreciate the help.
  17. Sep 15, 2020 at 1:10 PM
    #2837
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    Thanks for the reply. Yes have had him waxing the 2 spots every week or 2. That helps a little but does not last. Thanks again.
  18. Sep 15, 2020 at 1:22 PM
    #2838
    ToyoMafia
    Magic carpet.
    Unfortunately the only fix to clear that has failed like this is to repaint. I just had the wife’s back door repainted because infinity white paint sucks and was applied wrong at the factory. It cost $450 for the whole door which was super cheap considering all the quotes I got for 1k and up. You could possibly sand it and wrap it but for the time and energy I would just spray it. Is it a part that could be swapped out by chance?
    Heath423[QUOTED] likes this.
  19. Sep 15, 2020 at 1:25 PM
    #2839
    ToyoMafia
    Magic carpet.
    If your feeling brave or your son is handy you could wet sand and paint yourself. One of my first cars was a Honda loved that thing.
  20. Sep 15, 2020 at 2:16 PM
    #2840
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    No I do not see that as an option.
    Hmm...it may have to get worse before I'm that brave. The wet sanding portion I could do and get smooth I think. I'm sure it is similar to finishing wood furniture projects. However, the auto painting makes me cringe. I do not have that type of equipment.
    ToyoMafia[QUOTED] likes this.
  21. Sep 15, 2020 at 3:39 PM
    #2841
    Trooper2
    JR
    Houston, TX (Suburban South)
    You could sand it smooth then get creative with some vynal wrap. Color matched or something to accent, maybe just black.
  22. Sep 16, 2020 at 10:33 AM
    #2842
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I had finally ordered some beadmaker and power clean from autogeek before the hurricane hit. Was supposed to be delivered the day it hit. Just got it yesterday. So about a month later. lol. Now to find time to actually get to wash ol blue. It's been about 2-3 weeks since I've washed either vehicle. I miss my therapy.
  23. Sep 16, 2020 at 10:39 AM
    #2843
    ToyoMafia
    Magic carpet.
    Yeah I bet. Hopefully life is ok up there with all this weather. Most of us gulf coast members miss our good car wash weather.
  24. Sep 16, 2020 at 10:56 AM
    #2844
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Considering what others are getting now from Sally and what most of our friends/family went through from Laura, we're gonna be just fine. I should be receiving ins. money soon to get roofers going and i'll be ok. Spray foam and drywall after.
    I'll probably take the kids out to wash the truck and wife's grocery getter van this Friday/Saturday. We have potential for another to possibly form and hit us now. Predicted to hit between New Orleans and Houston in the next week or so as a Category 1....and I'm smack dab in the middle of that in Lake Charles area. Laura was supposed to hit as a 1 or maybe a 2, and look what that did.:(
  25. Sep 16, 2020 at 11:08 AM
    #2845
    ToyoMafia
    Magic carpet.
    Good olde 2020. Smoke em if ya got em
    Fotnot[QUOTED] and War Machine like this.
  26. Sep 16, 2020 at 11:32 AM
    #2846
    War Machine
    Dilute the hell out of that Power Clean. It’s stout!
    Tundra14Platinum and ToyoMafia like this.
  27. Sep 16, 2020 at 11:52 AM
    #2847
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    a friend of mine says his buddy works on and cleans stuff in the plants. says they use that straight to clean exchanger bundles. freaking potent he said. I'll prob start around 10:1 and figure it out from there.
  28. Sep 16, 2020 at 12:01 PM
    #2848
    War Machine
    I know it cleaned the hell out of my driveway where I spilled it. Took forever to rinse off though.
    Fotnot[QUOTED] likes this.
  29. Sep 16, 2020 at 12:02 PM
    #2849
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    it actually crossed my mind to spray a bit on my driveway and pressure wash it off. haha
  30. Sep 16, 2020 at 12:02 PM
    #2850
    War Machine
    It works for sure.
