Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Nov 13, 2019 at 12:06 PM
    #1591
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Best bet is to put the decals back on, I know it stinks but the cost of having that repaired will be high.
    Pudge[QUOTED] likes this.
  2. Nov 13, 2019 at 4:14 PM
    #1592
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    How do I remove swirl and scratches from my gauge cluster so annoying. Used a microfiber to wipe away dust and I can see only in direct sunlight
  3. Nov 13, 2019 at 4:34 PM
    #1593
    OV-1794
    OV-1794 New Member
    I would go back to the dealer and ask them to fix it, but do so nicely. I'm surprised they'd sell a CPO truck with such a poor respray. I'm sure they have body shop relationships and could get it done relatively easy. If they say no outright, could always see if they'll split with you.
  4. Nov 13, 2019 at 5:14 PM
    #1594
    Istvank11
    Istvank11 Shine On
    AZ
    2016 CM
    I wish this post could be pinned somehow so it doesn’t get lost. Lots of valuable information here! Also, you guys are enablers!
  5. Nov 13, 2019 at 5:20 PM
    #1595
    Pudge
    CT
    2015 Blue Ribbon Platinum
    You are very right, this is too much good info to get lost in the mix. Maybe a mod can pin this or quote it into the OP of this thread? @T-Rex266 @ColoradoTJ @Pinay ?
  6. Nov 13, 2019 at 5:23 PM
    #1596
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Thread is stickied already
    NewImprovedRon likes this.
  7. Nov 13, 2019 at 5:23 PM
    #1597
    Pudge
    CT
    You're quick
    Pinay[QUOTED] likes this.
  8. Nov 13, 2019 at 5:25 PM
    #1598
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Thread on top of detailing section of forum.
  9. Nov 13, 2019 at 5:27 PM
    #1599
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    jpod and Pudge like this.
  10. Nov 13, 2019 at 6:12 PM
    #1600
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Just need to PM me want you want or go to https://yodaganofficial.com/
    4x4_Angel and GODZILLA[QUOTED] like this.
  11. Nov 13, 2019 at 8:02 PM
    #1601
    18" TRD Off Road Wheels
    boardude[QUOTED] and Pudge like this.
  12. Nov 14, 2019 at 12:26 AM
    #1602
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Thanks buddy! :cheers:
  13. Nov 14, 2019 at 4:26 AM
    #1603
    War Machine
    War Machine SSEM # 5 3MW
    I appreciate the compliments, but these are just my opinions. I’m nowhere near an expert on this stuff, and I’m sure plenty of people would disagree. There’s a lot of legitimate ways to get the results you want.
    GODZILLA likes this.
  14. Nov 14, 2019 at 4:26 AM
    #1604
    War Machine
    boardude[QUOTED] likes this.
  15. Nov 14, 2019 at 4:27 AM
    #1605
    War Machine
    If you figure out a way, let us know. I’m not aware of a fix for that.
  16. Nov 14, 2019 at 8:32 AM
    #1606
    Lol. He was referring to the fact that the vinyl I want to protect is one I'm ordering from him.
    boardude and War Machine[QUOTED] like this.
  17. Nov 14, 2019 at 9:34 AM
    #1607
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    Its fairly easy, however it requires some elbow grease. You will need some masking tape, a few microfiber towels, and a light to medium polish, something like plastic X from Meguiar's will do the trick
    1. You will need to mask surrounding areas where the you don't the polish to get on.
    2. Put a dab of the polish on a section of the MF towel (could be a corner). A little goes a long way.
    3. Put the section with polish of the MF towel on your fingers and Start going around the surface covering as much as you can. There is no need to apply much pressure, make sure you do multiple passes.
    4. Once done, get a clean MF towel to wipe off the excess.
    5. Inspect the area, if you are not satisfied, repeat steps 2-4 until you achieve the desire result.
    6. Remove masking.
  18. Nov 14, 2019 at 11:07 AM
    #1608
    hypa
    hypa New Member
    Dear Detailer.
    How do I get rid of the gritty sound when rolling down my windows? I've tried dry lube, silicone spray, etc and have had no luck. This typically happens after a rainstorm too.
    Thanks!
  19. Nov 14, 2019 at 8:18 PM
    #1609
    YsoSeRiouS!
    NorCaL
    thank you
  20. Nov 14, 2019 at 10:39 PM
    #1610
    Bust
    Bust New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    Wonder if you need to clay your glass or if there is grit on the rubber felt seals. Griot's makes glass clay
  21. Nov 15, 2019 at 9:31 AM
    #1611
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Lol no, I was just answering his comment on the yodagan decal
  22. Nov 16, 2019 at 2:21 PM
    #1612
    EastbayAllday
    EastbayAllday Strip mall legend
    East Bay
    2018 White Platinum
    I’m about to use a DA Polisher for the first time and am wondering how do you guys clean the pads after using them?
  23. Nov 16, 2019 at 2:33 PM
    #1613
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    After I’m done I spray a little griots pad cleaner on the pad, work it in with my hands while rinsing with water.
  24. Nov 16, 2019 at 3:40 PM
    #1614
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
  25. Nov 16, 2019 at 3:49 PM
    #1615
    War Machine
    Some water and a little bit of ONR or another soap. Rinse by hand.
    EastbayAllday[QUOTED] and Pudge like this.
  26. Nov 16, 2019 at 3:53 PM
    #1616
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    can anyone tell me where you can buy a 2000 grit wet sanding block ? The guy who took a small dent out for me had a 2000 and a 3000 grit very small wet sanding block and he said you could find them on the internet but im not having any luck !
  27. Nov 16, 2019 at 3:54 PM
    #1617
    War Machine
    Never heard of this brand, and I’d be very careful about which one to go with. @Pudge would love to tell you about his experience with a lesser known brand of ceramic.
    Carpro CQuartz is probably the most recommended around here. Well known product, great service, and not overly difficult to apply.
    There is a good bit of labor involved, as you need to do a very thorough paint correction to get the best results. I personally would rather go a different route, but that’s because I love doing the work. If you don’t enjoy washing, waxing or applying sealant to your vehicle, then it may be the right thing for you.
    NewImprovedRon and Pudge like this.
  28. Nov 16, 2019 at 3:55 PM
    #1618
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Ceramic coatings are a very worthy investment on any vehicle, they provide not only hydrophobic properties, but also anti-static and UV protection for your paint, all with the added benefit of making your washes much easier and less time consuming. A good coating will provide you with at least 2 years of protection, if it properly maintained after its application. No wax will ever provide you with that much protection without having to be applied every month.
    A highly recommended brand, and one that I've used on my personal and clients vehicles, is CarPro cquartz UK 3.0. Great longevity and very forgiving at the moment of applying it.
    Pudge and sask3m[QUOTED] like this.
  29. Nov 16, 2019 at 3:57 PM
    #1619
    War Machine
    https://www.theragcompany.com/tools-accessories/sanding-tools/
    Pudge and NewImprovedRon like this.
  30. Nov 16, 2019 at 4:06 PM
    #1620
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Thanks for the info. By labour would clay bar and polishing be sufficient? My truck is brand new (black) but I did make the mistake of using the local car wash so just did a hand polish job to remove as many swirls as I could, plan on waxing tomorrow. I'm 65 and my elbows aren't what they used to be.:(
    PS, I see there is a shop in Calgary AB 40 miles away that sells carpro products. A visit may be in order.:)
    Trooper2 and Pudge like this.
