Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Oct 8, 2019 at 7:56 AM
    #1411
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    My wiper cowl is faded. Should I Solution Finish first then this, or just this or just Solution Finish?
  2. Oct 8, 2019 at 8:15 AM
    #1412
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Now that my truck is lifted what are you all useing to put on the lift components to help keep them clean and free of rust?
  3. Oct 8, 2019 at 10:22 AM
    #1413
    War Machine
    War Machine SSEM # 5 3MW
    I’d go with Solution Finish unless you already have Dlux. I know for certain it does a great job, and have yet to try the DLux. I’m guessing the Dlux is more about prevention than cure.
    Pudge likes this.
  4. Oct 8, 2019 at 10:24 AM
    #1414
    War Machine
    Pudge likes this.
  5. Oct 8, 2019 at 11:38 AM
    #1415
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I think this is the way to go. Use the solutions finish to get it back to black, then after a few days or a week, use DLux to protect your new finish and prevent future damage. I would imagine putting a coating on top of faded gray trim will result in coated faded gray trim. However some have said they had good results as far as getting trim black again with gtechiq permanent trim restorer, which I think is similar to DLux. Personally I would want it turned back to black before I sealed it
    War Machine[QUOTED] likes this.
  6. Oct 8, 2019 at 4:50 PM
    #1416
    Cdorman
    Cdorman New Member
    Oklahoma
    2015 - SR5 - CM - MGM
    Color match MGM Bulge/Grille Trim Pro Grille TRD Pro Headlights(black) OEM led fog lights upgrade Headlight Revolution HID upgrade TVD vinyl decals Fog lights Always MOD Bilstein 5100’s 12Volts remote start kit PowerBass plug/play speaker upgrade
    What’s the best way to get get semi-deep scratches out of headlight??
  7. Oct 8, 2019 at 7:08 PM
    #1417
    Bust
    Bust New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    Unfortunately I think you just have to replace the headlamp. Surface scratches, discoloration and build up can usually be removed, but deep scratches I think you are hosed. Unless others have been able to???
  8. Oct 8, 2019 at 7:16 PM
    #1418
    Pudge
    CT
    Maybe wet sanding and blending the sanding marks, then polish the marks out. But deep can mean a wide range of things. You may need new lights if the damage is too deep
  9. Oct 9, 2019 at 1:32 PM
    #1419
    sunnysideTRD
    sunnysideTRD New Member
    Sunny
    2019 Tundra TRD Pro Voodoo Blue
    Standard 2019 TRD Pro but will be a project car and add as I go
  10. Oct 10, 2019 at 5:54 AM
    #1420
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
  11. Oct 10, 2019 at 10:05 AM
    #1421
    War Machine
  12. Oct 10, 2019 at 2:05 PM
    #1422
    cmiller219
    Nashville, TN
  13. Oct 10, 2019 at 2:27 PM
    #1423
    K1NJO
    K1NJO New Member
    Allen
    Bay Area, CA
    2011 Black Tundra TRD Sport
  14. Oct 10, 2019 at 3:02 PM
    #1424
    War Machine
    It has never even crossed my mind to be honest. I’ve never known anyone to do anything like that until I joined here.
  15. Oct 11, 2019 at 7:45 PM
    #1425
    Tundraman1000
    Tundraman1000 New Member
    2016 SR5 DC MGM 4x4
    Looking for a good recommendation on fixing a long scratch all the way down the side of my truck from a bush.
  16. Oct 11, 2019 at 7:51 PM
    #1426
    Pudge
    CT
    Got any pictures? This will be very helpful.
    How deep is it? If you run your fingernail across it, does it catch? Is it just the clear coat or is there paint involved?
    The recommendations could range from layering touch up paint and wet sanding to a simple polishing.
  17. Oct 13, 2019 at 1:11 PM
    #1427
    Pudge
    CT
    I so pisssd off today. 2 beautiful days this weekend for getting yardwork and detaling done. I have been sick in bed since Saturday morning with some kinda of stomach bug
    I havent been sick in years even though I work in the ER. I have so much I want to get done, detailing and swapping shocks. Will have to wait til I feel better, this sucks, losing 2 great work days.
  18. Oct 14, 2019 at 4:07 AM
    #1428
    War Machine
    That sucks Sean. That’s how I’ve been with my back lately. We’ve had really good detailing weather, but I just haven’t been able to do much. Worst part about back pain is that it’s hard to do anything, but sitting around makes it worse.
    Pudge[QUOTED] likes this.
  19. Oct 14, 2019 at 6:41 AM
    #1429
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    Need more advice/direction:
    I have a Torqx Random Orbital Polisher and was looking to get a couple wool pads for it.
    What do you all recommend?
    Thx
    Tom
  20. Oct 14, 2019 at 7:27 AM
    #1430
    Pudge
    CT
    I like the buff and shine uro wool, and carpro foamed wool. Also lake country makes great pads so I would check them out too.
    purplenova[QUOTED] likes this.
  21. Oct 15, 2019 at 4:23 AM
    #1431
    briarpatch
    briarpatch New Member
    First thing to do is give it 'the fingernail test'....see if your fingernail catches in it...if it does, you may be at the repaint stage. Pics would be helpful if it will show up
  22. Oct 15, 2019 at 6:42 AM
    #1432
    purplenova
    Tom
    Ohio
    Thanks @Pudge
  23. Oct 15, 2019 at 10:55 AM
    #1433
    AZTundra
    Paul
    Phoenix, AZ
    @War Machine @Pudge
    What do you guys recommend for taking car of the paint issue in the below picture? Any idea what happened here?
  24. Oct 15, 2019 at 11:05 AM
    #1434
    War Machine
    Looks like the clear coat is oxidized. You should be able to improve it through Iron remover, clay, and polishing, but not sure how much. I’d honestly like to try it myself and see. Sometimes it’s too bad and there’s nothing to do but respray it. I do think it can be at least improved, if not fixed.
    Pudge and AZTundra[QUOTED] like this.
  25. Oct 15, 2019 at 11:11 AM
    #1435
    briarpatch
    Agreed....looks like oxidization (<---is that a word?) to me too. Perform a test spot in an inconspicuous area with a light polish or even a cleaner wax to see...after wash and decon of course....I'd like to have a shot at that one as well
    AZTundra and War Machine like this.
  26. Oct 15, 2019 at 11:53 AM
    #1436
    AZTundra
    Paul
    Phoenix, AZ
    Thanks Jason, I'll pass along the info. It's on a coworkers son's truck.
  27. Oct 15, 2019 at 11:54 AM
    #1437
    AZTundra
    Paul
    Phoenix, AZ
    I'll give it a try and post up the after shot.
  28. Oct 15, 2019 at 11:57 AM
    #1438
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    It can be improved for sure. but Im afraid some areas will require heavy cutting, if possible have a paint gauge handy.
    The appearance Can definitely be improved.
  29. Oct 15, 2019 at 12:20 PM
    #1439
    AZTundra
    Paul
    Phoenix, AZ
    Any idea how much of the Iron Remover I'd go through for a job like this? Curious what size bottle/jug to order. Also, any recommended brands? Thanks again for the assistance.
  30. Oct 15, 2019 at 12:35 PM
    #1440
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    It is a big vehicle and probably very neglected, so I would get the 1 Ltr bottle of ironx to be safe. Keep in mind that it is a dark color so it will be hard to tell if the product is working.
    AZTundra likes this.
