Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Jul 26, 2019 at 6:45 AM
    #1171
    tstieb
    tstieb New Member
    2014 CM TRD
    I just picked up some Menzerna FG400 compound for some pretty substantial scratches on my black Tundra. I'd prefer not to use this on the whole truck, but instead spot treat the stratches with the compound then polish and seal the whole truck. Any idea if I can get away with this or will the finish look different in the areas where I used the compound?
  2. Jul 26, 2019 at 8:01 AM
    #1172
    War Machine
    War Machine SSEM # 5 3MW
    What do you mean by polishing? If you’re talking about an actual polishing product with a DA, you should be fine. That’s what is recommended after using compound anyway. Compound will usually leave a haze in the areas you use it on, so you need to go back over it with a polish.
    If I’m interpreting you correctly, it sounds like you’re already going to do that on the whole truck anyway. You may have to spend some extra time in the places you compounded.
    tstieb[QUOTED] likes this.
  3. Jul 26, 2019 at 8:16 AM
    #1173
    briarpatch
    briarpatch New Member
    For cleaner.....soap and water once you seal them.....Sonax Full Effect wheel cleaner prior to that. I've used McKees wheel sealant with success....I redo it every six months. CarPro Dlux is also very good, although the application may be a bit cumbersome on more intricate wheels
  4. Jul 26, 2019 at 8:30 AM
    #1174
    Jmmtjoy
    Jmmtjoy Livin the dream
    Bristow, Virginia
    2016 Crewmax SR5 Super White
    10-4. So nothing super specific to Matte or Powder Coated wheels as far as sealer? I am going to check with Mckee's but I assume the Paint Coating I have will work on the wheels also.
  5. Jul 26, 2019 at 8:38 AM
    #1175
    tstieb
    tstieb New Member
    2014 CM TRD
    Thx for the response. Yes, I'll be using a DA and another Menzerna polish product for jeweling followed by Powerlock sealant for the whole truck. I just didn't want those spots I used the compound on to look different than the rest of the truck, especially on black paint. I'll give it a shot and see. Thanks!
  6. Jul 26, 2019 at 9:05 AM
    #1176
    briarpatch
    I do not believe so...but double check with Nick and the good folks at McKees
    Jmmtjoy[QUOTED] likes this.
  7. Jul 26, 2019 at 9:14 AM
    #1177
    BrennanC0212
    BrennanC0212 New Member
    Brennan
    Atlanta, GA
    2014 Toyota Tundra Platinum - White
    Don’t use any acidic wheel cleaners for matte rims!
  8. Jul 26, 2019 at 10:32 AM
    #1178
    War Machine
    I’m pretty sure you’ll be fine.
  9. Jul 26, 2019 at 4:11 PM
    #1179
    Falconsfan
    Falconsfan New Member
    Southern Ohio
    I searched but didn't find an answer, I used to use the absorber to dry vehicles, I've now switched to microfiber, my question is how do you let it dry after washing vehicles with it? I'm assuming just hang to air dry? Or do you wash and dry them after each use?
  10. Jul 26, 2019 at 6:27 PM
    #1180
    War Machine
    I wash and dry mine after every use.
    Pudge likes this.
  11. Jul 26, 2019 at 6:34 PM
    #1181
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Same here.
    War Machine[QUOTED] and Pudge like this.
  12. Jul 26, 2019 at 7:01 PM
    #1182
    Jmmtjoy
    Bristow, Virginia
    Wheel cleaning brush/mit? What do you guys use?
  13. Jul 26, 2019 at 7:15 PM
    #1183
    War Machine
    I can’t remember exactly which ones I have, but I have on off brand version of these. Thy work great, and I think I paid 20.00 for mine.
    Liquid X Original Wheel Woolies Brushes 3 Piece Kit - Includes Angled Caliper Spoke Brush - USA Made - Black - New & Improved https://www.amazon.com/dp/B0779HTLD7/ref=cm_sw_r_cp_tai_Bo7oDbR1J1P4Q
  14. Jul 27, 2019 at 11:08 AM
    #1184
    owb2gp
    owb2gp New Member
    ID
    Istvank11 and jpod like this.
  15. Jul 29, 2019 at 9:23 AM
    #1185
    briarpatch
    As others have aid, wash and dry after use. I wash with All Free and Clear, add an extra rinse at the end. Tumble dry on air only, and then hang to allow them to dry completely. If you want to use the best drying towel in the market, pick yourself up a Griots PFM. You can get the smaller size (16x16) at Pep Boys.
    War Machine and Pudge like this.
  16. Jul 29, 2019 at 9:36 AM
    #1186
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Griots pure freakin magic towels are amazing like stated above.
    I wash all my microfiber separately, with a little all free and clear detergent, some griots MF detergent and sometimes white vinegar. I set a hot water soak, then cold extra rise, and extra spin to get really dry in the washer. tumble dry after cleaning the lint trap well, with no heat and no dryer sheets. Air dry is fine too but I'd need a long line when I wash 20+ towels at a time lol.
    My next MF detergent will be 3D Kleen, its $19 a Gallon at detailedimage and gets great reviews. For now I like the griots MF and foam pad cleaner just fine. well worth the investment. They all work as good as new. Treat them right and they will treat you right, they aren't cheap so take good care of them.
    War Machine likes this.
  17. Jul 29, 2019 at 10:24 AM
    #1187
    Jmmtjoy
    Bristow, Virginia
    Has anyone used either of the chemical guys drying towels? They are just a bit cheaper. Just curious
  18. Jul 29, 2019 at 10:31 AM
    #1188
    War Machine
    Which one are you looking at? Not drying towels, but these are great all around towels for washing and applying sealant:
    Chemical Guys MIC_506_12 Professional Grade Premium Microfiber Towels, Gold (16 in. x 16 in.) (Pack of 12) https://www.amazon.com/dp/B00A8MZ7IA/ref=cm_sw_r_cp_tai_O0YpDbVG382WS
  19. Jul 29, 2019 at 10:36 AM
    #1189
    Jmmtjoy
    Bristow, Virginia
  20. Jul 29, 2019 at 10:38 AM
    #1190
    War Machine
  21. Jul 29, 2019 at 10:46 AM
    #1191
    briarpatch
    I started with the Chemical Guys waffle weave towels, and they're okay, but no where near as good as the Griots PFM. One towel that does come reasonably close is the Twistress from the Rag company...I think a better value than the CG Waffle weave
  22. Jul 29, 2019 at 10:49 AM
    #1192
    Pudge
    CT
    Griots pfm is the best I wouldn't mess with CG towels. TRC double twistress is a solid towel too, not as good as the griots but good. I have 3 of them lol and 2 griots. I haven't been impressed with any CG towels I have tried to be honest
    Brownsfanhere and War Machine like this.
  23. Jul 29, 2019 at 2:24 PM
    #1193
    owb2gp
    owb2gp New Member
    ID
  24. Jul 31, 2019 at 11:15 AM
    #1194
    Pudge
    CT
    Just drove home from the grocery store thru a freaking tsunami. I love the beading from carpros products. This is hydro2 that I recently wiped down with ech2o, ech2o doesnt get the love of deserves. It's such a versatile product. Can be diluted for a waterless wash, rinsless wash, quick detailer, clay lube. And it does contain sio2 even without adding reload to the mix, so whenever you use it you are adding protection and great shine.
    phogallen, driverdog and War Machine like this.
  25. Aug 1, 2019 at 4:48 AM
    #1195
    War Machine
    Yes, it’s perfectly fine. I have three different brands I use, and I honestly don’t see any difference. Shine Supply Micro Clean is a better value at $24.00 per gallon, and Micro Restore is what The Rag Company recommends for their towels, but really I don’t see where any is better than the other as far as performance goes.
    phogallen[QUOTED] likes this.
  26. Aug 1, 2019 at 5:35 AM
    #1196
    Pudge
    CT
    I just use what's on sale. The CG seems to be 2-3 times what other cost. 3D kleen is the best value at under 20 a gallon
  27. Aug 1, 2019 at 5:43 AM
    #1197
    War Machine
    Main thing to remember is don’t use fabric softener when drying. It’ll mess the towels up.
    Pudge[QUOTED] and Fotnot like this.
  28. Aug 1, 2019 at 9:18 AM
    #1198
    Pudge
    CT
    I got sucked into an autogeek sale yesterday. 25%, free shipping, bogo stuff. Ended up getting BOGO Wolfgang MF restore wash to try, a bunch of stoner tarminator(which is one of my favorite new items I tried recently), new hydro2 bottle which was on sale plus 25% off, new MF towels plus some free towels, and more eraser. But I needed more hydro2 anyway and I got all that and more for about $10 more than what 500ml of hydro2 usually costs so it works out.
  29. Aug 2, 2019 at 4:42 AM
    #1199
    briarpatch
    Almost pulled the trigger yesterday too...the microfiber BOGO really didn't have anything I wanted/needed.....so I passed...seems like they're having lots of sales these days
  30. Aug 2, 2019 at 8:31 AM
    #1200
    Pudge
    CT
    Yeah AG seems to have a new sale every day or 2 and detailedimage does their sales for 3-4 days at a time. It's rare that you would find a day that at least one of the 2 doesnt have some kind of sale. I try to do the BOGO or free shipping deals when I need stuff. I'm fairly well stocked up for now....
