Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Aug 27, 2023 at 5:47 AM
    #5041
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    A lot of chrome plated plastic is soft. Metal polishers can break down that plating over time. A very fine polish on a micorfiber (Meguiar's M210 for example since you can get it at autoparts stores) is good for that substrate as it is less abrasive and will do the job of shining it up nicely.
  2. Aug 29, 2023 at 5:27 PM
    #5042
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    What’s everyone using to wash their MF towels?
    ToyoMafia likes this.
  3. Aug 29, 2023 at 6:11 PM
    #5043
    Azblue
    The Dirty T ( ^_^)_且
    I thrown them in the washer on max-fill with a low/mid amount of soap and no fabric softener. Dry in the drier at a med setting. I might be wrong, but it's what I do. If it's a towel that I used with a sealant or other "sticky" product, I wash it 2x and keep them seperate for that task.
    Fotnot and T-Rex266[QUOTED][OP] like this.
  4. Aug 29, 2023 at 6:43 PM
    #5044
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Rags to riches from TRC
  5. Aug 29, 2023 at 6:44 PM
    #5045
    ToyoMafia
    Magic carpet.
    Wash on delicate warm water. Dry delicate low heat and remove before bone dry.
    Damie Street, Fotnot and T-Rex266[OP] like this.
  6. Aug 29, 2023 at 6:47 PM
    #5046
    Thanks! That’s what I had before, but the wife tossed out the bottle. Ordered.
    Yessir
    ToyoMafia[QUOTED] likes this.
  7. Aug 30, 2023 at 5:15 AM
    #5047
    War Machine
    War Machine SSEM # 5 3MW
    Put some white vinegar in the wash also. I pour it in the fabric softener compartment next to where the soap goes. It really helps get any residue and crud out. It keeps them softer and extends the life of them. No fabric softener when drying. I actually do this with bath towels also.
  8. Aug 30, 2023 at 11:16 AM
    #5048
    briarpatch
    briarpatch New Member
    All Free and Clear. Been using it for years with no issues. After the wash cycle is completed, I use the 'rinse and spin' option to make sure I have all the soap out. Tumble dry on 'air dry' for 15 - 20 minutes and then hang up to complete the drying process.
    T-Rex266[OP] likes this.
  9. Sep 14, 2023 at 7:16 AM
    #5049
  10. Sep 16, 2023 at 9:34 AM
    #5050
    Ckatz53
    Ckatz53 Newish
    MD
    Just a tip for those looking to debadge the new Tundras '23+. The vinyl stickers on the bed are actually a three layer system. A heat gun separates the top vinyl layer but two layers of underpaper and adhesive stay behind. Strip the outer layer (color) with a heat gun then don't even worry about the underlayer using heat...go straight to an eraser wheel. I made the mistake of using the heat gun on one of them thinking it would be easy going...those underlayers are a pain in the ass and took 3x as long to take off...learn from my mistake and go straight to an eraser wheel.
    Badges are the same gooey 3m adhesive that heat and floss/fishing line can remove. Eraser wheel the residual then polish everything lightly to remove any eraser wheel holograms.
    20230915_183150.jpg 20230915_185206.jpg 20230915_183155.jpg 20230915_185222.jpg
  11. Sep 19, 2023 at 5:04 PM
    #5051
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    3D towel clean if you don’t mind having a gallon of it for years, lol. Rags to riches will be my next purchase
  12. Oct 7, 2023 at 8:18 PM
    #5052
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Finally got around to applying the solution finish to the step sides. They're pretty textured, so it kinda sucked to do...especially on the vehicle. That stuff is practically paint. Hopefully it works well.
    Before
    After
  13. Oct 20, 2023 at 11:21 AM
    #5053
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Question for you detailers: Can you touch up ceramic coating when it has started to peel? Or should I just have it removed from all four wheels? I searched ye olde interwebs, didn't find a clear :) answer. So I would guess it just needs to be removed? Here's a pic:
  14. Oct 20, 2023 at 12:05 PM
    #5054
    ToyoMafia
    Magic carpet.
    That’s the coating??? Looks like the clear coat coming off!
    to remove coating
    1 decon with a product like IronX
    2 Polish which will be a Ton of fun on wheels
    sask3m, Fotnot and Terndrerrr[QUOTED] like this.
  15. Oct 20, 2023 at 12:33 PM
    #5055
    Terndrerrr
    Music City
    6UR-FE
    Yep, double ceramic coated.
  16. Oct 20, 2023 at 12:39 PM
    #5056
    ToyoMafia
    Magic carpet.
    Most coatings do not stack so what does double mean?
  17. Oct 20, 2023 at 12:50 PM
    #5057
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    Sure doesn't look like a ceramic coating. As others have said thats a clear coat that has been sprayed.
  18. Oct 20, 2023 at 12:51 PM
    #5058
    Thats not ceramic man. Hopefully you didnt purchase a wheel with this defect, and this is what they said it was.
  19. Oct 20, 2023 at 12:58 PM
    #5059
    Terndrerrr
    Music City
    6UR-FE
    Here's the FS thread. It seems it's just an aftermarket spray coating, not ceramic. Look at the center caps in that first pic. You can tell they've been sprayed.
    T-Rex266[QUOTED][OP] likes this.
  20. Oct 20, 2023 at 1:01 PM
    #5060
    Opened and posted, but he hasnt been on since July.
  21. Oct 20, 2023 at 1:01 PM
    #5061
    ToyoMafia
    Magic carpet.
    I’d take the wheel to a restoration shop. Unfortunately I call BS on his FS thread.
  22. Oct 20, 2023 at 1:26 PM
    #5062
    Terndrerrr
    Music City
    6UR-FE
    Maybe it's not ceramic, but they definitely look like they were sprayed with some kind of aftermarket coating. My other set of Pro wheels look like what this set looks like under the peel.
    Look at this center cap; this is the bottom left wheel in his first pic in the FS thread. Whatever he coated the wheels with is bubbling up there, too:
    Thanks for the help; I knew these wheels would take some work. Just want to know what I'm working with!
  23. Oct 20, 2023 at 1:45 PM
    #5063
    ToyoMafia
    Magic carpet.
    I think they were sprayed with clear coat or the original finish has failed.
    @Ckatz53 might be able to give another opinion.
  24. Oct 20, 2023 at 2:06 PM
    #5064
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
  25. Oct 21, 2023 at 5:03 PM
    #5065
    Ckatz53
    Ckatz53 Newish
    MD
    Hard to tell from the picture, bit grainy on my end. I'd have to agree with @ToyoMafia. Detailing coatings don't actually create a "peelable" layer like what I see there. Either the OEM finish (maybe cleared? Unfamiliar) is degraded or someone refinished them with cheap clear. Bubbling like that looks like cheap 1k clear to me and not a two part paint.
  26. Oct 21, 2023 at 8:19 PM
    #5066
    Tundra1D6
    Another day looking for scraps landed me with some Sun visors.
    I’ve always been told never touch a headliner and sparingly get hands with the visors.
    How do I clean these and what do I need to buy from Wally World or a local auto parts store?
  27. Oct 21, 2023 at 8:20 PM
    #5067
    Could use a steamer
  28. Oct 21, 2023 at 8:28 PM
    #5068
    ToyoMafia
    Magic carpet.
    My wife flips the visor down all the time to use a mirror. It drives me nuts.
    Markus and T-Rex266[OP] like this.
  29. Oct 21, 2023 at 9:58 PM
    #5069
    Ckatz53
    Ckatz53 Newish
    MD
    Any carpet clean should do well enough. Or APC 30:1 (I use 3D all purpose).
  30. Oct 22, 2023 at 9:01 AM
    #5070
    coTony
    Tony
    Montrose, CO
    I am looking for a way to remove dog hair from our Tundra carpets. I have 2 white dogs that are 50lb and 62lb and OMG do they shed.
    After each offroad outting I come home and roll down all 6 windows, open all doors and use my leaf blower and get under the hood and all through the interior. Never takes long just have to remember to get everything that may blow out first but get used to that. This just gets the loose hair but then after the vacuuming there is dog hairs all inside the carpet hairs and takes forever (each day picking them when I see them). There has GOT to be a better way... I hope
