Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. May 12, 2022 at 12:07 PM
    #4471
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Our go to has always been Meguiar's Flagship, advertised at a season worth of protection. Recently we have been testing Jescar Powerlock as it's a polymer sealant that apparently does better on gel coat/fiberglass substrates. So far so good...can't go wrong with either.
    You wanna go big pickup some Undrdog Marine and coat it!
  2. May 12, 2022 at 2:07 PM
    #4472
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    have you tried griots 3in1 on a trailer/rv?
    ToyoMafia likes this.
  3. May 12, 2022 at 3:58 PM
    #4473
    Ckatz53
    Ckatz53 Newish
    MD
    I haven't. I've tried Meguiar's Hybrid Ceramic and it seems to do fine but haven't seen that RV back in a minute so couldn't give you any idea on durability of a ceramic wax product on those vehicles.
  4. May 12, 2022 at 4:30 PM
    #4474
    Danimal86
    Daniel
    Sacramento, CA
    Cool thanks!
    I've got about 4 bottles of 3 in 1 on the shelf (store was closing and i cleared them out), so i'll probably give that a try.
    I did a quick search and griots said its safe for rv/trailers, they just said it needs the 24hr cure time above 50deg in no humidity.
    I'm really tempted to get that underdog marine, its steep though
  5. May 12, 2022 at 8:03 PM
    #4475
    Ckatz53
    Ckatz53 Newish
    MD
    Pricey but I've had great results. Worth it!
  6. May 18, 2022 at 10:11 AM
    #4476
    Rocko9999
    Rocko9999 New Member
    What is a cheaper plastic protectant that lasts more than a couple washings? Someone recommended Ice Spray Wax.
  7. May 18, 2022 at 10:13 AM
    #4477
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    a few of us have used and loved cerakote. it's fairly cheap, typically will last about a year or more, can pick up at walmart or Amazon, and is pretty easy to use (assuming you follow directions @War Machine :boink:).
    i've used it on 3 different vehicles and loved it! it's suggested in bottom in the "products discussed" box
    ToyoMafia and War Machine like this.
  8. May 18, 2022 at 10:16 AM
    #4478
    Rocko9999
    I have used that on my Corolla with limited success. Was a bit splotchy for my taste. Could have been user error.
    ToyoMafia and Fotnot[QUOTED] like this.
  9. May 18, 2022 at 10:21 AM
    #4479
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    only time i've personally noticed splotchy applications was where i was trying to make a wipe stretch too far. i think tyipcally 1 pack of wipes it says will do a vehicle, maybe 2. i can't remember. again, thats my personal experience.
    I dunno if you're sure if all oils were removed from the plastic surface either. i thought i remember someone saying they used some kind of oil based trim shine kinda stuff and didn't do a good job stripping it out/off.
    idk though, it may not be for everyone
    ToyoMafia and Rocko9999[QUOTED] like this.
  10. May 18, 2022 at 12:33 PM
    #4480
    Ckatz53
    Ckatz53 Newish
    MD
    Solution Finish is awesome. It's a dye so be careful.
    War Machine, PKFan and ToyoMafia like this.
  11. May 18, 2022 at 12:41 PM
    #4481
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I just used underdog pro on all the black plastic on the FJ and it seems to work very well.
    War Machine likes this.
  12. May 18, 2022 at 12:42 PM
    #4482
    ToyoMafia
    Magic carpet.
    Wear rubber gloves
  13. May 18, 2022 at 1:16 PM
    #4483
    Runway
    Runway New Member
    Kenneth
    Houston, Texas
    2016 White Tundra 1794
    That is good advice. I messed up a brand new pedicure using that stuff
  14. May 22, 2022 at 7:03 AM
    #4484
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Need some thoughts on this faded old black trimming around top and trunk. It shines up with a compound and mf applicator pad. Just looking for anything that would make it a speedier process?
    Some of its metal, plastic, aluminum.
    Does someone make a stiff fucking q-tip with an applicator pad on the end? Lol. They need to
  15. Jun 1, 2022 at 4:37 AM
    #4485
    War Machine
    War Machine SSEM # 5 3MW
    Cerakote will work on both the plastic and metal portions. As always, follow directions perfectly and be careful. If you mess it up, it’s going to stay that way indefinitely. No room for error with this product, but if you get it right you’re good for at least a year.
    If you want to take a more forgiving approach, Solution Finish or Shine Supply Trim Shield are great for plastic. Other than Cerakote I haven’t found anything that will make faded metal look good again for more than a week at most.
    As for applicators, there are products like this, but they are made for dusting or cleaning nooks and crannies in the interior. Not sure if they would be effective applying product or not.
    TucsonTundra1794 and ToyoMafia like this.
  16. Jun 8, 2022 at 5:47 AM
    #4486
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Thanks, I thought about solution finish too. Seems like it'd be easier and last longer to just pull these small parts, repaint and clear them... Just trying to help a friend out for a more permanent solution. The front plastic grill vent is the same and it'd take forever to clean and coat.
    Fotnot and ToyoMafia like this.
  17. Jun 8, 2022 at 3:56 PM
    #4487
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    Carpro Dlux. Works well and is easy to work with.
  18. Jun 8, 2022 at 3:58 PM
    #4488
    ToyoMafia
    Magic carpet.
    I’d go with underdog pro over dlux. I’ve tried both but UDP out performs In every way
    Ckatz53, Hi06silver and Ace96[QUOTED] like this.
  19. Jun 8, 2022 at 4:02 PM
    #4489
    Ace96
    Ace96 New Member
    Western KY
    On black plastic? Good to know. Planning on trying it on my Tundra
  20. Jun 15, 2022 at 4:53 PM
    #4490
    T-Rex266 [OP] Fuck Cancer Staff Member
    Any greatest and latest glass cleaners?
  21. Jun 15, 2022 at 4:56 PM
    #4491
    ToyoMafia
    Magic carpet.
    Glass is still a pain. Spray away works great so does invisible glass. If you need to get rid of water spots.. liquid barkeepers friend and a scotch pad.
    T-Rex266[QUOTED][OP] and Ace96 like this.
  22. Jun 16, 2022 at 1:24 PM
    #4492
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    On the glass topic, Once every year or two I take about a teaspoonful of cornstarch in maybe a cup of water and use it to wash the inside of my windshield (non tinted) seems to polish the crap off that many cleaners don't get. Makes the glass much eaiser to keep clean. Does anybody do this? Any harm being done?
  23. Jun 16, 2022 at 1:34 PM
    #4493
    ToyoMafia
    Magic carpet.
    I don’t do this but I can’t imagine it causes damage. My favorite glass cleaner for interior is Blackfire glass if it drips on the dash it doesn’t seem to leave marks afterwards
  24. Jun 17, 2022 at 2:29 AM
    #4494
    Chris001
    Chris001 New Member
    Ontario, Canada
    2018 Tundra Double Cab SR5
    LED interior, tint, auto lock tailgate, Rhino Liner, Blacked out emblems
    My go to is a magic eraser with CarPro eraser on it to clean the inside of the windshield twice a year. Worked great on my wifes new Corolla, (there was some residue on the inside and this removed it with ease!).
  25. Jun 20, 2022 at 1:57 AM
    #4495
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    What polish and pads should I look at for 2 black paint vehicles that have plenty of swirls in the paint? I’ve never done anything more than just wash, claybar, and wax. Currently using honeydew wash and griots 3 in 1 ceramic wax.
  26. Jun 21, 2022 at 6:01 AM
    #4496
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Try and get some pictures posted up and you're going to get some better replies.
    Are you doing it by hand or using a machine?
  27. Jun 21, 2022 at 7:23 AM
    #4497
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    What’s the best stuff to keep my new Clazzios looking good and clean? Never had leather before.
  28. Jun 21, 2022 at 7:58 AM
    #4498
    Stanky10
    Stanky10 New Member
    Stanky
    W Columbia SC
    2019 MGM Tundra TRD Sport
    3/1 leveling kit with 295/60/20 Nitto Ridge Grapplers, Go Rhino Dominator D6 step rails, Husky X-Act floor liners (front and back).
    Anyone recommend a good detail garage around West Columbia South Carolina
  29. Jun 21, 2022 at 8:02 AM
    #4499
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Scroll down to the bottom of the page. You'll find lexol down there. It's good stuff. I have some voodoo leather conditioner that I like. I personally don't have leather but I use it when needed on others cars. Never had clazzios either, you may wanna see what they suggest about cleaning in the paperwork just to be safe if their is any warranty to be had.
  30. Jun 21, 2022 at 8:57 AM
    #4500
    briarpatch
    briarpatch New Member
    My wife's Yukon has leather seats......I switched to Chamberlains Leather products a while ago and have never looked back
    nhw544[QUOTED] likes this.
