Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Apr 19, 2022 at 4:41 PM
    #4441
    briarpatch
    briarpatch New Member
    Maybe it was in an earlier post....but what issue/problem were you trying to fix?
    ToyoMafia likes this.
  2. Apr 19, 2022 at 5:16 PM
    #4442
    Rocko9999
    Rocko9999 New Member
    Still trying to remove slight must smell from the seats. Visibly look clean but they have a slight must mixed with a few old air freshener bombs. I feel like there is no end to pulling out dirty water with these seats. First tank and 5th tank on the same seat.
    NUDRAT and ToyoMafia like this.
  3. Apr 19, 2022 at 6:00 PM
    #4443
    808Tunderer
    808Tunderer New Member
    2021 DubCab SR5 4x4 TRD Offroad
    Stock
    Anyone use optimum no rinse and distilled water for windshield wiper fluid? Think it’s safe?
  4. Apr 19, 2022 at 6:46 PM
    #4444
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    This may or may not help...try spritzing vodka. Watched a cleaning guru guy on Ryan and Kelly show the other day. Said it would take out the smell of campfire on clothes. Could be worth a shot just don't use the whole bottle you may need it if it doesn't work
    ToyoMafia and Rocko9999[QUOTED] like this.
  5. Apr 19, 2022 at 6:51 PM
    #4445
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Interesting concept…
  6. Apr 20, 2022 at 4:11 AM
    #4446
    briarpatch
    I'm hoping CKatz53 will chime in on this one. In my experience, the Bissell machine is good for a lot of things, but legitimate deep extraction is not one of them. It simply does not have enough 'water lift'. Topical stains are one thing...those have became deeply embedded in the padding are another.
  7. Apr 20, 2022 at 5:31 AM
    #4447
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    needing a new wash mitt soon. any suggestions of ones to get and/or stay away from? both my vehicles are coated if that makes much difference.
  8. Apr 20, 2022 at 8:06 AM
    #4448
    briarpatch
    These are the ones that I buy. So far I've been very happy with them:
    ToyoMafia and Fotnot[QUOTED] like this.
  9. Apr 20, 2022 at 9:56 AM
    #4449
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    I missed the origination of this. Did the musty smell originate from cleaning it or was the smell there before and you were attempting to remove it? And it seems no matter how much you extract it keeps pulling dirty water up?
  10. Apr 20, 2022 at 12:40 PM
    #4450
    Rocko9999
    Truck was a heavily soiled/used construction work truck. Interior smelled of dust/dirt. I attempted to clean them best I knew how but apparently left some of the seats damp and for the last year there has been a slight must/dirt smell. I think the two Meguiars foggers only made it worse. I have tried my ozone machine with limited results.
  11. Apr 20, 2022 at 12:49 PM
    #4451
    Ckatz53
    Ckatz53 Newish
    MD
    Heavily used work truck I'd expect you'd have to remove the carpets/any padding and pressure wash and leave out to dry. The Bissell is good but only for surface contamination. Anything deeper you'd need a heated commercial unit like a mytee. Expensive and won't guarantee results for something heavily used. If you don't want to remove seats and carpet, try red solo cups filled with baking soda...It's a bandaid on a broken arm but might help over time (shake them up periodically). Also try sprinkling the carpet with Armor All pet odor elimator powder meant for the house and let it sit for a few hours and vacuum it up. Again...these are more than likely temporary fixes as you haven't removed the source of the issue but is less invasive/time consuming.
    Rocko9999[QUOTED] and ToyoMafia like this.
  12. Apr 20, 2022 at 1:34 PM
    #4452
    Rocko9999
    Thanks. Carpet has come out, was pressure washed. No smell from the carpet. The seats even after the last cleaning this weekend still have slight lingering odor. I have sensitive nose too which doesn't help. I guess at some point I will run out of steam-no pun intended and just live with it. I am considering taking the oem covers of the seats, wash them in a commercial washing machine and only reinstall when the smell is gone. Not sure how much smell is in the foam padding though. May be wasted effort.
  13. Apr 20, 2022 at 1:49 PM
    #4453
    Ckatz53
    Ckatz53 Newish
    MD
    Yeah I'd venture to say the culprit is the seat foam then if you've pulled the floor and let it air dry in the sun after washing. In that case you can pressure wash those too if you pull the covers but its likely to remain. With anything detailing related nothing is 100% and never will be short of a 0 mile factory car (and most likely even then there are issues lol).
    Try the carpet powder and baking soda in cups trick. Distilled vinegar 2:1 in a spray bottle when extracting can help to neutralize smells as well....but then you're dealing with waiting for vinegar smells to dissipate which I think is worse sometimes lol.
    Rocko9999[QUOTED] likes this.
  14. Apr 21, 2022 at 7:52 PM
    #4454
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    "Son - you been drinking tonight?"
    No officer, that's my seat cleaning trick. :bananadead:
    Rocko9999 likes this.
  15. Apr 22, 2022 at 5:23 AM
    #4455
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    LMAO. Well played...I'm serious it was on TV. It's probably a temp fix if it's real bad but what else ya gonna do with that crap? Ain't worth drinking.
    NUDRAT[QUOTED] likes this.
  16. Apr 22, 2022 at 9:46 AM
    #4456
    Rocko9999
    Tried vinegar early on with the carpet-the smell never really dissipated until I pulled it and pressure washed.
    I am leaning towards Cl02 treatment after I give the seats another go and try to extract more dirt.
  17. Apr 22, 2022 at 10:40 AM
    #4457
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    I've used @Ckatz53 pet carpet sprinkle and baking soda in a cup method on a really trashed Corolla. I mean this thing was a biohazard. It did lessen the smell and held up well the next time I saw the car in a few weeks I took a whiff. So it helps but I don't know that it will totally ever remove it like he said.
    Ckatz53 likes this.
  18. Apr 22, 2022 at 4:58 PM
    #4458
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Say, I impulse bought some 303 Salt Wash. Seemed a good thing to do in the spring to the under bits.
    Anyone used this, have any pointers to using it best?
  19. Apr 22, 2022 at 6:25 PM
    #4459
    Ckatz53
    Ckatz53 Newish
    MD
    Yeah sometimes that smell takes ages to fan out. Unfortunately I learned long ago that in this venture there is no such thing as perfect and some things just aren't doable. Can't tell you how many 3 hour jobs turned into 8 hours because I couldn't let something go. Now I know those things I couldn't let go were actually never fixable from a detailing perspective...the things you learn lol.
    ToyoMafia and Hi06silver like this.
  20. Apr 25, 2022 at 8:08 AM
    #4460
    Rocko9999
    I totally get that. I have that personality and have tried to learn to 'live with' things instead of wasting countless man hours. It's not unlivable as it is, just enough to bother me. I have one final push and then I am closing this chapter lol.
    Ckatz53[QUOTED] likes this.
  21. May 2, 2022 at 12:17 AM
    #4461
    Oey12
    Oey12 New Member
    Joey
    New York
    I have a water spot question…
    My truck was professionally ceramic coated and typically I only use ONR or CarPro ECH2O with distilled water for my wash’s. Mostly spray and wipes with the occasional two bucket method thrown in. But due to an injury I have been unfortunately using this local hand wash that does a great job BUT the use regular water which I find is leaving hard water spots.
    I am going for my yearly “refresh” soon and will probably have them removed but what is suggested to remove such stains that is safe for ceramic?? I have to go for surgery soon so my truck is going to the hand wash place more often than normal (I get lazy and use them when it’s extremely cold/salty). And eventually I would like to remove them on my own.
    Thanks!!
  22. May 2, 2022 at 3:47 AM
    #4462
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Hey @Ckatz53 i was going to suggest WSP have you had experience with this product yet?
    Ckatz53 and Oey12[QUOTED] like this.
  23. May 2, 2022 at 6:35 AM
    #4463
    Ckatz53
    Ckatz53 Newish
    MD
    @Oey12 Undrdog WSP is great for removing water spots and is coating safe (although you don't want to use any company's water spot remover regularly as it is acidic and will cause premature degradation of any coating).
    If you're in a pinch, distilled vinegar diluted 4:1 works well enough.
    What coating do you have applied if you don't mind me asking? Certain coatings are better than others at preventing water spots from becoming permanent. There is not a single coating on the market that won't water spot in one form or another....the key is how easily they come off. A good coating will remove water spots upon a simple contact wash with soap and a microfiber mitt.
    Oey12 and ToyoMafia[QUOTED] like this.
  24. May 2, 2022 at 9:13 AM
    #4464
    Oey12
    Oey12 New Member
    Joey
    New York
    Pardon my grammar, I am literally in the post recovery room. Ya think I am a little addicted to my Tundra??? LOL!!
    The company I use was Expel. The responds are much appreciated.
    Ckatz53 and ToyoMafia like this.
  25. May 2, 2022 at 9:21 AM
    #4465
    ToyoMafia
    Magic carpet.
    Addicted to tundras never happens. :anonymous:
    Oey12[QUOTED] and Fotnot like this.
  26. May 2, 2022 at 9:38 AM
    #4466
    Ckatz53
    Ckatz53 Newish
    MD
    Ahh so Xpel Fusion Plus? I haven't seen much about it in the real world application outside of internet reviews. Not many Xpel installers around here. So, I can't speak on how good it is and if the water spots will come off with a waterspot remover or if they may be baked in. If you try waterspot remover, again I recommend Undrdog WSP, and it doesn't work then that means they've baked in and etched meaning they would need to be polished off and the coating reapplied.
    ToyoMafia and Oey12[QUOTED] like this.
  27. May 2, 2022 at 10:02 AM
    #4467
    Stanky10
    Stanky10 New Member
    Stanky
    W Columbia SC
    2019 MGM Tundra TRD Sport
    3/1 leveling kit with 295/60/20 Nitto Ridge Grapplers, Go Rhino Dominator D6 step rails, Husky X-Act floor liners (front and back).
    What can I use to get tar off the inner fender plastic liners
  28. May 2, 2022 at 10:47 AM
    #4468
    Ckatz53
    Ckatz53 Newish
    MD
    Stoner's Tar and Sap Remover.
  29. May 2, 2022 at 10:56 AM
    #4469
    Stanky10
    Stanky10 New Member
    Stanky
    W Columbia SC
    Thanks
    Ckatz53[QUOTED] and ToyoMafia like this.
  30. May 12, 2022 at 7:40 AM
    #4470
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Whats the lowdown on protecting a travel trailer?
    We just upgraded our trailer to this guy:
    Whats the low down on paint protection? We plan on covering when not in use, but i would like to get some uv protection on there.
    I remember hearing that @Ckatz53 was the man for the question?
