Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Oct 17, 2021 at 4:19 PM
    #4261
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    It definitely has. Ordered some CarPro spotless as you suggested - I’ll see where that gets me. Thanks for the rec.
  2. Oct 17, 2021 at 4:21 PM
    #4262
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Most dedicated water spot removers are just diluted acid. A strong wheel cleaning acid will work better but have to be careful with them. Make sure the panel is cool, don't do it in sunlight, work it in gently with a soft microfiber, and wash it off.
    ToyoMafia likes this.
  3. Oct 17, 2021 at 5:14 PM
    #4263
    briarpatch
    briarpatch New Member
  4. Oct 20, 2021 at 1:13 PM
    #4264
    War Machine
    War Machine SSEM # 5 3MW
    Pretty good comparison of several methods. Wheel acid seems to be the fastest, confirming what @Ckatz53 said. I’ve had better luck than they did with MDR though.
    https://youtu.be/SNPtBeyOlNA
  5. Oct 20, 2021 at 1:18 PM
    #4265
    War Machine
    Both great options.
    I’ll add Shine Supply Trim Shield to this. It is the most expensive option though.
  6. Oct 23, 2021 at 4:04 PM
    #4266
    Ni-Ju-Ni
    Ni-Ju-Ni New Member
    2018 White Tundra Platinum 4x4
    Question: I have a white tundra and I can't seem to get the black exhaust residue off the paint. Any suggestions?
    GODZILLA likes this.
  7. Oct 23, 2021 at 4:08 PM
    #4267
    Ckatz53
    Ckatz53 Newish
    MD
    Honestly never had to deal with that before. I would assume try a clay bar and/or iron remover and see what it does. If not, an acid or mineral spirits as that typically handles the worse off stuff (just be careful) we have come across. May need to resort to polishing as a last step after trying the aforementioned. I'd be interested in what some of the more experienced folks in here would venture to say.
    War Machine and Ni-Ju-Ni[QUOTED] like this.
  8. Oct 23, 2021 at 5:08 PM
    #4268
    briarpatch
    I've never had this issue with my Tundra, as the stock exhaust exits far enough away and pointed down. I think the answer you got from CKatz is spot on....I can not think of anything else to try anyway. The only suggestion I'd have would be to put on some PPF once you get the area clean...even though I hate PPF. As a shorter term fix, you could always use track tape....although I think you'd probably go through a lot of it.
    Ni-Ju-Ni[QUOTED] likes this.
  9. Oct 24, 2021 at 11:55 AM
    #4269
    Ni-Ju-Ni
    Ni-Ju-Ni New Member
    Thanks, I will give it a try
    Ckatz53[QUOTED] likes this.
  10. Oct 24, 2021 at 11:55 AM
    #4270
    Ni-Ju-Ni
    Ni-Ju-Ni New Member
    Thanks!
  11. Oct 25, 2021 at 9:48 AM
    #4271
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    What’s the best way to clean the rubber pieces that the windows slide on? Every time I roll my windows down and back up, that piece leaves them streaky as hell. Infuriating after I’ve spent time cleaning the windows.
  12. Oct 25, 2021 at 12:29 PM
    #4272
    Ckatz53
    Ckatz53 Newish
    MD
    Roll the windows all the way down and use a toothbrush. Spray it with APC and scrub the seals inside then wipe with a microfiber. The rear windows on my crewmax stays slightly above the seal. I just pry it back with a plastic trim pry tool and clean the same way. Almost impossible to get completely clean without taking the seal out though. There's stuff you can't reach where dirt will build up and cause streaking. I've got 5% tint and everything shows on my windows so I've just learned to live with it....always got my windows down too lol.
    defaint, nhw544[QUOTED] and ToyoMafia like this.
  13. Oct 25, 2021 at 1:00 PM
    #4273
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Just bought a bottle of the Shine Supply Classy Chassis. Can’t wait to use it in 8 months or so.
    Definitely going to detail the truck again when I get back. Don’t know how the truck is going to fair when I start overland camping in it (about to order the AT Overland Summit topper for it)
    ToyoMafia[QUOTED] likes this.
  14. Oct 25, 2021 at 1:06 PM
    #4274
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I really like classy chassis it smells so damn good. It doesn’t last a long time but it sure makes the underbody look real good after a full detail. Just don’t let it drip on the driveway or you’ll hear it from ur significant other.
  15. Oct 25, 2021 at 1:07 PM
    #4275
    Damie Street
    Edsel
    South Carolina
    How do you normally apply it? @ToyoMafia
  16. Oct 25, 2021 at 1:08 PM
    #4276
    Damie Street
    Edsel
    South Carolina
    Also any new great products I should look into? @ToyoMafia
  17. Oct 25, 2021 at 1:22 PM
    #4277
    ToyoMafia
    Magic carpet.
    I just mist the stuff. I don’t even wipe it
    Damie Street[QUOTED] likes this.
  18. Oct 25, 2021 at 1:23 PM
    #4278
    ToyoMafia
    Magic carpet.
    I’ve been using hydro2 once a month for the past 6 months and I freaking love it.
    War Machine likes this.
  19. Oct 25, 2021 at 1:30 PM
    #4279
    Damie Street
    Edsel
    South Carolina
    What product did you replace for it? 3in1 wax?
  20. Oct 25, 2021 at 1:31 PM
    #4280
    ToyoMafia
    Magic carpet.
    I use 3-1 twice a year
  21. Oct 25, 2021 at 1:33 PM
    #4281
    Damie Street
    Edsel
    South Carolina
    Do you use the Hydro2 after each time you wash your vechs now?
  22. Oct 25, 2021 at 1:35 PM
    #4282
    nhw544
    nhw544 Food fight!
    RVA
    Appreciate the help! Excuse my ignorance though, what is APC?
  23. Oct 25, 2021 at 1:36 PM
    #4283
    Damie Street
    Edsel
    South Carolina
    All-Purpose Cleaner
    ToyoMafia and nhw544[QUOTED] like this.
  24. Oct 25, 2021 at 1:40 PM
    #4284
    ToyoMafia
    Magic carpet.
    I try and wash my truck once a week during our dry months but summer that’s not possible so I apply it once a month
  25. Oct 25, 2021 at 1:43 PM
    #4285
    Damie Street
    Edsel
    South Carolina
    Do you apply to a wet truck or after you dry it? I know your suppose to mist after applying the product.
    last question. Haha.
  26. Oct 25, 2021 at 2:01 PM
    #4286
    ToyoMafia
    Magic carpet.
    Wet.
  27. Oct 25, 2021 at 2:22 PM
    #4287
    Ckatz53
    Ckatz53 Newish
    MD
    APC. We go through gallons of Simple Green from Home Depot. Diluted 50:1 should work fine for your seals.
    nhw544[QUOTED] likes this.
  28. Oct 25, 2021 at 3:19 PM
    #4288
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    Do you use the green or purple (HD) version?
  29. Oct 25, 2021 at 3:21 PM
    #4289
    Ckatz53
    Ckatz53 Newish
    MD
    Green. I think purple is a degreaser if I'm not mistaken.
  30. Oct 26, 2021 at 5:05 AM
    #4290
    War Machine
    Wash the truck and rinse it off. While it is still wet, spray the product on about a section at a time, wait about 30 seconds, and rinse it off. Start with the roof and work your way down. Just don’t do too much at a time, because you absolutely do not want it having a chance to dry on the vehicle.
    While you’re doing it, keep misting the rest of the truck so the water / Hydro2 doesn’t dry and leave spots. Keep in mind that some product will runs down on other panels while you’re doing it. Key is to not let the vehicle dry on its own during the process.
    Once you’ve done all panels (while keeping the rest wet), go over the whole thing one more time.
    You don’t need to use much. Just a light mist over the paint. Follow the dilution instructions on the bottle. I think it’s 6:1. A bottle of this will last you quite a while.
    Once you get the routine down, there’s nothing easier. It doesn’t add gloss, so you can follow up with a spray wax or something later. (Beadmaker works great with Hydro2.)
    I couldn’t find a great video on how to apply. Most of the ones I looked at used way too much product. It won’t hurt, but it’s a waste of money. This is probably the best one if you don’t mind Pan’s chatter.
    https://youtu.be/d1beB0P4sOM
    Damie Street[QUOTED] and Fotnot like this.
