Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Mar 22, 2021 at 11:55 AM
    #3571
    War Machine
    War Machine SSEM # 5 3MW
    Welcome back. Still using Iron X, but Shine Supply Smooth Move works about as well and smells better.
    ToyoMafia likes this.
  2. Mar 22, 2021 at 12:04 PM
    #3572
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    Yeah the stuff just works. I am always up to try new things though. Maybe I should just order a gallon
  3. Mar 28, 2021 at 1:53 PM
    #3573
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I've been trying to gather the items that were mentioned to me for keeping my exterior clean and I wanted to see if there was a go to set of products for the interior? I've used 303 before and really like it but if someone knows of something better I'd be open to try it.
  4. Mar 28, 2021 at 2:35 PM
    #3574
    cmiller219
    Nashville, TN
    I use Nextzett cockpit premium. It cleans and protects and leaves no shine. Are you looking for a shine?
    every once in a while I’ll hit everything with some In and Out but it’s expensive and not necessary
  5. Mar 28, 2021 at 2:46 PM
    #3575
    TucsonTundra1794
    Anthony
    Tucson, AZ
    No shine just want to clean and protect the plastic. Black plastic in black cars in AZ heat I want to do everything I can to keep it looking good.
  6. Mar 28, 2021 at 3:11 PM
    #3576
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Although I always have an eye out for something new I think 303 is one of the better products out there. No shine, doesn't attract dust, protects VERY well. It's been around a long time and has a great reputation.
    Having said that, I'm a product of the 70's where we used Armor All by the gallons. Spayed that crap on EVERYTHING!
    Times do change.
  7. Mar 29, 2021 at 3:50 AM
    #3577
    War Machine
    I like Clean N Shine from Shine Supply when I want to leave a little pop to the interior. When I’m just cleaning, I generally just use Eco Shine or ONR.
  8. Mar 29, 2021 at 11:43 AM
    #3578
    Saltyhero13
    Saltyhero13 Throbbing Member
    The Iron X snow foam that I tried is not as strong as the Iron X spray. I tested this by spraying Iron X after foaming and it would still react after applying the foam. On it's own it is also more aggressive than Reset and will remove a lot of the spray on waxes and sealants.
    War Machine[QUOTED] likes this.
  9. Mar 29, 2021 at 12:14 PM
    #3579
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Replace or sand and paint or sand and wrap
  10. Mar 29, 2021 at 12:17 PM
    #3580
    18" TRD Off Road Wheels
    You can peel it off. Lots of people prefer the look without it. It's painted underneath. If you don't like it without it, you can get replacements from Toyota.
  11. Mar 29, 2021 at 12:23 PM
    #3581
    I'm not certain on that. Mine are still intact. I just know that others have removed them. I think @RainMan_PNW removed his?
  12. Mar 29, 2021 at 1:05 PM
    #3582
    ToyoMafia
    Magic carpet.
    There will be a huge difference between pulling that stuff off on a 2014 and a 2021. If Casey did pull his off it was probably pretty easy. The 2014 will be a mission I’m guessing especially if it is already failing. I’m thinking a 3m adhesive wheel may be needed and that takes a special touch so you don’t mess up the paint but if your re wrapping it won’t matter to much.
    War Machine likes this.
  13. Mar 29, 2021 at 3:13 PM
    #3583
    Saltyhero13
    +1 to 3M Wheel for adhesive removal. Make sure you keep the wheel very clean from abrasives and you won't jack up the paint. I've used these aggressively without any marring but as always with any paint work test a small area first before going all brute with it.
  14. Mar 29, 2021 at 3:43 PM
    #3584
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Start with a hair dryer on hot and a fingernail. If you open the door and look on the inside edge at the top, you'll see how it just barely wraps around and then stops. You can get your fingernail under it with some heat to soften it and it will start to pick off. Go slow and be patient. Yes, I'm sure peeling it off after 30 days is going to be easier than after 6-7 years, but I'd at least give that a try first before resorting to any sort of wheels. It's a lot of surface area, but if you keep it warm it comes off pretty easy. Hardest part was along the bottom corner where the lower window trim extends across. I had no residue left behind, and it is fully painted underneath. It is just vinyl wrap - nothing like the 3M foam tape they hold the emblems on...
    As for how it looks - you may have some color difference from 6-7 years of paint fade on the rest of the vehicle compared to behind that vinyl. Once you get it off, the only way to get it back is to buy new and get it applied.
  15. Mar 29, 2021 at 3:57 PM
    #3585
    Saltyhero13
  16. Mar 29, 2021 at 4:10 PM
    #3586
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Welp, some bad news. My Griot's G9 locking mechanism took a dump again. This will be the third unit replaced in about a year of pretty continuous use. For the folks looking for a machine, I highly suggest it regardless. Lifetime warranty so that's a plus, however my uses for it far exceed the weekend warrior machine that this was designed for. I'm stepping up to a Flex 3401. Will still be using the G9 for the smaller areas.
  17. Mar 30, 2021 at 4:10 AM
    #3587
    War Machine
    I wouldn’t worry too much. Use the tips given above. I’d suggest trying Goo Gone before an eraser wheel. Those work great but it does have a possibility of marring the paint if you’re not careful.
    Worst that can happen is you have to get replacement vinyl and put it on.
  18. Mar 30, 2021 at 4:57 AM
    #3588
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Just ordered a G9. Sounds like it will still work well for my limited use.
  19. Mar 30, 2021 at 7:12 AM
    #3589
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    I ordered Griots, but in the mean time I came across the Jay Leno’s garage stuff. Soap was awesome, and the Polymer...came out better than my old stuff. Thanks @War Machine
  20. Mar 30, 2021 at 9:58 AM
    #3590
    briarpatch
    briarpatch New Member
  21. Mar 30, 2021 at 9:59 AM
    #3591
    briarpatch
    I like their soap.....if you have a Pep Boys nearby......they have it for 5.90 online only.....order it online and pick up in the store
  22. Mar 30, 2021 at 10:00 AM
    #3592
    briarpatch
    Excellent machine.....lifetime guarantee and plenty of power
    81 TOY[QUOTED] likes this.
  23. Mar 30, 2021 at 10:01 AM
    #3593
    briarpatch
    Some big coin there. Let us know what you think of the Flex
  24. Mar 30, 2021 at 10:04 AM
    #3594
    ToyoMafia
    Magic carpet.
    Yeah I think your beyond a G9 at this point. I think you work harder then most machines out there. G9 is great but Flex should kill it for you.
    Ckatz53[QUOTED] likes this.
  25. Mar 30, 2021 at 10:08 AM
    #3595
    Ckatz53
    Ckatz53 Newish
    MD
    Yeah it's pricey but I've got quite a few corrections lined up already this Spring. Should pay for itself fairly quickly.
    GODZILLA and ToyoMafia like this.
  26. Mar 30, 2021 at 10:11 AM
    #3596
    Ckatz53
    Ckatz53 Newish
    MD
    Yeah the G9 really is a great machine and is great for 99% of your hobbyists. I would still recommend it to anyone. That lifetime warranty is clutch hah.
    GODZILLA and ToyoMafia[QUOTED] like this.
  27. Mar 30, 2021 at 10:13 AM
    #3597
    ToyoMafia
    Magic carpet.
    It is. Hands down for anyone wanting to take care of personal vehicles and stretching to friends and family it is perfect. Commercial guys don’t have as much time to have machines down so hopefully stepping up helps that.
  28. Mar 30, 2021 at 10:16 AM
    #3598
    Ckatz53
    Ckatz53 Newish
    MD
    Exactly. Luckily I have the rotary and can whip that out to finish jobs. But I'll hang onto the G9 as a backup in case the Flex fails.
  29. Mar 30, 2021 at 10:20 AM
    #3599
    ToyoMafia
    Magic carpet.
    Sounds perfect that’s a damn nice backup if needed.
  30. Mar 30, 2021 at 12:31 PM
    #3600
    War Machine
    Just throwing this out there, but Shine Supply carries Rupes, and our 10% discount does apply to them. I don’t know how Rupes and the Flex compare, but just wanted to make you aware in case they’re comparable.
    ToyoMafia and Ckatz53[QUOTED] like this.
