Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Mar 13, 2021 at 12:58 PM
    #3451
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Thanks a ton. After about 3 hours of scrubbing, washing and a whole bottle of Meguiar's Iron Removing Spray Clay. A large amount of the noticeable stains are gone. Ordered up a bottle of IronX and try to get as much out as I can, before polishing/sealing. Looks noticeably cleaner and smoother. Still got a long way to go....Huge thanks too all you guys for the advice.
    20210313_124706.jpg 20210313_134220.jpg 20210313_125546.jpg 20210313_134227.jpg
    jpod, tundrasportinMA, drobb and 2 others like this.
  2. Mar 14, 2021 at 5:33 AM
    #3452
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    I’m going to get Carpro Reset, and Griots. Is Griots considered a sealant or do I need 3 products? Soap (carpro), Sealant (brand?), wax (griots)? Appreciate your thread @War Machine and help @Swfltoyomafia
  3. Mar 14, 2021 at 5:46 AM
    #3453
    War Machine
    War Machine SSEM # 5 3MW
    The Griots 3-in-1 would be all you need. It’s a sealant.
  4. Mar 14, 2021 at 5:47 AM
    #3454
    War Machine
    You’ll love Reset. Just pay attention to the dilution ratios. It’s expensive, so you don’t want to waste any. It will go a long way if diluted properly.
  5. Mar 14, 2021 at 11:26 AM
    #3455
    Runway
    Runway New Member
    Kenneth
    Houston, Texas
    2016 White Tundra 1794
    Does Reset work in a foam cannon? I couldn’t really tell from their website.
    ToyoMafia likes this.
  6. Mar 14, 2021 at 11:31 AM
    #3456
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Yes
  7. Mar 14, 2021 at 11:46 AM
    #3457
    briarpatch
    briarpatch New Member
    Works very well out of a foam cannon
  8. Mar 14, 2021 at 12:31 PM
    #3458
    Runway
    Runway New Member
    Kenneth
    Houston, Texas
    I bought a MAATC snow blower for a starter unit. The unit seems well built enough, but not much in the “how to use” department. Now I just need a few days of no rain to experiment with it. We are in a pattern of rain every few day right now in my area.
    War Machine likes this.
  9. Mar 14, 2021 at 1:47 PM
    #3459
    HighonFirewood
    2019 Tundra
    Awesome. Thank you!
  10. Mar 14, 2021 at 3:17 PM
    #3460
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    I'm sure someone else with more knowledge will chime in but I don't think the white trucks were clear coated back then.
  11. Mar 14, 2021 at 4:09 PM
    #3461
    briarpatch
    Didn't Toyota have 2 whites...one single stage and one clearcoated?
  12. Mar 14, 2021 at 5:53 PM
    #3462
    Taco-Blender
    AZ
    2010 DC 4x4
    I really don't know. My kids 1st Gen Tacoma was single stage. I think I've read the white Tundras were single stage too. I'm definitely no expert.
    Someone in the know will let us know.
  13. Mar 14, 2021 at 7:08 PM
    #3463
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Just realized that the 5" pads I got with my backing plate conversion are all griots! After my bitching about soaking up compound. Haven't tried HDO hex logic. Just regular lake country. Where should I go with 5 "? I must have been half in the tank when I ordered the pads
  14. Mar 14, 2021 at 7:13 PM
    #3464
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Apparently it is single stage... Guess ill just try to clean it as much as possible and seal it. Granted, it looks better now that it ever has since I bought it. The haze on the cab was significant, compared to the bed.
  15. Mar 15, 2021 at 4:40 AM
    #3465
    briarpatch
    I'm not familiar with HDO hex logic pads. The only hex logic pads that I know of are sold by Chemical Guys....can you send me a link to what you're referring to? For what it's worth...the CG Hex Logic Quantums are good pads. If you don't want the pads, you can return the kit and just order the backing plate by itself:
    https://www.griotsgarage.com/produc...56bIRezxEagYuGVBhOQb2Xx02Aw3hnjsaAvL2EALw_wcB
  16. Mar 15, 2021 at 4:44 AM
    #3466
    briarpatch
    Pretty simple to use....I typically go with a 10:1 ratio (water to soap).....add 20oz of warm water and then add 2 oz of soap.....mix thoroughly.....attach to pressure washer....keep calm and foam on
    knob on top controls the thickness of the foam.....twisting the nozzle will adjust the fan width of the foam
  17. Mar 15, 2021 at 4:58 AM
    #3467
    War Machine
    You guys think so? I didn’t feel like it actually foamed enough. I think @Pudge had the same experience.
    Pudge and ToyoMafia[QUOTED] like this.
  18. Mar 15, 2021 at 5:03 AM
    #3468
    War Machine
    Yeah, we’re in that rain plus pollen time of year. Everything is just a mess. Three weeks ago we’re freezing, now there’s pollen everywhere. Saw this the other day. You’d probably appreciate it:
    As for the MATCC cannon, it is a bit confusing at first. Main thing that’s weird is you want to move the dial to the “negative” side to get more foam. It’s counterintuitive to say the least. Solid product though. I’ve had mine for several years with no issues. I’ll never recommend an expensive one.
    Also, use warm water in the mixture. Works way better that way.
    Fotnot and ToyoMafia like this.
  19. Mar 15, 2021 at 5:04 AM
    #3469
    War Machine
    Though I haven’t done as much correction as these other guys, I’ve seen the best results with Griots Boss and Uro-Fiber pads.
  20. Mar 15, 2021 at 5:04 AM
    #3470
    ToyoMafia
    Magic carpet.
    I think some of the CG soap worked better but I still had good results with reset but I don’t use a cannon that often.
    War Machine[QUOTED] likes this.
  21. Mar 15, 2021 at 5:06 AM
    #3471
    War Machine
    I only use it as a pre-wash on a really filthy vehicle. CG Honeydew Snow Foam is my favorite when I use it.
    ToyoMafia[QUOTED] likes this.
  22. Mar 15, 2021 at 5:57 AM
    #3472
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Lol. My mistake, I was apparently thought they were the same pad from my readings/ skimming on here. I see the difference now. I'll probably order the hex or lake country that I have in 6". Seems the HDO are designed for long stroke.
  23. Mar 15, 2021 at 9:27 AM
    #3473
    briarpatch
    I think it works well.......keeping it in perspective.....I do not have high expectations with my SunJoe either. Trying to get an Active VE52 pressure washer.....specs are 1800 PSI/2.0 GPM....and its actually pretty close to that.
  24. Mar 15, 2021 at 2:57 PM
    #3474
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Ok detailer came out today. Looking at the exterior he suggest paint correcting on the Front and top, single stage on the rest. For 1 coat of ceramic (lasts 6 months) I'm at 550. Full detail on interior and engine adds another 200. If I want the lifetime ceramic which is 4 more coats we're looking at close to 1300 and again 200 for interior and engine. Price seems right, he said It would take him about 6.5 hours for exterior alone.
  25. Mar 15, 2021 at 4:25 PM
    #3475
    briarpatch
    His price is for Ceramic Pro Sport.....which is a spray ceramic coating. On the up side, once you get it corrected, you can easily do that yourself. What did he think about the pieces under the headlights? There are a ton of spay products out there, like Griot Garage 3 in 1 Ceramic Spray Wax, that will give you 6 months of protection. That package for 550 is not unreasonable.
    ToyoMafia and War Machine like this.
  26. Mar 15, 2021 at 4:30 PM
    #3476
    TucsonTundra1794
    Anthony
    Tucson, AZ
    He was concerned about one. He said he has a pad that might be able to bring it back. The other one wasn't as bad and he said he can get it pretty close to perfect. With the sport package they recommend getting it done every 6 months. But if I'm happy with everything and want to step up to the lifetime package I would just be paying for the ceramic and a wash, the paint correction will hold unless I wait longer then 6 months. He also scared me by showing me a vehicle that he had to remove the ceramic coating from because the last guy put it on wrong. It looked horrible.
  27. Mar 15, 2021 at 4:40 PM
    #3477
    briarpatch
    To me....once you get the correction done......you should be comfortable with DIY products after that. Did he say what the price would be in 6 months when all they are doing is a wash. clay and re-application of the Ceramic Pro Sport?
  28. Mar 15, 2021 at 4:52 PM
    #3478
    TucsonTundra1794
    Anthony
    Tucson, AZ
    He did not but I assume it will only go down slightly, he wanted to make me a repeat customer so he charged me for the wash and sport coat ceramic and only for 1 hour of paint correction but he will be spending longer on it and doing touch ups all over the vehicle. I assume the repeat will be just the 440. Also once I've had a job done they will come out and do touchups as I need them for cheap he said engine would be 30, seats like 35-45 depending on if there were any stains he had to work on. If I run something over and need the paint redone they would also work with me on that. Also if I decide to go with the lifetime I would have to have them come and inspect the vehicle every year and If someone else has cleaned the truck and ruined the coating they are not liable, basically I have to use them for all cleaning from then on.
  29. Mar 15, 2021 at 5:13 PM
    #3479
    Runway
    Runway New Member
    Kenneth
    Houston, Texas
    So do I interpret that to say that you then use Reset when you hand wash?
    BTW: The comment above a Cool 70 or warm 70 was spot on.
  30. Mar 15, 2021 at 5:36 PM
    #3480
    briarpatch
    I understand his position. A friend of mine had a local shop do a full correction and coating, and I offered to do his maintenance washes.....my friend said the installer said something similar to him. Who will be doing the maintenance washes during that 6-month period? My truck would likely get washed 12 times during that span. If I were going for his top of the line package, I might consider their follow-on services. For their 6 month package, I'd get that done and then take it over myself....but thats just me. My truck is not perfect, (I'd give the paint condition a solid 'B') but I find taking care of it very therapeutic.
    You are at a crossroads, sir.
