Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Mar 11, 2021 at 7:22 AM
    #3391
    owb2gp
    owb2gp New Member
    ID
    What speed setting should I use with the G8 for cutting and polishing with a 2 inch pad?
  2. Mar 11, 2021 at 8:25 AM
    #3392
    briarpatch
    briarpatch New Member
    I've not used my G8 for doing any correction....but the lower speeds on it are not particularly useful. Something in the 4-5 range I'd think...although I've also never run a 2-inch pad on mine
    ToyoMafia and War Machine like this.
  3. Mar 11, 2021 at 8:26 AM
    #3393
    briarpatch
    Some solid advice right there
  4. Mar 11, 2021 at 8:34 AM
    #3394
    owb2gp
    owb2gp New Member
    ID
    Thanks!
    ToyoMafia likes this.
  5. Mar 11, 2021 at 9:01 PM
    #3395
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Called a local detail shop just to see what they charge. Clay and ceramic coat would run me $1000, if I need paint correction it would be $2000 is it really that extensive to get my paint back to new?
  6. Mar 12, 2021 at 3:50 AM
    #3396
    War Machine
    War Machine SSEM # 5 3MW
    Some places do charge that much, but you should be able to find someone cheaper. Look for a smaller company. I’d bet a one man shop that’s hungry will do it for less than half of that.
    If you’re inclined to try it yourself, you can get everything you need for probably $400.00- $500.00. That includes a polisher, pads, and chemicals.
    Without the paint correction, the materials to clay and ceramic coat are less than $150.00. (Not accounting for products needed to wash the truck. You’d also need a detail spray to use as clay lube.) Most of the cost is in the labor, and it is a good bit of work to do.
    I would highly recommend a paint correction if you’re doing a ceramic coat though.
  7. Mar 12, 2021 at 8:38 AM
    #3397
    Azblue
    The Dirty T ( ^_^)_且
    BigSkyTaco likes this.
  8. Mar 12, 2021 at 9:37 AM
    #3398
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
  9. Mar 12, 2021 at 10:54 AM
    #3399
    owb2gp
    owb2gp New Member
    ID
    Has anybody attempted to polish plastic trim? I've tried everything on this motorcycle part. Solution finish helped a little. I have SEM trim paint but I've heard this can be polished after some wet sanding.
  10. Mar 12, 2021 at 12:07 PM
    #3400
    briarpatch
  11. Mar 12, 2021 at 12:13 PM
    #3401
    briarpatch
    He gave you these prices without seeing your truck? Did he say what coating he was using? I'd love to be able to get that much for a wash, clay and ceramic coat. I was only getting a fraction of that for a wash with a full decon (clay + iron remover), sealant and basic interior cleaning. My hope is that he was coating the wheels and plastic trim as well.
  12. Mar 12, 2021 at 3:03 PM
    #3402
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Yeah, he wants to come look at it on Monday and give me a better quote to see if I actually need paint correction or not.
  13. Mar 12, 2021 at 3:11 PM
    #3403
    briarpatch
    If he is coming to you, then I say go for it. Hear him out, make sure he takes some time with you. I'd be interested to know what coating he is using.
  14. Mar 12, 2021 at 4:54 PM
    #3404
    TucsonTundra1794
    Anthony
    Tucson, AZ
    On his website it said G9? If that means anything
  15. Mar 12, 2021 at 5:21 PM
    #3405
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Believe it or not I use a heat gun on plastic. With a flat black part like that part, a little heat, and it will turned smooth and shiney. You have to be carefull though. And I don t expect it works on all plastic.
    owb2gp[QUOTED] likes this.
  16. Mar 12, 2021 at 5:37 PM
    #3406
    briarpatch
    whats his website? I need to look this up
  17. Mar 12, 2021 at 5:58 PM
    #3407
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    Thanks for the post. I really need to fix my clear coat. Been watching YT videos...but still starting from scratch.
  18. Mar 12, 2021 at 6:00 PM
    #3408
    briarpatch
    Pun intended?
    Fotnot likes this.
  19. Mar 12, 2021 at 6:15 PM
    #3409
    BigSkyTaco
    Aaron
    W. Glacier, MT
    No...its in my DNA. Comes naturally
  20. Mar 12, 2021 at 6:45 PM
    #3410
    BigSkyTaco
    Aaron
    W. Glacier, MT
    Kinda got the detailing bug after cleaning up the wifes car and the truck this weekend. Fixing the clear coat is kinda intimidating, but i dont think I can make it much too much worse.
    Azblue likes this.
  21. Mar 12, 2021 at 6:52 PM
    #3411
    briarpatch
    You can do it....it ends up being very therapeutic
  22. Mar 12, 2021 at 7:04 PM
    #3412
    BigSkyTaco
    Aaron
    W. Glacier, MT
    My plan was the HF DA polisher and Griots Complete Compound. Working up to the fine pad and then wax/sealer. Gonna clay bar and try to remove all of the grime/dirt this next week. Thank baby Jesus for this tread and YT.
  23. Mar 12, 2021 at 7:20 PM
    #3413
    briarpatch
    Do you know what pads you plan on using?
  24. Mar 12, 2021 at 7:42 PM
    #3414
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Big X2
  25. Mar 12, 2021 at 7:43 PM
    #3415
    ToyoMafia
    Magic carpet.
    IronX makes the claying much easier FYI
    BigSkyTaco[QUOTED] likes this.
  26. Mar 12, 2021 at 7:43 PM
    #3416
    ToyoMafia
    Magic carpet.
    Don’t clay with it just use it before the clay
    Hi06silver likes this.
  27. Mar 12, 2021 at 7:48 PM
    #3417
    BigSkyTaco
    Aaron
    W. Glacier, MT
    No idea...still reading. Any and all suggestions are taken.
  28. Mar 12, 2021 at 7:50 PM
    #3418
    ToyoMafia
    Magic carpet.
    Lake county hdo is what I run currently. Griots boss are great as well. Both @Ckatz53 amd @briarpatch can advise
    Ckatz53 likes this.
  29. Mar 12, 2021 at 7:51 PM
    #3419
    BigSkyTaco
    Aaron
    W. Glacier, MT
    This one? And suggestions for a good clay lube?
    ToyoMafia[QUOTED] likes this.
  30. Mar 12, 2021 at 7:54 PM
    #3420
    ToyoMafia
    Magic carpet.
    I personally love griots speed shine and you can pick it up local. I just ordered griots ceramic speed to try no clue how it will do with clay yet.
