Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Oct 24, 2020 at 10:33 AM
    #3061
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  2. Oct 24, 2020 at 10:38 AM
    #3062
    ToyoMafia
    Magic carpet.
    Sounds about right if the truck is really wet. I have 4 of them. I usually take the truck for a quick ride just to get most the water off then it only takes one towel to finish the job.
  3. Oct 24, 2020 at 2:46 PM
    #3063
    briarpatch
    briarpatch New Member
    The large PFM?
    ToyoMafia and itsmerh85[QUOTED] like this.
  4. Oct 24, 2020 at 3:55 PM
    #3064
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    I generally use 1 large and 1-2 small ones to dry mine (once they're full, I don't wring them out - just put them aside). One other thing to consider is using the hose with no nozzle on it to run water over the surface rather than just the spray nozzle as a final rinse step. You'll find that less water remains, so there's less to have to dry.
  5. Oct 24, 2020 at 4:23 PM
    #3065
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    Yea the large one that’s like $35
  6. Oct 24, 2020 at 4:24 PM
    #3066
    itsmerh85
    Gilbert, AZ
    2020 Black TRDPro
    Ya I skipped that step, it gets dark too damn early now so I was rushing at the end.
  7. Oct 24, 2020 at 6:17 PM
    #3067
    briarpatch
    Have not had that issue with the large PFM. Water is not prone to staying on my truck after a wash, however.....so maybe my situation may not be typical.
    ToyoMafia likes this.
  8. Oct 24, 2020 at 9:22 PM
    #3068
    jtaco11
    jtaco11 New Member
  9. Oct 25, 2020 at 5:48 AM
    #3069
    War Machine
    War Machine SSEM # 5 3MW
    I never have to wring mine out unless doing a second vehicle.
  10. Oct 25, 2020 at 6:04 AM
    #3070
    Istvank11
    Istvank11 Shine On
    AZ
    2016 CM
  11. Oct 25, 2020 at 6:43 AM
    #3071
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    A few thoughts...
    1) do you wash your microfiber towels separate? (you should)
    2) did you use fabric softener? (you shouldn't)
    3) did you put the dryer on high? (you shouldn't)
    Sometimes with the Tundra it does get full of water. Sometimes I use another towel to get the water that is puddling on the truck/car off. Then get the truck bone dry with the Griot's.
    Rica25 likes this.
  12. Oct 25, 2020 at 10:41 AM
    #3072
    itsmerh85
    Gilbert, AZ
    2020 Black TRDPro
    Typically wash all MF rags and towels together. No fabric softener, tumble dry low. I think I just left the truck too wet with a final rinse down before drying. Either way, I now have an ‘excuse’ to buy more stuff
  13. Oct 25, 2020 at 10:56 AM
    #3073
    briarpatch
    To the best of my knowledge...the original spray wax is carnuba only...the best of show spray wax contains polymers as well
    Rica25, jtaco11[QUOTED] and ToyoMafia like this.
  14. Oct 25, 2020 at 11:59 AM
    #3074
    jtaco11
    jtaco11 New Member
    The Griots original spray use after rinse and dry with towel as your drying the car. And Best of Show you use when dry wipe down/buff as normal wax, correct?
    Rica25 likes this.
  15. Oct 25, 2020 at 1:13 PM
    #3075
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    To the detailing gurus: I'm low on CarPro Eraser and need to reup. Obviously I can make my own IPA 50/50 solution but looking more into it, it appears these products have other ingredients meant for cleaning (ex. CarPro Eraser freely admits they put an ingredient in to limit dust accumulation, which is supposed to be used before applying a CP Ceramic).
    My question: has anybody tested any other IPA wipedown products and what your preferences may be? The businessman in me says make my own IPA wipe down to save on cost. But the other products (looking at Meguiar's Surface Prep, $5 cheaper by the gallon, and on sale 20% off at Autoality today) are catching my eye.
  16. Oct 25, 2020 at 3:22 PM
    #3076
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    I like Gyeon Prep. Good stuff. But cost wise make your own imo is the way to go.
    ToyoMafia and Rica25 like this.
  17. Oct 25, 2020 at 5:22 PM
    #3077
    briarpatch
    I'm far from a guru.....but I have to confess I've never used anything but Eraser.....if it ain't broke, I don't fix it
    Rica25, Ckatz53[QUOTED] and ToyoMafia like this.
  18. Oct 25, 2020 at 6:37 PM
    #3078
    War Machine
    I’ve used Eraser and Shine Supply Throwback. Couldn’t tell any difference.
  19. Oct 25, 2020 at 6:40 PM
    #3079
    ToyoMafia
    Magic carpet.
    X2
    Rica25 and Ckatz53 like this.
  20. Oct 26, 2020 at 4:03 AM
    #3080
    Ckatz53
    Ckatz53 Newish
    MD
    Troof, but I've gone through 3 gallons this year and the cost adds up fast if you're using it frequently.
    Rica25 and ToyoMafia like this.
  21. Oct 26, 2020 at 4:05 AM
    #3081
    Ckatz53
    Ckatz53 Newish
    MD
    I picked up a gallon of Meg's Surface Prep for about $15 cheaper than Eraser because of a sale going on. Will let folks know. I'm poor.
    GODZILLA, War Machine, Rica25 and 2 others like this.
  22. Oct 26, 2020 at 9:38 AM
    #3082
    briarpatch
    You're never truly poor as long as you own a Tundra
    GODZILLA, Rica25 and Ckatz53[QUOTED] like this.
  23. Oct 26, 2020 at 11:34 AM
    #3083
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    I have always like the aerosol Sprayway it’s cheap and easy
    Rica25 and NewImprovedRon like this.
  24. Oct 26, 2020 at 11:57 AM
    #3084
    ToyoMafia
    Magic carpet.
    I really like the black fire window cleaner. It’s just expensive. I also use carpro clarify which is also very good.
  25. Oct 26, 2020 at 2:08 PM
    #3085
    CNE0207
    CNE0207 New Member
    Arvada, CO
    Sprayway....I typically get from Walmart for less then $5 a can.
  26. Oct 26, 2020 at 10:38 PM
    #3086
    Rica25
    Ricardo
    Tulare
    Whats the best soap for the foam cannon but that is not crazy expensive?
  27. Oct 27, 2020 at 5:11 AM
    #3087
    War Machine
    That’s what I use.
    ToyoMafia and NewImprovedRon like this.
  28. Oct 27, 2020 at 5:11 AM
    #3088
    War Machine
    Chemical Guys Honeydew Snow Foam.
  29. Oct 27, 2020 at 8:27 AM
    #3089
    briarpatch
    Lots of them.....as previously mentioned.....CG Honeydew snow foam is a very good one, as is P&S Pearl Shampoo, Jay Lenos Vehicle Wash, Meguiars HyperWash, and MTM Perfoamance Soap.
    ToyoMafia and Rica25[QUOTED] like this.
  30. Oct 27, 2020 at 8:27 AM
    #3090
    jtaco11
    jtaco11 New Member
    we bathe our cars better than ourselves lol
    Rica25 and Darkness like this.
