Are all 2gen rear ends set up like this?
Discussion in 'Suspension' started by LibertySand, Mar 25, 2017.
  1. Mar 27, 2017 at 3:16 PM
    LibertySand
    LibertySand [OP] IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    So I just got off the phone with Joey at SDHQ. Good guys. Looks like next week I'll be placing an order on some ICON leaf packs and Camburg hangers to dump my lift blocks. I'll also look into rebuilding my current shocks. The ICON leaf packs come with new U-Bolts also.
    Joey did mention my Overloads looked abused, I admit I have put them to use which is why I'll be adding air bags to the suspension. This brings me to another issue, I'll need to find some fairly unused Overloads. Anyone have a pair that they want to get rid of?
    Should make a nice early Fathers Day Present while doing the Tundra to Sedona 2017 trip, sounds like SDHQ will be at the event.
    TheBeast and Wynnded like this.
  2. Mar 27, 2017 at 3:31 PM
    TheBeast The Beach
    sounds like a plan
  3. Mar 27, 2017 at 3:32 PM
    Yep. You can adjust thrust angle slightly. An axle that is off will shred tires quickly. Trailers can be aligned as well. On cheaper trailers, sometimes extensive work needs to be done.
    15whtrd[QUOTED] likes this.
  4. Mar 27, 2017 at 3:54 PM
    LibertySand
    Montclair, CA
    A Man of Many Words :quickdraw:
    TheBeast[QUOTED] and GNTundra like this.
  5. Mar 27, 2017 at 4:02 PM
    Especially on days off.
    GNTundra likes this.
  6. Mar 27, 2017 at 4:11 PM
    You probably already know the center being worn out is either overinflated tires or wheels not being wide enough.
    Feathering is usually the toe in being to much. Toyota specs are pretty liberal on this setting.
  7. Mar 27, 2017 at 7:36 PM
    After reading all this. I don't want hear about bed bounce. Just sayin. By the way..if you want to use blocks... must be for mall crawling purposes.
  8. Mar 27, 2017 at 8:35 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    This is where I would start. The shocks need to be replaced
  9. Mar 28, 2017 at 8:21 AM
    LibertySand
    Montclair, CA
    Bed bounce is for all the hookers I pick up from the malls. I'd be lucky to have bed bounce with my 2" body lift that I installed. I used oak blocks and lagged them straight into the sheetmetal. Thats how I made room for the dual turbo set up under the hood. I used a 7.3 turbo to feed the 6.0 turbo, dual inline to a propane mister. I got this 4.6 pullin more HP than the 5.7 Turbocharger that Spvrtan has. The blocks are a deterrent for wanna be mall crawlers. They really get the axle wrap goin when I lay down that rubber across the speed bumps. This Tundra is hooked up! You dont even know!
    Ya, this weekend I plan on pulling one off to see how it's doing. I have a local shop that rebuilds shocks. I also talked to SDHQ and they rebuild shocks also, pretty reasonable too. Also hoping this week to drop it off for another alignment to see if the rear is possibly sitting wrong on the perches. As ColoradoTJ mentioned the thrust angle. This could be running issues. I've had a rock crawler that had horrible anti squat issues and when I got off the gas the rear would get all angry at me.
  10. Mar 28, 2017 at 6:02 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Thinking of thrust angle have you had any u joint issues
  11. Mar 28, 2017 at 6:05 PM
    LibertySand
    Montclair, CA
    Good call.
    No vibrations that I have felt but I'll take a look at the driveshaft. Might be a good idea to grab some u-joints for a trail repair.
  12. May 30, 2020 at 12:52 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Thanks for this thread OP. I am in the middle of installing some firestone bags and first had to remove my SumoSprings—which required loosening and retightening the Ubolts. I took a look behind the tire to ensure they were parallel and thought I messed it up somehow with the axle being at an angle. I guess I just never noticed before
  13. May 30, 2020 at 1:01 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This thread was an oldie but a goodie.
    I love how an advertising agent clearly wrote those words from toyota to justify their use of a crappier frame than other half ton trucks.
    i love my tundra, but I’m sure their goofy rear leaf idea is the main reason it has the worst riding rear suspension of any half ton out there
