Anyone shooting a gun chambered like this?
Discussion in 'Guns & Hunting' started by gosolo, Sep 6, 2019.
  1. Sep 6, 2019 at 9:06 PM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    Score!!!
  2. Sep 6, 2019 at 9:07 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    HK 91 uses fluted chamber. The deformation causes the casing to become basically a gas piston.
    Black Wolf likes this.
  3. Sep 6, 2019 at 9:07 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    Yep, it’s the only way to get this to happen. Any deformities in the chamber are imaged in the brass after firing. It’s why resizing is the first step in reloading.
    Still doesn’t really explain the “why”, though.
  4. Sep 6, 2019 at 9:08 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    So are you saying that the brass is ridged before firing?
  5. Sep 6, 2019 at 9:08 PM
    Grumpy Uncle
    Pat
    CO
    Exactly, I am curious about the why.
  6. Sep 6, 2019 at 9:10 PM
    Now that is out of the way for the time being, Ray, @gosolo , needs to post Orygun crabbing pics....
  7. Sep 6, 2019 at 9:11 PM
    CourtJester
    Alabama
    A round shouldn’t go that far into the fluting of a barrel or the fluting of a barrel shouldn’t go that far back into the chambering of a round.
  8. Sep 6, 2019 at 9:12 PM
    Yeah, but how do you resize something like that in a die?
  9. Sep 6, 2019 at 9:14 PM
    One use only I'm thinking.
    gosolo[OP] likes this.
  10. Sep 6, 2019 at 9:15 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Never seen anything like that. Subd for curiosity sake.
    Black Wolf and gosolo[OP] like this.
  11. Sep 6, 2019 at 9:15 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’m gonna say you can’t reload these
    jewsNbrews and Grumpy Uncle like this.
  12. Sep 6, 2019 at 9:16 PM
    Grumpy Uncle
    Pat
    CO
    I've shot HK 91s down in Peru many moons ago. I dont remember the brass being like that. Not saying it's not the case, I just dont remember.
    Black Wolf, jewsNbrews and gosolo[OP] like this.
  13. Sep 6, 2019 at 9:21 PM
    Windsor
    Homeless in Oregon
    Some.
    No, the chamber itself is fluted. It deforms the round when fired.
  14. Sep 6, 2019 at 9:22 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Great time with my son visiting.
    Crabbing, clamming, mushrooming, crawfishing, and a day on the Columbia trying to snag a silver
  15. Sep 6, 2019 at 9:23 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    That’s what I thought
  16. Sep 6, 2019 at 9:30 PM
    Windsor
    Homeless in Oregon
    Some.
    I stand corrected. It appears it is intended to assist in extraction.
  17. Sep 6, 2019 at 9:43 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I believe that is what i said in post #3.
    Thanks for finding the diagram! I hadn’t ever seen anything like it and thought it was worth letting folks get a look
    OR18TRD, Black Wolf and jewsNbrews like this.
  18. Sep 6, 2019 at 9:47 PM
    Subd because I like beer and my grandson is asleep..
  19. Sep 6, 2019 at 9:48 PM
    #49
    ...as you get older...memory fades.........
    gosolo[OP], OR18TRD and jewsNbrews like this.
  20. Sep 6, 2019 at 9:50 PM
    #50
    Excellent........silvers were never easy to catch
  21. Sep 6, 2019 at 9:51 PM
    #51
    Grumpy Uncle
    Pat
    CO
    Especially when its TBI induced.
  22. Sep 6, 2019 at 9:52 PM
    #52
    thezoltar
    thezoltar New Member
    Gas extraction. Common on HK designs regardless of actual manufacturer.
  23. Sep 6, 2019 at 9:53 PM
    #53
    Your avatar is giving me hallucinations.....
  24. Sep 6, 2019 at 9:55 PM
    #54
    Gas extraction is quite common on semi auto's, whether shotgun or rifle versions, but nothing like what we are discussing. I think?
  25. Sep 6, 2019 at 10:03 PM
    #55
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    So the gas blowback hits the cartridge shoulder and forces it rearward out of the chamber? I wonder what kind of deflector knocks it off to the side? Do you know of any videos showing the action in operation?
  26. Sep 7, 2019 at 5:14 AM
    #56
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    That’s from a CETME or Hk G3 rifle.
    I used to have one. They have a fluted chamber.
    gosolo[OP] and Sas like this.
  27. Sep 7, 2019 at 5:31 AM
    #57
    Rubberdown
    This. I’m not supposing. I’m telling you this is what happens. Chamber is fired to let gas flow around the brass. Helps knock it loose for extraction. Helps with shit brass and bullets in dirty conditions. Brass forms to the chamber and you have what you have.
    Hk91... couple other hk rifles.
  28. Sep 7, 2019 at 6:10 AM
    #58
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Fluted chamber is common on roller delayed guns. This is to aid extraction by keeping the expanded brass from sticking to the chamber due to fouling or other gunk (flutes reduce the chamber to brass contact area and allow some gas to help blow out the chamber). Fouling also happens quicker on full auto which these were originally designed to be. The system was also meant for thinker mil-spec brass so using commercial ammo may cause the brass to be more deformed and sometimes tear the case on extraction. My PTR91 had a fluted chamber and so does my MP5. The PTR would destroy brass but it’s less noticeable on the MP5 most likely due to the lower pressure of 9mm vs 7.62x51.
  29. Sep 7, 2019 at 6:29 AM
    #59
    JimBeam
    JimBeam Moderator Staff Member
    South Carolina
    2015 Limited
    Interesting information guys!
    Grumpy Uncle likes this.
  30. Sep 7, 2019 at 6:30 AM
    #60
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    ^^^ This is your answer.
    "A good place to start is by getting a firm handle on the difference between roller locked firearms and ordinary direct blowback guns. The latter design setup sees the bolt pushed backward by the pressure of expanding gases at the same time as the bullet moves down the barrel. This blowback action is delayed in a roller locked design. The critical roller locking mechanism acts to keep the bolt closed for a few vital milliseconds after firing. This reduces the pressure in the chamber before the bolt opens and the gun comes out of battery. The advantage? A roller locked gun can have a lighter bolt group assembly and operate more smoothly.
    This analogy should make the difference in the two systems clear. Imagine what it would feel like to strap into the passenger seat of an offroader competing in a grueling Baja race. That's direct blowback. In contrast, operating a roller locked gun is like piloting a German sedan down the Autobahn at 160 mph."
    Interesting CNC video:
