Anyone running 285/75r18 on stock Trd Pro Tundras
Discussion in 'Wheels & Tires' started by Jp-ProMamba, Jun 14, 2020.
  1. Dec 14, 2020 at 6:11 AM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    I have a very similar setup on my 2018 with 295/70/18 and I tow a travel trailer very close to the same weight as yours (roughly 7k loaded). Since installing the bigger tires I have towed my TT once and yes I could tell a slight difference in power but nothing that I believe would warrant swapping the gears. The trip I towed my trailer on required interstate driving and I know its not the best idea but I generally tow running about 70mph lol and leaving the truck in 5th gear. With stock tires I generally could keep it from down shifting except for large hills. Towing with the bigger tires obviously it likes to down shift into 4th a little more often, but on relatively flat ground it still pulled in 5th gear just fine. And honestly if I slowed down to 60-65mph I think it would stay in 5th gear with very little down shifting.
    So all of that to say in my personal opinion I would not be concerned with needing to regear after installing 295/70/18 tires. It may burn a little more gas, but it will still tow just fine.
    I have also noticed a drop in mpg during general driving too, but I rarely track my mpg so I don't have much to compare it too. This past weekend I went on a 3 hour trip running 80mph on the interstate and the computer showed 13.5mpg.
    But all things considered the truck looks soooooo much better that overall I'm still thrilled that I decided to install the larger tires on it!
  2. Dec 14, 2020 at 6:15 AM
    Bronzeback
    Bronzeback New Member
    Your tires are an inch smaller than the OP is asking about though. 285/75/18 is the question
    nasher75 likes this.
  3. Dec 14, 2020 at 6:16 AM
    TheMolenator
    TheMolenator New Member
    Jake
    2020 Tundra TRD
    TBD
    This is the exact information I was looking for. Thank ya much, my man.
    Which specific tires are you running? The 34” ridge grapplers I was looking at weigh 60lbs apiece, so I imagine if the tires you are using are 70lbs each or so I may just end up going with your setup for towing.
  4. Dec 14, 2020 at 6:26 AM
    Tundraman479
    I'm running the Cooper Discoverer AT4. I have been very happy with them so far. They ride great and have a more aggressive look then most all terrain tires.
  5. Dec 17, 2020 at 12:25 PM
    Tundra1078
    Tundra1078 New Member
    Peter
    Los Angeles
    2018 White Platinum 4x4
    TRD dual exhaust, sway bar, TRD skid plate, grab handle (future), husky liners
    Finally got my 285-75-r18 Goodyear Duratracs installed yesterday. Looks really good on them. About a half inch sticking out.
    Current setup is TRD Pro Fox shocks, removed front mud flaps due to one being torn in half (don’t know how it got torn before), and no other adjustments. Slight rubbing on the back mud flaps at full lock reverse (only on right side). Little power loss compared to the Michelin’s, but drives well.
  6. Dec 18, 2020 at 8:23 AM
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    Wheel spacers?
  7. Dec 18, 2020 at 3:25 PM
    Tundra1078
    Peter
    Los Angeles
    nope. Just stock trd pro suspension.
  8. Dec 18, 2020 at 3:30 PM
    danno266
    danno266 n00b
    I am surprised that you're getting that much poke without them.
    COTundra23 likes this.
  9. Dec 18, 2020 at 5:53 PM
    Tundra1078
    Peter
    Los Angeles
    yeah I just wanted a little to stick out, but nothing like the 295 tires which would weigh even more.
  10. Dec 19, 2020 at 7:08 PM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    Great look on the Tundra! What lift did you go with? I'm running the Bilsteins 5100 on all four corners. Truck is leveled. Again your Tundra looks amazing. I would probably go with a 285 75 18 tire. Any advice would be appreciated
  11. Dec 30, 2020 at 10:08 AM
    Snikskytter9
    Snikskytter9 New Member
    Rich
    New Hampshire
    2017 Tundra SR5 TRD off road
    2” level Nitto Ridge Grapplers Switch Pros 9100 Alpine wireless CarPlay Pillar post lights / amber / white Grille mounted light bar TRD Pro grille Dipped/blacked out badges 20% front window tint RCI 12” rack DECKED bed system LED bed lighting OEM Tow mirrors Crappy awful magnum research side steps.
    Hey all,
    I had 275 70R 18 Ridge Grapplers on for about 55k and just went up to the 295 70R 18 yesterday. I have a 2” level in the front and Air Bags in the back. It’s crazy how quiet these are when they’re new. I don’t see myself moving away from the ridge grapplers anytime soon. New England snow up here in NH can get brutal and the RG have handled it with no issues.
  12. Jan 3, 2021 at 6:21 PM
    woofhauler
    woofhauler New Member
    Pacifica, CA
    285/75/R18 Duratracs, stock 19 Pro, no rubbing, no trimming, just removed front flaps.
  13. Jan 4, 2021 at 10:05 PM
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    A bit off topic here, but what length RCI rack did you get? And does it feel secure being clamped in under the bed rack? Or did you drill into the bed side caps and bolt it in, too? Thanks!
  14. Jan 8, 2021 at 6:33 AM
    Snikskytter9
    Rich
    New Hampshire
    I bought the 12” high rack and the tonneau adapters. I drilled into the bed to bolt it on. I have a dual fold hard cover and I can’t raise it. There’s a Decked storage system in there and the 10” I have I slide pelican cases and rifle cases in the space available. I’ll get a hard rolling cover soon. I transport firearms to and from various ranges so it works out perfectly. I also affix pelican cases to the rack for additional storage if I need it. I took out the back seats and made a platform so I have a good amount of cargo space available.
    The RCI wasn’t my first choice but it was the least expensive, now I can’t imagine getting anything else. I’m very pleased with it. Wicked stable and solid. Last hunting season I slapped a rooftop tent up there and camped near the hunting locations. The rack feels like it’s mounted to the truck frame from the factory: solid.
    I put the rack on after the decked but the pics show you the space between the cover and storage system. If you’re thinking about the RCI, go for it. I mount everything to it as I need and it’s pretty easy.
    981826C0-BB05-443A-A71A-C2901FFEB847.jpg B5472160-4997-4E73-ABA9-D2C9FCBECC94.jpg
  15. Jan 8, 2021 at 9:44 AM
    itsmerh85
    Gilbert, AZ
    2020 Black TRDPro
    awesome, thank you for the detailed feedback! Was the RCI rack the 54" (for 5'-6" bed) or 58" (for 6' bed). I've seen the 58" fits on our crew max so just curious. Looks awesome, man!
    Also, my apologies to everyone for hijacking the thread for a few posts :hattip:
  16. Jan 8, 2021 at 9:44 PM
    Snikskytter9
    Rich
    New Hampshire
    No problem man!
    Mine is the 54”. There’s plenty of room for the 58”. I would have selected the 58” if I could go back in time, but I’m not one bit upset about it.
    itsmerh85[QUOTED] likes this.
  17. Jan 9, 2021 at 3:15 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Congrats, looks killer.. What noticeable difference?
    Oem ride? Stiffer? Firm? Planted? Please tell
  18. Jan 12, 2021 at 10:51 AM
    TheMolenator
    Jake
    2020 Tundra TRD
    TBD
    Are you running wheel spacers?
  19. Jan 12, 2021 at 11:46 AM
    #49
    mghtyducks93
    mghtyducks93 Bubble Head
    Southern California
    2015 White Double Cab
    Yes, 1.25” spidertrax
    TheMolenator[QUOTED] likes this.
  20. Jan 12, 2021 at 11:49 AM
    #50
    GianLaGatta
    GianLaGatta New Member
    Gian
    2019 white tundra sr5
    3in lift
    BFG K02s could be a good option too.
  21. Feb 23, 2021 at 2:57 PM
    #51
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Hey guys, sorry to bring an old thread back up but I have a 17 TRD PRO (stock) and got some 285/75/r18, just wanted to make sure that they will fit without any mods (except the removal of the front mud flaps)? Any input would be great!
  22. Feb 23, 2021 at 4:39 PM
    #52
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    This looks damn good!
    woofhauler[QUOTED] likes this.
  23. Feb 23, 2021 at 8:31 PM
    #53
    Tundra1078
    Peter
    Los Angeles
    yes, they fit perfectly fine. I have stock trd pro suspension. No additional lift, no spacer, I probably didn’t need to move the front mud flap but for some reason they got ripped in half prior. You will like them. Looks great. I think it’s the perfect size doe the tundra.
    YotaBro[QUOTED] likes this.
  24. Feb 23, 2021 at 9:06 PM
    #54
    woofhauler
    Pacifica, CA
    Thanks! Really loving it.
  25. Feb 24, 2021 at 4:22 AM
    #55
    YotaBro
    Calvin
    FL
    Sweet! Hopefully I’ll have these bad boys on by Friday! Thanks for the info!
  26. Feb 24, 2021 at 12:47 PM
    #56
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Fits well, I have tiny scraping on front sway bar at full lock and full flex, I'm also running Yokohama X-AT, being really happy with them.
  27. Feb 25, 2021 at 4:35 PM
    #57
    YotaBro
    Calvin
    FL
    She fits! Thanks for all of the help guys!
  28. Mar 22, 2021 at 7:10 PM
    #58
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    How close are you to the UCA? Any rubbing? No wheel spacers or BMC? Looks awesome!
  29. Mar 22, 2021 at 7:12 PM
    #59
    YotaBro
    Calvin
    FL
    Thanks! so no rubbing full left and right unless i am on a decline backing up ill barely rub on the sway bar. No wheel spacers or BMC. Bout to put on a front bumper so i might take the front sway bar off.
    jewsNbrews and GT87[QUOTED] like this.
  30. Apr 27, 2021 at 1:49 PM
    #60
    CoryShap09
    CoryShap09 New Member
    Cory
    2020 CM XP
    I have 5100s on middle clip with CB shims on both sides. Will 285/75r18 fit with TRD wheels?
