Anyone have this happen?
Discussion in 'General Tundra Discussion' started by Spolar, May 30, 2018.
  1. Jun 3, 2018 at 8:58 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Yeah I have my frame boxed up to the reinforced center section and I have 4 pads on each corner of the bed floor to support the bed cage. Those pads are tubed and gusseted to the frame.
    @Spolar just get your frame boxed and add a pad to each corner of your bed exactly like mine. The pads should be pretty cheap and if you ever decide to add a bad cage you can attach to them.
    If you don't want to do all that work, you don't have to. Just dial it down...:D
  2. Jun 3, 2018 at 9:17 AM
    NewRider
    NewRider New Member
    Travis
    Roaming the Shenandoah's
    2014 Tundra Limited Crew cab w/Flatbed
    Flatbed
    Just read through your build thread.. do you have any pics or more info on this “custom welded on rear bumper”? My guess would that that combined with the bed stiffners caused the rear or the bed and frame to act as a solid unit and pull the front apart... and I doubt Toyota will do anything for you with as much farm modification as you’ve got with the bumper and sliders... hopefully they don’t notice the added stiffners but I’m sure that would delete any warranty as well
  3. Jun 3, 2018 at 9:31 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    It totally depends on the dealer. I had my rear diff replaced and my axle is fully modified for a spring under axle conversion. If the dealer wants the work, they will present it to toyota in such a way as to get them to cover. If they dont want the work because it doesn't pay what they want, then they'll present it in a much different way
    15whtrd and Porschetech29 like this.
  4. Jun 3, 2018 at 9:42 AM
    Spolar
    Spolar [OP] Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Good guess... but my bumper is like 2 or 3 weeks old and never seen dirt
    Also how exactly would a different rear bumper behave any differently than the factory bumper and tow hitch??? My bumper is simply welded to the frame vs bolted on with the hitch relocated higher to a crossmember welded in place to act like the factory hitch.
    The bed stiffeners are solely there to stop the bed from falling apart from all the flex of the tundra frame. Don’t see how that contributes at all.
    Sliders? Suspension? Bumper etc etc? Zero has anything to do with the bed of the truck. None of it should be a reason to deny the claim. I don’t doubt Toyota will try and deny it because my truck is far from stock, but nothing I’ve put on the truck would co tribute to bed separating like that.
  5. Jun 3, 2018 at 9:51 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Alex is completely correct when it comes to the dealer covering the bed. Not sure about Toyota, but for the manufacturer that I work for, if I find an item that should not be covered under warranty for whatever reason I could submit for goodwill assistance. This all depends if the client is a good customer or not, and his or her attitude. More times than not we can get something covered. Partial or full depends on the case.
    Hopefully they help you out. Pm me and let me know how it goes, my old service manager is now a service manager for a Toyota dealership. I can reach out to him for his opinion if you would like.
    osidepunker likes this.
  6. Jun 3, 2018 at 9:58 AM
    n2deep
    n2deep Pavement Princess
    It's just a bed. Easily replaced and sure easy to find in a junk yard as many front end collisions that happen and beds are not touched. I am thinking I may just do a flatbed with tube and fiberglass so I can customize it. But will box and stiffen the frame and run it till it falls apart, then decide at that point what to do.
  7. Jun 3, 2018 at 9:59 AM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
    If this was slack I’d argue with you Craig
  8. Jun 3, 2018 at 11:10 AM
    n2deep
    What is there to argue? If the dealer covers it great if not then you have a to deal with it. A replacement bed is easy custom bed will cost more.
  9. Jun 3, 2018 at 12:00 PM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
    Finding a used 3rd gen bed, same color, for cheap, then installing it... I call that hassle
    Also I said that because u think slack is all pointless arguing:boink:
  10. Jun 3, 2018 at 12:42 PM
    n2deep
    Yeah it is that's why I am not there. Haha. Better trade the truck in because it's falling apart and going to explode on the trail in the middle of nowhere. Lol
  11. Jun 5, 2018 at 3:47 PM
    NewRider
    NewRider New Member
    Travis
    Flatbed
    All of that will absolutely affect how your vehicle wears and especially a rear bumper that is welded in. Sliders and bumpers all make vehicles more rigid (altering the factory designed flex) which could lead to potential increased wear on parts that are designed to move with the flex of the truck.
    In your case, you took a vehicle that’s intended to have the rear end twist with the rear of the fram and instead completely stiffened that section. Now your truck wiggles in the middle but doesn’t transfer that motion out the end and is forced to use the bed mounts to stop it... AND you jump it regularly it looks like which is extra hard on that particular section of frame
  12. Jun 5, 2018 at 5:08 PM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
    Once again, rear bumper is only like 2 weeks old, haven’t hit the dirt with it. And if you know your stuff you’d know what would happen to the bed if I didn’t tie the frame together with a high clearance bumper. But again, bed was already like that before the bumper so... check that theory off the list. Also rear of the bed is fine, it’s the one front corner
    Do you think I don’t understand getting a 7000+ truck airborn isn’t going to cause some stress? Of course I do. But where the bed issue is it’s unusual and there’s a lot of guys who offroad their trucks and I’ve yet to see that particular issue
  13. Jun 5, 2018 at 5:10 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    So id the dealere covering it?:eek:
  14. Jun 5, 2018 at 5:14 PM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
    The dealer by my house didn’t even look at it. Left it there for a few days and the service manager just had his “master” tech check it out. Basically told me I would need to revert back to stock if I wanted to have them evaluate the issue further lol. They didn’t even go to Toyota with it. So I might try one more dealer, but I’m going to the fab shop at the end of the month and having the frame boxed and everything beefed up so I’m not worried about it.
  15. Jun 5, 2018 at 5:27 PM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
    Master tech noted my aftermarket exhaust and skid plates along with bumpers and suspension as issues that would need be resolved before being able to continue with diagnostics on the bed. Basically didn’t even bother
  16. Jun 13, 2018 at 1:35 PM
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    They just hate you cause your truck is better than theirs.
    15whtrd likes this.
