Any way to upgrade just the JBL subs?
Discussion in 'Audio & Video' started by 2015Crewmax, Aug 10, 2018.
  1. Jan 3, 2019 at 10:00 PM
    #91
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Looks like different speaker wire.. Did you run new wire to the amp?
  2. Jan 3, 2019 at 10:04 PM
    #92
    cantle
    cantle New Member
    Durango, CO
    2018 Platinum CrewMax Barcelona Red
    TRD Pro Exhaust, TRD Skidplate, TRD Faux-Pro wheels, Ridge Grapplers
    It's just larger speaker wire crimped on to the factory connector to give some slack in the line.
    Rica25 and KnuckleHD[QUOTED] like this.
  3. Jan 4, 2019 at 7:29 AM
    #93
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    thinking about ordering as well. It sounds like it will suffice until I can afford to do the JL stealth box, new head unit and component speakers. Sounds like it's worth the $200.
  4. Jan 4, 2019 at 7:54 AM
    #94
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    keep me posted on the group buy as well...
  5. Jan 4, 2019 at 8:10 AM
    #95
    Freezy
    Freezy New Member
    Just checking, is this just the sub you guys are swapping or the entire enclosure?
  6. Jan 4, 2019 at 8:30 AM
    #96
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Sub and box combo
  7. Jan 4, 2019 at 11:03 AM
    #97
    Pudge
    CT
  8. Jan 4, 2019 at 12:22 PM
    #98
    KnuckleHD
    Count me in!
  9. Jan 4, 2019 at 12:33 PM
    #99
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    Count me in as well.
  10. Jan 4, 2019 at 12:39 PM
    #100
    Pudge
    CT
  11. Jan 5, 2019 at 8:08 AM
    #101
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    Count me in in.
    Pudge likes this.
  12. Jan 9, 2019 at 11:11 AM
    #102
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    yessssssss
    Another satisfied customer! Easy install and it really makes the factory JBL sound as it should have stock. I didn't need to make any modifications to the seat back.
  13. Jan 9, 2019 at 11:16 AM
    #103
    Pudge
    CT
    Nice!!!!!
    I cant wait and neither can 50 other guys lol
    Rica25 likes this.
  14. Jan 9, 2019 at 11:50 AM
    #104
    Freezy
    Freezy New Member
    Does the seat bolt right back in and sit flush?
    Rica25 likes this.
  15. Jan 9, 2019 at 1:08 PM
    #105
    ninjajay
    Spoolston, TX
    Yeah
  16. Jan 21, 2019 at 8:53 PM
    #106
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Here are pics of the sub box, amplifier and LC2i audio controller.
    k0diak8o8, Mountun Goat and Rica25 like this.
  17. Feb 9, 2019 at 4:12 PM
    #107
    Pudge
    CT
  18. Feb 10, 2019 at 9:31 AM
    #108
    TXTundra2722
    2015 Black Tundra
    I'm assuming your not JBL equipped?
  19. Jun 17, 2019 at 11:42 AM
    #109
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I ordered a 12Volts JBL replacement for my 2010 CrewMax Friday. I have a Pioneer amp running a JL sub now that is much smaller. I have reasonable bass now.
    I removed that side of the panel where the JBL sub was and would like to put it back. First, how did you guys secure the sub and how did you retain the cover panel that is behind it?
    Thaik you!
  20. Dec 17, 2019 at 5:05 AM
    #110
    Jetsurgeon
    Jetsurgeon New Member
    2016 TRD 4x4 *1794*
    Can anyone confirm ohm reading of JBL system factory installed Subwoofer??? Does it read 1 ohm across OEM speaker posts or 2 ohms??? Sorry guys both numbers can be found in every posting on the www. Just wondering if the factory changed the design at some point in production and might explain different results for different members doing a speaker only upgrade.
    Let you know what my '16 JBL reads, when I remove it. THANKS for all the help. I can't argue any route you take to improve your bass response, factory output is close to non-existent!!!!!
  21. Jan 9, 2020 at 11:29 AM
    #111
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    Ever figure anything out on the ohm reading?
  22. Jan 9, 2020 at 11:29 AM
    #112
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Where can I get a box like this???
  23. Jan 9, 2020 at 8:05 PM
    #113
    Jetsurgeon
    2016 TRD 4x4 *1794*
    My 2016 JBL subwoofer resistance was just shy of 2 ohms. So I installed a
    Kicker CompRT 43CWRT81
    like CARMAN suggested ($112 @ Crutchfield). I wired the dual 1 ohm voice coils in series for a 2 ohm load on the amp. It is a DISTINCT improvement over stock JBL sub. It is NOT like having twin 12" subs behind the seat. Only twin 12s will give you that. The mod is well worth the $112 & 1 hour install time, IMO. Follow CARMAN's instructions and you will not have problems. I also taped the original faster holes closed, put a small amount of polyfill in and taped the enclosure seams.
  24. Jan 10, 2020 at 5:43 AM
    #114
    Rebel Tundra Man
    Tyler
    Western Kentucky
    Yea I'm good with doing that option, I would rather have two 10's or 12's behind the seat with some decent power going to them though.
    Jetsurgeon[QUOTED] likes this.
  25. Jan 10, 2020 at 6:09 PM
    #115
    dalejunior
    dalejunior New Member
    2018 BBP TRD Limited Crewmax
    I got two ohms on mine before i tossed it.
    Jetsurgeon likes this.
  26. Jan 16, 2020 at 4:08 PM
    #116
    r1-superstar
    DB
    UTAH
    No I wasn't.
  27. Jan 16, 2020 at 4:09 PM
    #117
    r1-superstar
    DB
    UTAH
    I bought it from my local dealer; Karl Malone Toyota.
  28. Jan 19, 2020 at 9:55 AM
    #118
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
  29. Jan 20, 2020 at 8:32 AM
    #119
    Rebel Tundra Man
    Tyler
    Western Kentucky
    so is it a factory option I'm assuming then?
  30. Jan 27, 2020 at 1:59 PM
    #120
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Minnesota
    2020 TRD Pro Tundra, 8371 Club
    Coachbuilder Pro Kit, 35x12.5 BFG KM3s, Baja S8 hood mounted, Rago Lo-Pro Brackets sitting empty at the moment, Rago Dash Divot Plate, AJT Stuff, LED Lighting throughout, TRD Intake, Bedliner, Tint, Full front PPF, SPS Graphene Coating, and dropped the B out of JBL ;-)
    Definitely worth it!
    Visually you can see very quickly how much more air gets moved between boxes. Bass is now present and low, doesn't sound muffled like the factory sub sounded. Solid 30 minute install...
