Any way to upgrade just the JBL subs?
Discussion in 'Audio & Video' started by 2015Crewmax, Aug 10, 2018.
  1. Aug 10, 2018 at 4:49 AM
    2015Crewmax
    2015Crewmax [OP] New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    Everything else is great. I feel the OEM JBL subs aren't the highest quality.
    TundraTRD08 likes this.
  2. Aug 10, 2018 at 4:39 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    Did you want to upgrade just the sub or both the sub and enclosure? If just the sub I recommend to change the amp also. When I changed out my entire jbl system the it looked like the sub was really shallow. You might need to take it out and get measurements.
  3. Aug 10, 2018 at 9:40 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    The factory sub is ridiculously cheap plastic and is nothing but a joke. As I slowly built my system piece by piece, I put the JL audio stealth box in for my sub. It was the first thing I did and I hooked it up to the factory system so I still had bass, and it made a huge improvement none the less. The factory sub is 2ohms. Just make sure you match that if you don't end up having a dedicated sub amp (highly recommended!!!) My sub amp is 1000watts, where the factory sub output is around 100watts for a reference.
  4. Aug 10, 2018 at 9:56 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Before I changed out my whole system, I added an amp and sub enclosure. When you have a separate subwoofer in a stock system, the easiest way is to use one of these.
    http://davidnavone.com/product/ne-7v-2-channel-line-drive-adapter/
    It wires to your subwoofer speaker wire and gives you rca inputs to add an amp. Worked fine for me in my last car and I used it for a while in the Tundra. Just adding better bass made the stock system MUCH better in my 2nd Gen, however it still wasn't enough, which is why I started from scratch and replaced everything.
    Mountun Goat likes this.
  5. Aug 10, 2018 at 10:10 PM
    Tundra Fan
    Toby
    Here is just a rough install I did to see if the line drive adapter I mentioned would work. You can see it at the end of the purple RCA's. It worked, so I had another box built for my subs so that the seat could stay in.
  6. Sep 5, 2018 at 2:29 PM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
    Kicker sub woofer, 1500 watt inverter
    The simplest easiest, most cost effective addition is to add a Kicker CompRT 43CWRT81 subwoofer. $149 from Crutchfield, 1 hr install if you can handle simple mechanics. Uses factory wires, nothing else to add, plug and play ( after you you[​IMG] use 1.5" self tapping screws-kicker/8 hoLes stock 6/holes). The factory amp will rock your mirror when heavy bass songs played.
  7. Sep 5, 2018 at 3:39 PM
    MT1794PRO
    MT1794PRO New Member
    Paul
    2014 MGM 1794 CM
    Debadge, Dechrome, TRD Pro Grille, 2018 Headlights, Amber Grill Lights, Carbon Wrapped Wood Trim, Pace Edwards Switchblade Tonneau....
    That kicker looks interesting.
  8. Sep 5, 2018 at 6:07 PM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
    whole different sound after install. factory amp is plenty to power. no extra wiring, disassembly or headaches. best 150$ spent.
    rv740, KnuckleHD and Mountun Goat like this.
  9. Sep 5, 2018 at 6:36 PM
    Rica25
    Ricardo
    Tulare
  10. Sep 5, 2018 at 6:39 PM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
    Is that an amp/sub box?
  11. Sep 5, 2018 at 6:40 PM
    Rica25
    Ricardo
    Tulare
    I will post some more pics
  12. Sep 5, 2018 at 6:42 PM
    Rica25
    Ricardo
    Tulare
  13. Sep 5, 2018 at 6:45 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Interesting
    Rica25[QUOTED] likes this.
  14. Sep 5, 2018 at 6:46 PM
    Rica25
    Ricardo
    Tulare
    Sub is 750 Rms ...1500 watt max and rumbles everything if I really turn it up
  15. Sep 5, 2018 at 6:48 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    That’s awesome. I bet you get some rattle with that big ol box:thumbsup:
  16. Sep 5, 2018 at 6:48 PM
    Rica25
    Ricardo
    Tulare
    I have dynamatted almost everything sounds very clean
    woods and Mountun Goat[QUOTED] like this.
  17. Sep 5, 2018 at 7:15 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Good for you:bowdown:. They always sound so crisp with sound deadening.
  18. Sep 9, 2018 at 4:35 PM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
    Looks great. Bet its expensive
    Rica25 likes this.
  19. Sep 9, 2018 at 4:46 PM
    Rica25
    Ricardo
    Tulare
    I did all the work and also made the box my self
    Luckydog likes this.
  20. Sep 9, 2018 at 4:49 PM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
  21. Sep 13, 2018 at 8:31 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    @2015Crewmax
  22. Sep 13, 2018 at 8:33 PM
    Pudge
    CT
    You get the 1 ohm or 2 ohm?
    Howd you wire it up as far as connecting the speaker wires to each voice coil?
    Thanks
  23. Sep 14, 2018 at 12:16 PM
    Jagamov
    Jagamov New Member
    Greg
    2017 White Tundra Platinum
    @carman
    I"m interested in this too. Can you provide some more information about this.
    Thanks!
    Pudge[QUOTED] likes this.
  24. Oct 1, 2018 at 4:35 PM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
    sure, run a jumper wire from + to - on the kicker
    then connect the green tundra wire to + and black to -. screw into the factory box and go listen:).
    rv740 and Jagamov like this.
  25. Oct 1, 2018 at 4:37 PM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
    Kicker CompRT 43CWRT81 it has :
    • 10" subwoofer with dual 2-ohm voice coils
  26. Oct 17, 2018 at 2:45 PM
    dalejunior
    dalejunior New Member
    2018 BBP TRD Limited Crewmax
    This looks very interesting. Question for you Carman...I haven't pulled the factory sub out yet but do you need to tap into the harness to do the final connection to speaker after I follow your instructions to drop the speaker to 1 ohm? Thanks for your help
  27. Oct 17, 2018 at 6:30 PM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
    Once you prep the Kicker by running jumper from left pos to right neg, then cut the factory green and black wires and run the green to the remaining pos and the black to the remaining neg connection. turn on the stereo to see that it works then use eight 1.5"(i think) screws to secure the sub to the enclosure. if there is a gap, use either small foam strip around edge to seal it off or black elec tap works too. there is no grill that works well so make sure nothing under back seat that can slide back and hit sub. crank up and enjoy mirror vibrating sound from the premium factory 440 watt amp and new kicker sub.
    minter66 likes this.
  28. Oct 17, 2018 at 6:36 PM
    Pudge
    CT
    I got the kicker dual 1 ohm sub and wired it in place of the factory JBL sub, no extra amp. Its marginally better, not worth the money without adding an amp. I figured that would be the case going into it though. Maybe some day I'll install an amp.
  29. Oct 17, 2018 at 7:34 PM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
    Did your 2015 come with the premium JBL
    system? Mine stated it has a 440 watt amp.if yours doesnt, that may explain the difference. also make sure the jumper crosses sides(left to right) and not just on one side.
  30. Oct 17, 2018 at 7:49 PM
    Pudge
    CT
    Yeah it is the platinum with the premium JBL it may have changed in 2017 but I'm not sure. It's pretty pitiful. I'll double check my wiring when I get a chance one day but I think that's the way i did it
