Any torque loss felt after installation of TRD dual exhaust?
Discussion in 'Performance and Tuning' started by Jaybird79, Jan 25, 2019.
  1. Apr 11, 2019 at 7:16 AM
    #61
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Either way Magnuson makes a repair kit, guess I’m going to have to “fix” my exhaust.
    :anonymous:
    Rica25, Tundradrenalin and dirtydeeds like this.
  2. Apr 11, 2019 at 7:16 AM
    #62
    dirtydeeds
    Keith
    USA
    more than I can list here
    The older trucks had a more touchy gas pedal making them feel like there is more low end torque. But it’s all the same on the highway.
  3. Apr 11, 2019 at 7:17 AM
    #63
    dirtydeeds
    Keith
    USA
    Yes. Anything that allows you to tie back to the stock tailpipe. And don’t go smaller than stock on muffler in/out size.
    But if drone is a concern check out a BAmufflers 8” system on YouTube.
    revtune, Rica25 and 15whtrd like this.
  4. Apr 11, 2019 at 7:19 AM
    #64
    Omohundro
    Jody
    McMinnville TN
    @dirtydeeds i can tell you this, if I ever change my exhaust it will be to yours. There is just so much positivity about it. :benchpress:
    Rica25 and dirtydeeds like this.
  5. Apr 11, 2019 at 7:21 AM
    #65
    dirtydeeds
    Keith
    USA
    This sounds reasonable;)
    Rica25 likes this.
  6. Apr 11, 2019 at 7:22 AM
    #66
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    So would going to a 3" In/Out muffler be fine?
    Rica25 likes this.
  7. Apr 11, 2019 at 7:24 AM
    #67
    dirtydeeds
    Keith
    USA
    Yessir. 3” is fine. But tie back to stock tailpipe. Whatever you do, don’t go 3” tAilpipe or duals. Keep stock tailpipe which is odd at 2 3/4”
  8. Apr 11, 2019 at 7:26 AM
    #68
    10TundraSR5
    Tennessee
    Would removing the resonator change or affect anything other than sound? I swear Keith, if I'm ever on that side of the country I'm buying you a steak dinner.
    Rica25 likes this.
  9. Apr 11, 2019 at 7:30 AM
    #69
    dirtydeeds
    Keith
    USA
    Not sure what resonator?
    Rica25 likes this.
  10. Apr 11, 2019 at 7:32 AM
    #70
    10TundraSR5
    Tennessee
    The one that is right after the muffler. I have a 2010 CrewMax SR5. Picture taken from internet.
    Rica25 and Rex Kramer like this.
  11. Apr 11, 2019 at 7:35 AM
    #71
    dirtydeeds
    Keith
    USA
    Gotcha. Most don’t hane that anymore. Just changed sound very slightly. No need to remove it.
    Rica25 likes this.
  12. Apr 11, 2019 at 7:35 AM
    #72
    10TundraSR5
    Tennessee
    You are now up to 2 steak dinners. THANK YOU!!!!!!
    Rica25 and dirtydeeds[QUOTED] like this.
  13. Apr 11, 2019 at 9:18 AM
    #73
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I measured my stock exhaust, since it's on the bench right now. Two pipes OD on the muffler inlet are about 2 1/4". Single pipe OD on the outlet is just a hair under 3". I'm not measuring the first 3-4" of pipe where it's welded to the muffler, there seems to be a pipe diameter increase at the connection points. I can't measure ID of the welded assembly. Are you giving measurements of ID?
    Rica25 likes this.
  14. Apr 14, 2019 at 7:03 AM
    #74
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    I tried paying attention to this over the last few days. The only time I sort of notice this is going up steeper inclines in 6th gear under 60 mph. Higher speeds and flat surfaces seem to hold 6th fine. I don’t tow. If I did it may be more of an issue for me.
    Just reporting out as objectively as possible.
    I’ve used Keith’s systems on a previously owned Tundra and was very happy with that exhaust as well. If my current Tundra came with stock exhaust, I would probably upgrade to the 10 inch BAM. But for now, the TRD is nice.
    Rica25, Hammy68 and banana_phone like this.
  15. Apr 14, 2019 at 7:36 AM
    #75
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I agree- I’ve been watching the shifting patterns more closely over the last few days because of this discussion. As I said above, I have nothing to compare to other than coming from a 17 Tacoma, which didn’t have a clue what gear to be in and was sluggish. I don’t tow either, so for me the hilly back roads in the Tundra seem to be spot on with this, and it seems to shift when needed on the highway and long inclines. It reminds me of how my 07 Tacoma shifted with the 4.0 5spd auto- not always perfect, but checking most of the boxes. And you can’t deny that the TRD exhaust sound is really nice.
    banana_phone likes this.
  16. Apr 14, 2019 at 10:34 AM
    #76
    15whtrd
    15whtrd Mr. Blonde
    Usually when someone is speaking about Pipe it’s always inside diameter. As a plumber this always rings true to me. That can vary in something like copper pipe when it uses all the same fittings but the wall thicknesses change. But typically it should always be referred to ID. I think companies should offer both measurements though. But what good is knowing the ID if the OD isn’t going to fit into what you’re trying to do. I feel your pain
  17. Apr 14, 2019 at 12:36 PM
    #77
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    I agree. I haven’t experienced anything noticeable so maybe it’s just my driving habits. Even on the highway I don’t get downshifting on small hills like a few have said. Nothing that would keep me from getting the Trd duals again knowing what I know now.
    Rica25 and Hammy68 like this.
  18. Apr 15, 2019 at 7:35 AM
    #78
    Jaybird79
    Jaybird79 [OP] New Member
    Jay
    Omaha, NE
    future Tundra owner!!
    N/A
    There was a link provided in this thread earlier which did dynos tests and showed that the TRD dual exhaust had an increase in both torque and horsepower.
    https://motoiq.com/project-toyota-tundra-part-5-testing-trds-warranty-friendly-exhaust-system/4/
    Just wondering why you wouldn't give that credence but assume Keith is right without any dyno numbers to prove it?
    Rica25 and 17inferno like this.
  19. Apr 15, 2019 at 7:42 AM
    #79
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    I guess I missed that link. I don't know. I have seen reports that show loss and others that show gains. whatever.... I don't care who is right. I got the TRD dual exhaust for the sound :)
    Rica25 and Tundradrenalin like this.
  20. Apr 15, 2019 at 7:53 AM
    #80
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    The rpm where the torque loss may happen is too low for a dyno to measure - well below 2000 rpms - so it is based on driver experience. The graph on the attached dyno began at 3500 rpms.
    I have not really noticed much of a torque loss with the TRD system (where and how I drive), but somebody who tows or is constantly lugging uphill may notice it.
    Rica25 and NoMoTaco like this.
  21. Apr 16, 2019 at 7:53 AM
    #81
    Walleye
    Walleye New Member
    Is this a water brake dyno?
  22. Apr 16, 2019 at 10:09 AM
    #82
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Dunno. I was paraphrasing what Keith said in Post 55 of this thread. I should have referenced that in my post.
    "Low end torque loss is not measured on a dyno. It is felt on the highway when in 6th gear."
    Rica25 and Walleye[QUOTED] like this.
  23. Apr 20, 2019 at 9:40 AM
    #83
    Pbear1454
    Pbear1454 New Member
    NorCal and SoCal
    2010 Tundra TRD
    Bilsteins SPC RCI Steel Bumpers
    Has anyone has noticed more sluggish and a delay in gear shift when accelerating ? Just curious if it’s an issue in both 2nd and 3 gen trucks
    Rica25 likes this.
  24. Apr 20, 2019 at 6:43 PM
    #84
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Can’t say I have.
    Rica25 likes this.
  25. Oct 15, 2019 at 5:22 AM
    #85
    colossalcrewmax
    colossalcrewmax New Member
    2019 tundra crewmax
    S&B intake , nfab side steps , limo tint 5% and 35% front window , custom side exit exhaust
    There is Deff a down low loss in tq. I did a custom side exit exhaust on my 2019 tundra crew max 5.7
    i deleted the second cats
    (for more sound )
    did 2.5” pipe to a magnaflow true x muffler (high flow muffler with x-pipe built in)
    Muffler is 2 in and 2 out with 2.5” inlet/outlet.
    from there it’s 2.5” piping with nice tips right out the right side before the rear tire
  26. Oct 15, 2019 at 5:29 AM
    #86
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I have no way of noticing any low end torque loss since I added the TRD supercharger at the same time as the TRD exhaust. If there was torque loss, I'm sure the supercharger has compensated for it.
    Rex Kramer, Hammy68 and Rica25 like this.
  27. Oct 15, 2019 at 5:48 AM
    #87
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I kept mine in place when lowering the rear suspension forced me to create a turn down dump ahead of the axle, we angle cut the pipe and rotated the resonator 180 degrees. It sounds pretty good, and I didn't lose any low end power.
    My new Dirty Deeds cat back will utilize a new OEM tail pipe that will reach beyond the rear axle, it doesn't have the OEM resonator.
  28. Oct 15, 2019 at 6:05 AM
    #88
    Rica25
    Ricardo
    Tulare
    I can attest to this, I had two different sets of duels and got rid of both for the same reason. Very happy with 8 inch Ba muffler
  29. Oct 15, 2019 at 10:41 AM
    #89
    10TundraSR5
    Tennessee
    I would love to hear a sound clip of this setup. I did a Magnaflow muffler swap and the drone killed me. I wanted the biggest muffler for the quietest sound but still have the straight through performance. I think the muffler had a built in Y and a chamber. Either way, it lasted 1 week then I got the TRD exhaust (my first choice). No regrets!
  30. Feb 5, 2020 at 2:16 PM
    #90
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
