Any torque loss felt after installation of TRD dual exhaust?
Discussion in 'Performance and Tuning' started by Jaybird79, Jan 25, 2019.
  1. Jan 30, 2019 at 8:19 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    Low end torque loss is noticed when cruising down the highway. Not when accelerating from a light/stop sign.
    When running stock exhaust manifolds there is absolutely low end torque loss when switching from single exhaust to dual exhaust.
    I’ve found thst an X pipe reduces this loss better than an H pipe does.
    But there is no better way to gain low end torque rather than slightly lose it than by installing a properly built single exhaust such as our standard 8” system.
    AggiePhil, D4x4TRD, equin and 6 others like this.
  2. Jan 31, 2019 at 6:25 AM
    Jaybird79
    Jaybird79 [OP] New Member
    Jay
    Omaha, NE
    future Tundra owner!!
    N/A
    Okay so you're saying the X pipe on the TRD will reduce the loss, but still not be as effective as a single outlet exhaust. Question, is the standard 6" system going to be louder than the TRD duals? I like the TRD dual sound, but I want a bit more noise. I'm assuming the 8" system is the same loudness as the TRD duals.
    Thanks Keith!
    Rica25 likes this.
  3. Jan 31, 2019 at 7:45 AM
    dirtydeeds
    Keith
    USA
    Correct. With stock manifolds, no matter what you do, a single exhaust built correctly will always make more low end torque than a dual exhaust.
    And actually the 8” is more aggressive on the throttle than trd. Yet quieter than trd cruising down the highway.
    equin, Rica25, NewImprovedRon and 2 others like this.
  4. Jan 31, 2019 at 9:00 AM
    Jaybird79
    Jay
    Omaha, NE
    N/A
    Good to know. How about the 6"? How much louder will be be compared to 8"?
    dirtydeeds[QUOTED] likes this.
  5. Jan 31, 2019 at 9:02 AM
    dirtydeeds
    Keith
    USA
    Overall sound isn’t that much louder. The 6 is slightly louder. Slightly higher pitch. And from inside the truck you can hear it slightly more. But basically they’re the same thing.
  6. Jan 31, 2019 at 9:43 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    i didn't notice any loss in low end torque when I added the TRD dual exhaust. however, that doesn't mean that the low end torque didn't go down. i just couldn't tell. really, i think that putting the truck on a dyno is the only way to know for sure. Keith @dirtydeeds says that's the case and i would believe him since he is the exhaust expert around here :)
    however, with the DAP tune, all of that is moot. any torque loss is nullified by having the tune. the better throttle response and the faster/firmer transmission shift points alone make up for any torque loss that the TRD dual exhaust may produce. and the performance improvement is noticeable at all speeds; from a stop or at highway speeds.
    equin and 15whtrd like this.
  7. Feb 23, 2019 at 10:04 PM
    tja1080
    tja1080 New Member
    TJ
    Virginia Beach
    2016 Platinum
    So what is required to replace a TRD exhaust with a 6” system?
  8. Feb 25, 2019 at 10:48 PM
    dirtydeeds
    Keith
    USA
    Only thing you’d have to acquire would be a stock tailpipe and clamp. Call for details. 760-877-4234
  9. Feb 26, 2019 at 3:59 AM
    Walleye
    Walleye New Member
    The TRD dual exhaust has slighter lower torque at lower RPM. In evaluating it, I would bet it doesn't hold a higher gear as well as the stock exhaust when towing. This is inherent in the dual exhaust setup. It likely makes slightly more hp on the high end but this is rather meaningless for towing. Really makes me wonder why the TRD Pro is always the truck that gets evaluated by automotive media for towing tests. Dyno a stock truck and one with a TRD Dual exhaust. Peak torque likely shifts slightly higher in RPM range. Good for high speed, not so good for longer distance towing.
    equin and Tundradrenalin like this.
  10. Feb 26, 2019 at 4:33 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I detect a jellybean!
  11. Apr 8, 2019 at 11:26 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I just replaced the factory single side exhaust with a TRD dual exhaust and I can confirm there was a very noticeable low-end torque loss. With the single exit stock exhaust I could hit the tow/haul button and burnout my 35" Toyo's easily from a stand still. With the duals, there is no burnout possible, just a mushy gas pedal. It sounds great at 5500 RPM flogging it on the highway 60 to 80 mph, but I don't do that too often.
    My 2016 DC is running factory manifolds on the 5.7L w/4.30 gears, nothing extra. Maybe long tubes would change this torque loss. But I'm trying to stay 50 state legal, so no long tubes for this truck.... yet. Contemplating going back to the stock exhaust. I knew this was a gamble and I was willing to try it. I'll give it another month to see if it grows on me or not.
  12. Apr 8, 2019 at 11:35 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I’ve drove a 2018 with and without the TRD exhaust, I can’t tell the difference. The only way that I would have known that there may be a difference is by reading this forum... still can’t tell the difference. I know that by reading this forum both the TRD and the Dirty Deeds are both great exhaust and both have there followers, but so does Flowmaster, Borla and others have a fan base also. The TRD CAI doesn’t do much either... except look bad ass!
    BTBAKER likes this.
  13. Apr 9, 2019 at 1:34 PM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    I also didn't notice any difference on my test drives. Granted my previous vehicle was a 4runner so any Tundra feels like a rocket compared to that. I don't tow anything - maybe I would notice something if I did.
  14. Apr 9, 2019 at 1:42 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Same here.
  15. Apr 10, 2019 at 12:57 PM
    Jaybird79
    Jay
    Omaha, NE
    N/A
    Yikes! Would hate losing that much torque on such a vehicle. I will have to go BA muffler or BA TRD replacement system when I get my Tundra.
    Thanks,
  16. Apr 10, 2019 at 1:14 PM
    banana_phone
    banana_phone New Member
    Aaron
    2015 Tundra
  17. Apr 10, 2019 at 1:24 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    Hammy68 and Rica25 like this.
  18. Apr 10, 2019 at 1:34 PM
    dandailey
    Dan D
    Newport News Va.
    Rica25, 17inferno and Hammy68 like this.
  19. Apr 10, 2019 at 2:04 PM
    #49
    Jaybird79
    Jay
    Omaha, NE
    N/A
    Rica25, 10TundraSR5 and Hammy68 like this.
  20. Apr 10, 2019 at 4:06 PM
    #50
    17inferno
    17inferno New Member
    I just bought the TRD duals from the 40% off special, and installed it two days ago. I had 22k miles of all sorts of driving, including 40 min cruise to work. I've driven a few hundred miles already, and can tell no loss of power, on any end. Even cruising down the highway feels the same.
    Rica25 and Hammy68 like this.
  21. Apr 10, 2019 at 4:37 PM
    #51
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    This is all anecdotal. Anyone have dyno information.
    Rica25 likes this.
  22. Apr 10, 2019 at 5:01 PM
    #52
    dandailey
    Dan D
    Newport News Va.
    See above
    Rica25 likes this.
  23. Apr 10, 2019 at 6:32 PM
    #53
    17inferno
    There is some older tests as well on the internet. Takes a bit of searching but the data is there.
  24. Apr 10, 2019 at 7:00 PM
    #54
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    My butt dyno says no power loss with my TRD exhaust.
    Rica25 likes this.
  25. Apr 11, 2019 at 6:20 AM
    #55
    dirtydeeds
    Keith
    USA
    Low end torque loss is not measured on a dyno. It is felt on the highway when in 6th gear.
    Every single tundra with stock exhaust manifolds that I’ve ever installed dual exhaust on, trd or otherwise, has lost low end torque.
    Trd will gain 3-10hp and 10-20tq to the rear wheels over stock. The power curve does not move. It remains the same, just more.
    You can minimize the loss with an X pipe. But it’s never the same as a single exhaust.
  26. Apr 11, 2019 at 6:28 AM
    #56
    Tundradrenalin
    Virginia Beach, VA
    Truth.
    Look at the dyno posted above, the reading starts at 3500 RPM.
    I don't understand how you guys can say there was no low-end torque loss. It was clear as day to me on the first 50 ft after I switched to duals.
    revtune, 1_thirsty_tundra and equin like this.
  27. Apr 11, 2019 at 6:39 AM
    #57
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    The measurable gains are only 2 to 3 percent, which I honestly can't feel, so the "immeasurable" loss is also something I can't feel.
    Rica25 and 17inferno like this.
  28. Apr 11, 2019 at 6:56 AM
    #58
    dirtydeeds
    Keith
    USA
    The loss is there. You can tell because I’m low rpm situations, like on the highway in 6th gear, you’re stepping on the throttle way more to maintain speed. So much more in fact that the truck downshifts st the slightest hill. And that’s super annoying. All tundras do this.
    revtune, Rica25 and equin like this.
  29. Apr 11, 2019 at 7:11 AM
    #59
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    @Tundradrenalin you say you can tell it from a stop and go, @dirtydeeds is saying it’s only at highway speeds. I can’t tell either way and I feel like I’m pretty intune with my vehicles. I’m wondering if this is more vehicle specific, maybe some trucks take it better than others. Just a thought.
    Rica25, Tundra_361 and dirtydeeds like this.
  30. Apr 11, 2019 at 7:14 AM
    #60
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    So would just doing a muffler swap with a Magnaflow or Borla muffler be better than the TRD setup performance wise? My wallet likes the idea.
    Rica25 and dirtydeeds like this.
