Any aftermarket bumpers compatible with BSM + RCTA?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Saltyhero13, Oct 19, 2020.
  1. Dec 17, 2021 at 9:58 AM
    #121
    SwampThing
    SwampThing New Member
    Looks good. I wish they’d corner the market and make a steel version of this with swing outs.
    Right now, my decisions are:
    1. P&P Engineering (drill my own parking sensor holes) or Victory 4x4. For both, you give up BSM. P&P provides more ground clearance out of the box with the relocated hitch. Victory has an option for that too, but it’s extra. Neither hitches are SAE certified.
    2. Rigd UltraSwing. They said this shouldn’t interfere with BSM and it looks like that’s true. You definitely block and lose your parking sensors though. It uses the OEM hitch and is tow rated up to 10k, but makes for worse ground clearance.
    All those options are pretty comparable price-wise when you factor in the accessories. The basic trade offs are BSM vs parking sensors and ground clearance (less of a concern for me). Not willing to consider CBI after my experience with their front bumper.
    I’m leaning towards the Rigd UltraSwing at the moment as BSM was really nice on a recent cross country trip. I was using a hitch hauler with the parking sensors disabled and I didn’t really miss them.
    Thoughts welcome.
    AggiePhil likes this.
  2. Dec 17, 2021 at 10:33 AM
    #122
    BayRunner
    2017 Tundra Platinum
    Funny you mentioned the UltraSwing. I’m in the Same boat and was looking for a way to mount a full size 35” spare. While the Ultra Swing will do the job, it does have cons and the DirtCom Trail Swing HD is a far superior option. It cost more but is designed, engineered and built way better. They compensate for the ground clearance. They have a video on YouTube where they directly compare against the Ultra Swing including cutting each in half to compare build quality. I was really impressed with the thought they put into it and ended up ordering one.
    https://dirtcomusa.com/products/trail-swing-hd
    SwampThing[QUOTED] likes this.
  3. Dec 17, 2021 at 10:37 AM
    #123
    BayRunner
    Truthfully, it’s a personal choice. I wanted a more robust aluminum bumper in all black. Upon removing g the stock bumper did I realize how thin and weak it is. There were many connector tabs, which are plastic, that were broke and pulling away due to wheeling. I feel the aluminum bumper will hold up better to the use I put it through.
  4. Dec 17, 2021 at 11:42 AM
    #124
    BayRunner
    I agree, it does match it well. BTW, I’d be interested in see the result if you decide to mod the Ironman bumper. Think that would look good.
  5. Dec 17, 2021 at 12:05 PM
    #125
    SwampThing
    @BayRunner - Good call. I like this more than the UltraSwing too. Do you know if the license plate light plugs into the trailer socket like the UltraSwing? Or does it require some wiring?
  6. Dec 17, 2021 at 2:16 PM
    #126
    BayRunner
    I spoke with AJ (the owner) in length about the Trail Swing. He is quite a personable guy and very easy to talk to. He loves their product and was more than happy to spend the time answering my questions.
    I did ask him your question and he’s said that the light ships with the 2 wire leads. He said they did so for flexibility to go into the trailer plug or hard wire. If you want to go to the trailer plug just pick up a 4 pin trailer plug at Lowes or Amazon and your good to go. I plan to get one off Amazon along with a Y splitter so I can plug the light in along with a trailer.
    If you are truly interested, make sure you only look at the HD version. The regular sized one will not swing open enough to drop the tailgate. There are 2 pics on the HD page of it on a Tundra.
    The Rigd Ultra Swing charges extra for the license plate light, charges sales tax and has a higher shipping rate. DirtCom does not charge sales tax, charges a flat lower shipping rate and includes everything. They even include a spacer for mounting a rotopax tank and even locking lug nuts and key. In the end after adding it all up, the DirtCom Trail Swing is not that much more. Especially considering how superior it is. I highly suggest you watching thei YouTube Video on this.
    AggiePhil and SwampThing[QUOTED] like this.
  7. Dec 17, 2021 at 2:38 PM
    #127
    SwampThing
    Nice. I was planning on a splitter too so that’s good to know.
    I watched the comparison video. The time to cut thing was a little hokey, but other than that, I’m definitely onboard with this over the UltraSwing.
  8. Dec 20, 2021 at 7:02 AM
    #128
    Saltyhero13
    Saltyhero13 [OP] Throbbing Member
    Will do if I pull the trigger on the Ironman. I'll need to compare the weights and other factors before making a decision. Probably a summer project or beyond.
  9. Dec 20, 2021 at 9:09 AM
    #129
    BayRunner
    Sounds good. For reference:
    • Ironman: 105 lbs
    • CBI: 120 lbs
    • ICI: 60 lbs
  10. Mar 12, 2022 at 4:36 PM
    #130
    Infidell
    Infidell New Member
    2018 Tundra 4WD Limited
    Hey folks, just joined . . . after literally following this thread (silently but fervently) since Saltyhero13 posted up the question. I was still a young man, then, I tell ya.
    I have a 2018 4WD Tundra Limited I flew to Boise and picked up there because I couldn't find burnt orange in California. Well, kinda close to burnt orange.
    Anyway I got excited about the CBI bumper when someone earlier posted about it and it was still in R&D. Waited. Waited. Then last May I went to the Overland Expo in Flagstaff with some buddies and met up with the CBI folks, including that gent in the install video, supra, that Saltyhero13 recently posted up - I think his name was Justin. Nice guy. To my eye, 120 lbs is an easy give - I want to keep GVW under control, because I'll be adding on. The cut of the bumper looks to me to improve exit angles in gully territory (mine isn't lifted), and if even it doesn't the bumper won't, like, tear off like the OEM. I also appreciate that I'm basically retaining the manufacturer tow-hitch apparatus, although I read the disclaimer and watched the vid about the cleat that goes on there. I'm ok with it.
    Like most of you following the thread, I like that BSM and I've been waiting for someone to come out with a lightweight, good-looking utility bumper for overland work while retaining the qualities I paid for when I bought this thing.
    Anyway, thanks for all the good intel posted up here via this thread. I've ordered the sucker up and I'll be sure to post up my review when I've replaced the current OEM tear-away bumper which I'm currently (and shamelessly) using zip-ties to retain in place as the CHP squints critically at me rolling by .... Hopefully it will help someone here get to the decision point I've been grappling with for a while.
  11. Mar 12, 2022 at 4:51 PM
    #131
    Saltyhero13
    CBI recently announced they are adding a swing out for their rear bumper. That may seal the deal for me. The also have a different version of their front bumper with a different lighting option making it more Ironman like.
    AggiePhil and Infidell like this.
  12. Mar 12, 2022 at 4:52 PM
    #132
    Saltyhero13
    @Infidell Looking forward to your review and good luck with the install. Hopefully it is trouble free.
    GODZILLA and Infidell like this.
  13. Mar 12, 2022 at 5:12 PM
    #133
    Infidell
    Infidell New Member
    Thanks, SH. Interesting news on that swing-out option - hope you'll keep the group posted. I'm intrigued.
    And thanks for the encouragement. I'll likely contract with a local shop to handle the install. Not that I don't like getting it done myself, I do. I've got a half-day's repair work tomorrow to do on, ah, the results of an ill-conceived-plan-poorly-executed relative to a Decked System crush-hole I caused on the way to Coyote Flats up in the Eastern Sierras (not the fault of Decked - great product). This install I'd love to do, especially with the advent of Youtube videos (everyone can be a mechanical hero!). But I'm full-time busy, and I'm happy to support the local OHV shop on this one.
    That said, I will gladly share what I learn, to the extent it's useful to this group of interested folk and experts.
  14. Mar 12, 2022 at 5:16 PM
    #134
    BayRunner
    Very interesting on the swing out announcement. Did they give a timeframe on the release of this?
    That would have highly interested me prior to my ICI and Dortcom swing out option.
    Infidell and AggiePhil like this.
  15. Mar 12, 2022 at 5:19 PM
    #135
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Wait, what?! Where was this announced? This could be huge.
    Infidell likes this.
  16. Mar 12, 2022 at 5:50 PM
    #136
    Saltyhero13
  17. Mar 12, 2022 at 6:10 PM
    #137
    BayRunner
    Wouldn’t hold your breath waiting. That’s exactly how they announced the BSM compatible rear bumper through a video. Then took years to actually release it. Who knows with the swing out, maybe they’ll surprise us with a reasonable time release.
  18. Mar 12, 2022 at 6:15 PM
    #138
    Saltyhero13
    You're not wrong. I'm in no rush at this point.
  19. Mar 12, 2022 at 6:16 PM
    #139
    Saltyhero13
  20. Mar 12, 2022 at 6:25 PM
    #140
    BayRunner
    i do like that front bumper. As you said, very Ironman’ish.
  21. Mar 12, 2022 at 6:44 PM
    #141
    Saltyhero13
    I do like it too even though even if I'm not a bull bar/brush bar fan.
    It doesn't have the crumple zone like the Ironman claims. No sacrificial intermediary mount point on this one. Its a direct frame bolt on not sure it could be modified to emulate that feature.
  22. Mar 12, 2022 at 6:45 PM
    #142
    Saltyhero13
  23. Mar 12, 2022 at 6:48 PM
    #143
    BayRunner
    Just finished watching the video on the 2nd Gen hybrid bumper. I REALLY like that bumper and it’s only 104 lbs. My N-Fab bumper has worked out well but if I ever want to add a winch this is a Possible candidate for a future bumper.
  24. Mar 12, 2022 at 9:41 PM
    #144
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  25. Apr 21, 2022 at 9:07 PM
    #145
    RainMan_PNW
    Casey
    Clark County, WA
    I got a very surprising message from our warehouse in Portland today - something arrived that I hadn’t gotten a shipping notice on and didn’t expect for at least another two months (they shipped about 4 weeks after order).
    09CAF4DF-FE62-4F63-A200-8FFC28A8E292.jpg 460F6E04-A00C-46F7-BD20-4AF9DC2A0E54.jpg
    Gotta get it out to a local powder coater and then get it installed. We’ll be a couple weeks before that happens.
    I’m going black for the bumper, but trying to decide if I want to color match the two side panels and the tread plates that bolt on top… :monocle:
    wonder if I should start thinking about adding parking sonar too now!
  26. Apr 22, 2022 at 6:00 AM
    #146
    AggiePhil
    College Station, TX
    Is this the new CBI? What are we looking at here?
    GODZILLA likes this.
  27. Apr 22, 2022 at 6:07 AM
    #147
    18" TRD Off Road Wheels
    I think so. Look at this cut out. I think it's CBI, but my eyes are still blurry cuz it's early.
    RainMan_PNW likes this.
  28. Apr 22, 2022 at 6:30 AM
    #148
    AggiePhil
    College Station, TX
    Yeah me too. But damn him for posting something without saying what it is. lol
    GODZILLA and RainMan_PNW like this.
  29. Apr 22, 2022 at 7:34 AM
    #149
    RainMan_PNW
    Casey
    Clark County, WA
    Sorry - yeah. The new CBI. I caved and pulled the trigger.
  30. Apr 22, 2022 at 8:07 AM
    #150
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Color match! I think that'll make it look OEM+.
