Android Headunit
Discussion in 'Audio & Video' started by bryanpwatson, Sep 1, 2017.
  1. Oct 25, 2018 at 11:12 AM
    #1831
    BayRunner
    2017 Tundra Platinum
    The Phoenix HU turns the factory "USB" plug in the truck to a charging only USB. However, the Phoenix HU can retain and use the factory "AUX" plug directly under the stock USB plug.
    D3Tundra likes this.
  2. Oct 25, 2018 at 12:05 PM
    #1832
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    On the procurer
    On the picture look like you have the Frac harness? Did it work? or you had to remove it?
  3. Oct 25, 2018 at 12:26 PM
    #1833
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    If there is an adapter from the Phoenix Head Unit to the factory USB/Aux it didn’t come with the v2 fastboot w/knobs they sent me.
    If you can post a pic with how you hooked it up to retain the factory usb and aux it would be awesome.
  4. Oct 25, 2018 at 12:47 PM
    #1834
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    Has anybody asked Phoenix?
  5. Oct 25, 2018 at 12:55 PM
    #1835
    BayRunner
    Two parts to this:
    USB Plug: I have not tested this myself, but read on the FB forum that the factory USB is supplied power through the connection of the main Phoenix HU harness. I cannot absolutely stand by this since I have not personally tested it.
    AUX Plug: I have verified this for I am using the stock aux port for a external XM receiver with the Phoenix. Works like a charm. They do supply an adapter plug with the head unit. It is one of the RCA female type plug adapters that needs to plugged into the male RCA type plugs in the main HU harness. Refer to post #1831 above to see my post with a pic discussing this very thing.
  6. Oct 25, 2018 at 1:58 PM
    #1836
    Cthulhu
    I just ordered the unit on the group buy. Yes, I have the FRAC harness, and I am going to see if it retains functionality once I receive and install the unit. Unless someone else has already tested the FRAC harness with a new v2 unit, and I missed the post saying whether or not it works...
  7. Oct 25, 2018 at 2:36 PM
    #1837
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Got 2 of the yellow rca cable label reversing video in, which one do you plug into the CCD IN?
  8. Oct 25, 2018 at 2:56 PM
    #1838
    COTundraRoamer
    COTundraRoamer New Member
    Dustin
    Denver, CO
    18' Platinum CM
    Fox 2.5 DSC front, Fox 2.5 DSC rear. JBA UCA. SCS Ray10 custom powder coated on 285/75r18 Duratracs.
    Does the Android unit pull obd2 info from it's connections it are you guys using a Bluetooth obd2 scanner?
    Also for the front cam- is it functional only at a certain speed? Trying to figure out what all I'll need before this thing gets here.
  9. Oct 25, 2018 at 5:10 PM
    #1839
    BayRunner
    The android unit does not have a wired OBD connection. Theoretically, you can use a Bluetooth connection, but I have not tried this.
  10. Oct 26, 2018 at 5:11 AM
    #1840
    Yotaman18
    Yotaman18 New Member
    Corey
    Houma, LA
    2018 Platinum 4x4 Bitching Blue
    Got mine installed yesterday. No issues Found yet with a/c. Once I swapped to Tundra Hi it all seemed to work fine but i also didnt try the heater yet. Had a few small glitches, sound reverting back to 0 and such but nothing major. The sound quality is 24252% better than the jbl "premium" sound.
  11. Oct 26, 2018 at 5:44 AM
    #1841
    dud13
    The front and rear cam are full time. The picture quality is poorer than stock though.
  12. Oct 26, 2018 at 7:12 AM
    #1842
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    actually, the package includes a USB adapter for that port, but you lose the AUX in. I have my iphone connected in through that port and going though a carplay adapter, and that part of the radio works.
  13. Oct 26, 2018 at 7:35 AM
    #1843
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    2018 Midnight Black Tundra Limited 4x4 CM
    Rigid fog lights Interior Led light upgrade Spray in Bedliner CRUX Avity-01 VIM Bypass module 5% tint all the way around 50% on the windshield Wireless charger arm rest mod Amp Research Steps Bak Revolver X4 Tesla Style Headunit Procomp 4" lift Toyo M/T's 35x12.5xR22 Fuel Maverick D538 wheels 22x10 -24 offset
    Links to the items your using?
  14. Oct 26, 2018 at 9:41 AM
    #1844
    COTundraRoamer
    Dustin
    Denver, CO
    18' Platinum CM
    Dude that is a huge bonus!!!
  15. Oct 26, 2018 at 9:49 AM
    #1845
    TundraLuv
    Kent
    IA
    If the Android unit doesn't have a OBD connection how are people getting some of the visuals on the display such as (rpm, etc?). Is this through an app or just the bluetooth adapter?
  16. Oct 26, 2018 at 9:58 AM
    #1846
    dud13
    Comes through some of the can connectionfro the truck that used t go to the old radio
    COTundraRoamer likes this.
  17. Oct 26, 2018 at 10:21 AM
    #1847
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Just got it install everything seem working good. Front camera working with frac harness. The outside temp is off. I’m in California temp showing 48
    TundraTex and Cthulhu like this.
  18. Oct 26, 2018 at 11:14 AM
    #1848
    Cthulhu
    Fantastic news about the FRAC harness. I didn’t want to throw the money I spent on it out the window, nor @tundratex’s hard work. Plus I would have two holes / dead switches in my panel for where I mounted the two FRAC harness switches. :yes:
  19. Oct 26, 2018 at 11:18 AM
    #1849
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Wtf.. Just pull off the screen protector and notice there’s a small crack on scree.. Shit should of check before install.Waited for almost a month for this.
  20. Oct 26, 2018 at 11:20 AM
    #1850
    Cthulhu
    Meh, I’d’ve been more impressed if you got 24253% improvement.
    Yotaman18[QUOTED] likes this.
  21. Oct 26, 2018 at 11:36 AM
    #1851
    ZPMAN
    Minnesota
    He is correct, it's hard to believe how good the stock speakers sound.
  22. Oct 26, 2018 at 11:56 AM
    #1852
    Cthulhu
    Man that sucks ass! :mad::annoyed::censored::frusty:
    Not the first time we’ve heard of damaged units arriving, but Phoenix seemed to be pretty quick to replace...
  23. Oct 26, 2018 at 1:12 PM
    #1853
    sprtbkr
    Scott
    Denver, CO
    D3Tundra[QUOTED] likes this.
  24. Oct 26, 2018 at 2:15 PM
    #1854
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Yea suck.. called them and voice mail came on said that they are at a show won’t be back till Nov 2. Hope I don’t have to wait another month to get a replacement. :popcorn:
  25. Oct 26, 2018 at 2:27 PM
    #1855
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    What’s the FRAC harness for? Can I buy a waterproof front-view camera and plug it directly into the side view yellow? (as I’ve read that gives instant on when pressing the camera icon)
  26. Oct 26, 2018 at 4:15 PM
    #1856
    BayRunner
    The outside temp is not sipported for the Tundra. Per Phoenix it's for other vehicles and should've been hiddened for the Tundra.
  27. Oct 26, 2018 at 6:30 PM
    #1857
    ZPMAN
    Minnesota
    My first gen defaults to the side cam when the icon on the top is pushed, on the install of my 2nd gen I'm going to wire my front cam to the side cam outlet so it is one touch for the front cam. This should work I hope as long as the head unit defaults to the side cam as it does now. I just got home from 47 days of work and got the 2nd gen yesterday, hopefully I can get in tomorrow. Here a little help for the front cam install.
    https://www.tundras.com/threads/front-cam-install-for-phoenix-android-hu.22363/
    https://www.tundras.com/threads/this-is-for-anyone-installing-a-camera.22927/
    https://www.tundras.com/threads/diy-remount-front-cam-from-toyota-emblem-to-pro-grill.29539/
    JoshuaA[QUOTED] likes this.
  28. Oct 26, 2018 at 6:59 PM
    #1858
    ZPMAN
    Minnesota
    Another thing I would like to check on (if I have time) would be to figure out a way to have the front cam to come on when truck is in 1st gear or try to find a way to turn on when fwd motion is below 5 mph.
  29. Oct 27, 2018 at 5:53 AM
    #1859
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    DON'T FORGET THAT THE GROUP BUY ENDS TODAY!
    ***GROUP BUY ALERT***
    Your code is tundra71gb
    PLEASE READ ENTIRE POST. IF NOT, YOU MIGHT MISS OUT ON THE GROUP BUY.
    Rules of the code:
    "$550.00
    12.1" Android 7.1 Fast Boot Vertical Screen Navi Radio for Toyota Tundra 2014 - 2018 (2 g ram 32 g rom / From China)
    Applies once per order
    One use per customer
    Active from Oct 21st until Oct 27
    DO NOT change from China stock. The code will not work.
    Your only option is "With Buttons."
    No orders will ship until the group buy ends. So, dont ask when it will ship. They will come from china and could take up to 2 months to arrive for the button version. (not saying that it will take that long)
    https://www.phoenixautomotiveinc.co...mmxbWpDC33_KSKu5yXOuBkot1lvoZhLpUsPCIVgwHBofs
  30. Oct 27, 2018 at 7:28 AM
    #1860
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Well that was fast to Canada, no delivery notifications, ordered last Fri and came home to a box last night my wife signed. That eBay SMA to SMB is gonna take forever, I’m just going to splice the Maestro.
