Alternative Stock Air Box Mod (SABM) - cheap
Discussion in 'Performance and Tuning' started by csuviper, Dec 28, 2015.
  1. Feb 8, 2024 at 6:49 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    I’ve got a fair amount of scrap stainless and chem hose at work that I could use for this, or just hit up Ace.
    RobertD[QUOTED] likes this.
  2. Mar 3, 2024 at 11:11 AM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Doing this today...
    RobertD likes this.
  3. Mar 26, 2024 at 9:54 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
  4. May 4, 2024 at 4:23 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    I just ordered the parts from Amazon. What the heck. I have a DirtyDeeds exhaust and I've done the throttle body coolant bypass. Might as well do this too.
    The only thing I'm uncertain about is the proper way to relocate that cluster of ground wires. :monocle:
  5. May 5, 2024 at 11:26 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I just moved the one in the way and stacked it on the other one. I think the right wire moved to left one.
  6. May 5, 2024 at 12:02 PM
    VWTim
    Corvallis, OR
    Same here, stacked onto one bolt. Very simple.
  7. May 6, 2024 at 5:09 AM
    Gene_in_FL
    FLORIDA
    Oh, excellent!! I thought BOTH of them would have to be moved.
    ZPhilip[QUOTED] likes this.
  8. May 8, 2024 at 9:09 AM
    Gene_in_FL
    FLORIDA
    Well, hell. Sometimes I hate having been right. Something is different about my truck. I DO have to move both grounding points, as I suspected I would.
    For now I'm putting the mod on hold until I find out how to create a new grounding point. It's probably not hard, but I want to get it right the first time. I now have a 3" hole in my air box, carefully sealed with Gorilla Tape. LOL
  9. May 8, 2024 at 9:13 AM
    VWTim
    Corvallis, OR
    May be a '07 vs '16 location issue.
    I'd just drill a 1/4 or 6mm SS bolt into the fender liner just past the new 3" hole and grind off the paint, coat with dielectric grease, and bolt the ground bundles to that. There should be enough slack.
    Gene_in_FL[QUOTED] likes this.
  10. Mar 7, 2025 at 1:44 PM
    RobertD
    Robert
    DFW, Texas
  11. Apr 16, 2025 at 11:28 AM
    Cthulhu
    So after a few months of having the SABM, I've decided to remove it. Although it sounds fantastic, since i upgraded to 5.29's which pretty much restored my power, I am returning a lot of the mods I did to increase power to OEM; if there's a chance any of the "power" mods are detrimental to longevity of the truck, I'd rather err on the side of caution, because I want to be buried in this truck. Besides, not sure how much power is really gained on a NA 5.7; only really saw evidence of it benefitting FI engines.
    So, if anyone wants my used SABM kit that I made, I'll be happy to send it to you for $50 delivered to CONUS, PayPal only please. Will include (2) clamps for the short intake tube, the short intake tube (already cut for the distance between the air box bottom and the inner fender well), the air box bottom with the hole drilled out and the intake tube plate already mounted to it (what's cool about me offering this included is that you can keep your OEM air box bottom if you don't like the SABM, and all you have to do is reinstall your original box, and plug the hole in the inner fender well), and I'm even throwing in the hole saw, which I only used once to drill the holes. Only thing you would need to do is clean up the old caulk, reapply new caulk when installing (to eliminate any whistling that has occurred on some installations of the SABM, right @RainMan_PNW :D?), drill the hole in the inner fender well, and provide four fine thread stainless steel sheet metal screws for the intake tube plate that mounts to the inner fender well.
    Here is a link to the listing; please communicate with me on that thread. Thanks in advance for any interest! :thumbsup:
    https://www.tundras.com/threads/fs-...delivered-to-conus-paypal-only-please.157496/
