Alignment specs
Discussion in 'Suspension' started by Joeshaker, Oct 28, 2016.
  1. Nov 15, 2016 at 11:06 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Was trying to avoid that until I get the BOSS lift from Toytec, damn.
    I wanted bigger tires anyway lol. Maybe I'll just run with this until they wear out and I'll put the trigger on the BOSS, UCAs and 35's all at the same time lol
    T-Rex266 likes this.
  2. Nov 15, 2016 at 6:15 PM
    Joeshaker
    Joeshaker [OP] New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Hey Jace, I was supposed to bring my truck in for the alignment and zero point calibration this Friday. But my boss needs me to work. Only been reminding him for three weeks. Oh well, that'll give me time to get the couchbuilder shims installed. Maybe some massaging to the fender liners to. I've got a little rubbing with the new tires, not exactly sure where. I ordered three shims, two for the drivers side and one for the passenger side to get a little more lift and get rid of the lean. Are there any issues that I should know about first? Is it bad to do two shims on one side and one on the other? Would just one on each be better and live with the lean? I've got bilstein 6112's on the top setting and stock ucas.
  3. Nov 15, 2016 at 6:16 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I rescheduled my appt. For Sat Dec 10th. Are you working that day?
  4. Nov 17, 2016 at 7:10 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Either rock I how it is and monitor tire wear outerm edge or buy ucas
    What kind of shims are these? not familiar... for rear or front?
    I'm off
  5. Nov 17, 2016 at 7:19 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I figured, dang it! Do you work any Saturdays? Or is there someone else there that can get it dialed in right? What about the shims, should I wait till I get ucas?
  6. Nov 17, 2016 at 9:48 PM
    Just call them and schedule it with him
  7. Nov 17, 2016 at 9:53 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yeah, I tried that. But my boss scewed it up for me. Can't count on getting time off during the week. I'll call again and ask if they have a say appt when he's going to be there.
  8. Nov 19, 2016 at 7:06 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I work every other Saturday.
  9. Nov 19, 2016 at 8:18 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Cool, I'll call on Monday and try to schedule it for the 17th.
  10. Nov 19, 2016 at 8:54 PM
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    Ok so its getting late, and I've had a bit to drink, but it doesn't look like they touched anything on this visit...
  11. Nov 19, 2016 at 9:05 PM
    Just go with @LOTSOFTOYS
    Whatever he does to your truck is like ...a magic touch. Think of him as the Toyota whisperer.
    NewImprovedRon likes this.
  12. Nov 19, 2016 at 9:09 PM
    cdkenne
    Corey
    KS
    Sometimes you have to yell and use colorful language and throw expensive tools around to get a stuck truck into spec. I'm not so sure about the whispering...
    T-Rex266[QUOTED] likes this.
  13. Nov 19, 2016 at 9:13 PM
    Oh..:you'll be surprised. He is the the Toyota Whisperer. He's one of the only ones I will ever let touch my vehicles. He goes above and beyond than a standard tech.
  14. Nov 20, 2016 at 8:48 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Nope they didn't touch a thing... or, they didn't "save before measurements". older machines made u hit a button that did that. newer ones do it by themselves
  15. Aug 10, 2021 at 11:03 AM
    BeastTundra303
    BeastTundra303 New Member
    2019 Tundra TRD sport
    3/1 lift
    Hey @LOTSOFTOYS.
    I have a 3/1 lift on my 2019 Tundra. I have the following specs that we set my truck to. Can you please tell me what you think? The positive camber is freaking me out a little because I just put new tires on and don't want them wearing excessively.
    Left:
    Caster 1.4
    Camber 0.0
    Toe .13
    Right:
    Caster 1.3
    Camber 0.1
    Toe .13
    Overall:
    Toe .25
    Steer ahead 0.0
  16. Aug 10, 2021 at 2:17 PM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    I'm in the same boat with Firestone lifetime alignment to keep my new tires (275/70R18) wearing properly with stock suspension. How bad is mine?
  17. Aug 10, 2021 at 4:46 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I lifted this off another forum, but it worked for me.
    STOCK TRUCKS:
    Camber: +.1 degree camber on both sides.
    Caster: As much as possible without sacrificing +.1 degree camber or causing a cross caster pull.
    Toe: +.12 degrees per side for a total toe of +.24 degrees. (some guys have had to drop toe to +.04 to +.5 per side/+.08 to +.10 total toe)
    LIFTED TRUCKS:
    Same As Above ... BUT if you have wheels that have more negative offset than factory wheels, increase the camber to +.2 degrees. (or even +.3 degrees if they just can't get there with the amount of adjustment allowed by the eccentrics) Adjustable upper control arms are available for cases where there just isn't enough adjustment left in the eccentrics to get a decent alignment. Although they are expensive, most guys with lifts have a lot of $$$ invested in tires so you need to make a judgement call.
    LOWERED TRUCKS:
    Guys that lower trucks tend to want it to handle the road like a Lambo so I'll give two recommendations. One for improved handling and one for improved tire wear.
    Emphasis On Handling:
    Camber: 0 to -.1 degree (watch for inside tire wear)
    Caster: As much as humanly possible. Caster causes the front tires to lean into the turn. Installing adjustable upper control arms to increase caster can really make it stick in turns. High positive caster can make it follow ruts/imperfections in the road and cause it to creep toward "full lock" after turning half way to the locks.
    Toe: +.12 per side for a total toe of +.24 degrees.
    Emphasis on tire wear:
    Camber: 0 to +.1 degree.
    Caster: As much as possible. It won't affect tire wear and we tend to have a hard time getting good caster unless we use drop spindles.
    Toe: +.12 degrees for a total toe of +.24 degrees.
    Norfolk757 likes this.
  18. Aug 12, 2021 at 5:53 AM
    Norfolk757
    Tom
    Norfolk, VA
    Does anyone know what can be done to get the Righ Front Caster to at least an acceptable range so my tires wear evenly. As I drove on the highway it looks like the steering wheels is tilted to the right a little for the truck to drive straight. They have it marked as MAX, was told it was maxed out on the caster side.
  19. Jun 22, 2022 at 5:48 PM
    #49
    terrythesalmon
    terrythesalmon New Member
    2001 Tundra
    Can you guys chime in on my alignment specs that I recently had done? I’ve got about 2.5 inch lift up front on a 2001 tundra. It feels a little twitchy at speed and I’m thinking the caster needs to come up a bit. Any other input is greatly appreciated.
    also curious why my rear left camber is high….bent axle? I did have new leaf springs installed as well.
    The left rear tire is sticking out about an inch more the right rear tire by the way.
  20. Jun 23, 2022 at 12:54 PM
    #50
    pursuit2550
    pursuit2550 New Member
    I am not familiar with the 01 tundra, but, I will say that if one of you rear tires stick out more than the other then that's a totally different issue. Solid rear axles have no alignment. The leaf pack sits in the bracket and the U-bolts hold it down. Could it be bent causing camber, I believe so, not and alignment tech. Right front caster could be closer to left side. Same with your caster, closer/equal. Why couldn't they get the toe equal?
  21. Jun 13, 2025 at 10:29 AM
    #51
    ToyTundra22
    ToyTundra22 New Member
    2020 Tundra Platinum
    How do these numbers look. 3" Boss lift SPC control arms.
  22. Jun 13, 2025 at 11:00 AM
    #52
    JMB
    Chesapeake, VA
    Perfect.
    Camber 0 +/- .1
    Toe, .12 max
  23. Jun 13, 2025 at 12:15 PM
    #53
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Numbers look great. But most importantly, how does it drive. Self righting and tracking straight make any vehicle more comfortable and safe to drive.
  24. Jun 13, 2025 at 5:01 PM
    #54
    ToyTundra22
    Thank you for looking and for the input. It's driving great. But what i really care about tue most is getting good wear on my new tires.
  25. Jun 13, 2025 at 5:13 PM
    #55
    Danman34
    Danman34 New Member
    Danny
    Shouldn’t have any issues. Camber and Toe are perfectly in line. Rotating every 5k will significantly increase the tire life as well.
  26. Jun 29, 2025 at 6:34 AM
    #56
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    This still the holy grail for alignment advice?
    Need to replace my Eibach 2” front, I am on the fence on JBA UCA, stock have 220k on them. 12 offset currently with 295/70/18.
