Alignment in spec but truck pulls to the right still
Discussion in 'Suspension' started by tundraoverland1, May 9, 2018.
  1. Jan 3, 2020 at 7:06 AM
    #91
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Can you find an off road shop that does aliments in ur area?
    Bakelite[QUOTED] likes this.
  2. Jan 3, 2020 at 7:17 AM
    #92
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    I just dropped it off at our local tundra crew go to spot. Fingers crossed. 4 wheel parts to save the day.
  3. Jan 3, 2020 at 8:58 AM
    #93
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    Good luck man. Sounds like alignment can be a nightmare if you can’t find the right shops to do it. :fingerscrossed:
  4. Jan 3, 2020 at 9:06 AM
    #94
    Bakelite
    Bakelite New Member
    Sam
    Thank you - It has only been a few days but it has already stressed me the hell out. -$300 later as well. :(
  5. Jan 3, 2020 at 10:43 AM
    #95
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Let us know and good luck man
  6. Jan 3, 2020 at 12:29 PM
    #96
    Bakelite
    Bakelite New Member
    Sam
    Just picked up the truck and it is a HUGE improvement. So far on the flattest roads I can tell she runs straight. They did say one of my rear cam bolts is frozen, so if I get that replaced there can be a little more improvement. Will post alignment picture later.
    Thanks for the help and suggestions.
    TOYOTRD8 likes this.
  7. Jan 3, 2020 at 2:53 PM
    #97
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Here is where I am at the moment, after asking the shop to follow the alignment specs commonly posted here on the forum. Same pull to the right. Seems like it shouldn't pull to the right with caster bias, from what I've been reading. Thoughts?
    6112s@1.9. two shims left, one right. OE wheels and tires.
    Bakelite likes this.
  8. Apr 2, 2020 at 5:36 PM
    #98
    $mitty
    $mitty New Member
    2018 2wd crewmax sr5
    Trd intake and exhaust
    Can I get a translation...just put ADS 2.5 coilovers and icon UCA’s...how are my numbers now? Looks like I am still in the red on the right side but not the left?
  9. Apr 14, 2020 at 12:41 PM
    #99
    MudKing16
    MudKing16 New Member
    Jonathan
    2018 Trundra Double Cab 4x4 SR5 XP
    Stock
    Well guys, the Toyota dealer finally got my alignment correct, after I paid for it. They were good to make sure that performing the alignment was no longer covered under the factory warranty, so I had to pay them to do it this time. Great dealer huh? Well, I traded it in and went back to Ford where I should have stayed to begin with. I gave the Tundra a try, and it just wasn't my cup of tea. I'm back to a F150 Lariat loaded and this thing drives 100 times better than my Tundra did. Going from the 5.7 to Fords 5.0 isn't showing me much of a difference power wise. However, my Tundra was always very loose on the rear end when the roads were just barely wet, and the new Ford grips way better. I've got the 3.73 rear end. I think the Tundra ran a 4.30?? Not sure if that makes that much of a difference. Overall, I'm happy with my truck, and I could never say that with my Tundra. Still love my Camry though. :)
    Anyway guys. Thanks for all the help, and for letting me be a part of your community for the short while I was here. Best of luck to you guys. Stay safe and healthy
  10. Apr 14, 2020 at 3:55 PM
    #100
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Congrats on your truck. It’s your money and ever Truck has an issue and recalls. But at the end of the day what makes you happy
  11. Apr 14, 2020 at 4:10 PM
    #101
    MudKing16
    Jonathan
    Stock
    Thanks man, I was expecting to get blasted. lol. I tried and really wanted the Tundra to be my last truck I bought for many years. Just didn't work out. Take care.
  12. Apr 14, 2020 at 5:37 PM
    #102
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Hey I came from the ford family of diesel trucks. This is my 1st gas since high school. Lol. Love the Tundra but pay load was an over site on my part and sometimes wish I went back to a diesel. Best wishes
  13. Apr 15, 2020 at 5:13 AM
    #103
    dystepanov
    dystepanov New Member
    Hey guys was wondering if someone can help me out, I installed a 2/1 level kit from tuff country and scheduled an alignment. Does anyone have alignment degree angle for 2.1 and will they have enough room to adjust? I noticed my wheels have a slight positive camber, have any of you had that fixed after the alignment? Also I have a very slight vibration when accelerating from zero to about 15mph. Should alignment fix that or can it be that I need carrier bearing drop spacers?
    glowblue likes this.
  14. Mar 22, 2021 at 2:39 PM
    #104
    Tundra44$
    Tundra44$ New Member
    Hi All, just joined and very happy to be here.
    Question, and thanks in advance.
    2016 Tundra SR5 here
    Issue: My Tundra has been pulling severely to the right. On my front right tire, it has gone bald due to wear. I just had my alignment checked at the Toyota dealership and drove off only to discovery the truck is still pulling to the right. I had the alignment re-checked and these are the specs given. Additionally, they moved the balding outside right edge tire from front to back. It helped a little. Could it be the tires making the truck pull even if the alignment is "correct/good"? Any thoughts?
  15. Mar 22, 2021 at 2:44 PM
    #105
    Tundra44$
    Forgot to mention, why do the specs not match on each side? When the truck is stock/brand new, do the alignment specs match on each side?
  16. Mar 22, 2021 at 3:48 PM
    #106
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    You have too much toe and should have about .5 more caster on the passenger side to account for road crown
  17. Mar 22, 2021 at 5:04 PM
    #107
    Tundra44$
    Thank you, what should the toe be? Is there a standard? What is too much?
    Also, If I had .5 more caster on passenger side, wouldn't it cause pull to the left on straight surface?
  18. Mar 22, 2021 at 5:19 PM
    #108
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    Toe should be about .12 per side but can be dropped down to .7 per side. This is the most out of spec on your alignment sheet.
    Technically yes the truck would pull on a completely level road with more caster on one side but most roads has some type of crown. You don't necessarily need to exactly .5 more but having more the passenger side will help the pulling.
  19. Mar 22, 2021 at 6:22 PM
    #109
    Tundra44$
    Do you mean it would pull if it had more camber not caster right? I have noticed that all of my tires through the life of the truck (89,000 miles currently) have worn on the outside edges when up front. I do rotate every 5,000 miles. So, if I dropped the toe down from .18 to .12 that would promote more weight to the inside of the tire vs outside? I am all confused.
    Thanks so much for the help!
  20. Apr 18, 2021 at 8:40 AM
    #110
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    Been fighting a pull to the right forever. Thought it was the tires and got a new set. Truck still pulls to the right. What do you think about my numbers:
  21. Apr 19, 2021 at 7:10 AM
    #111
    Tundra44$
    Similar to my specs, I am not sure why the rear numbers on the right and left side are so different?
  22. Apr 21, 2021 at 7:49 AM
    #112
    Tundra44$
    Can someone please comment on my rear specs? I am not sure what the numbers are so different from back left to back right?
    I am goin go to get my Toe in the front down to .12. Any other suggestions?
    Thanks Big
  23. Apr 21, 2021 at 3:15 PM
    #113
    Tundra9880
    Tundra9880 New Member
    2019 Cement CrewMax SR5
    Leveled, wheels and tires, Line X on the grille surround and bulge, Line X in the bed, Retrax rolling Tonneau cover, Flowmaster Outlaw cat back exhaust.
    Same here with an offending tire. Taken off the wheel, reinstalled, balanced, good to go.
  24. Nov 3, 2021 at 6:28 PM
    #114
    gph04
    gph04 New Member
    Pearce
    2018 Tundra 4x4
    2” lift. 275x65xr20 BFG AT.
    My truck keeps pulling left. Lift and tires were installed on truck when I purchased and it didn’t pull left. I had it aligned at Firestone then it started pulling left. I’ve taken it back three more times and they say there’s nothing they can do to correct the caster due to the 2” lift on the front and the tires are bad which is causing the pull to the left.
  25. Nov 3, 2021 at 6:33 PM
    #115
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    They can do better than that. I have a 2.5 lift with factory UCAs and have more caster and 0 camber. Firestone did my alignment too
    gph04[QUOTED] likes this.
  26. Nov 3, 2021 at 6:40 PM
    #116
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    This is mine from a few weeks ago, 3” lift and factory UCA’s. I do have coachbuilder tie rods though. It can be done, find a different shop.
  27. Nov 3, 2021 at 6:49 PM
    #117
    gph04
    gph04 New Member
    Pearce
    2018 Tundra 4x4
    Other than the lift, everything else is stock. I’m going to bring it to another shop that specializes in this tomorrow morning. He said Firestone wasn’t doing it right. Will let y’all know what happens! Pic of front lift.
  28. Nov 3, 2021 at 6:51 PM
    #118
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    That looks like more than a 2" lift. Are you measuring the spacer height?
  29. Nov 3, 2021 at 6:52 PM
    #119
    gph04
    gph04 New Member
    Pearce
    2018 Tundra 4x4
  30. Nov 3, 2021 at 6:53 PM
    #120
    gph04
    gph04 New Member
    Pearce
    2018 Tundra 4x4
    Yes, just measuring the spacer. Is that what to measure? New to this stuff..
