Alignment in spec but truck pulls to the right still
Discussion in 'Suspension' started by tundraoverland1, May 9, 2018.
  1. May 9, 2018 at 1:01 PM
    tundraoverland1
    tundraoverland1 [OP] New Member
    Las Vegas
    2015 White Tundra crewmax TRD 4x4
    IG: sfarrisjr88
    Hello all,
    i recently had some 285/70/17 bfg ko2 and 17x8.5 method vex installed on my tundra. i took it to the alignment shop and they were able to get it perfectly aligned but for some reason the truck still pulls to the right.
    The tech suggested something may be bent or that there is some steering wheel sensor recall for my truck. Can someone possibly shed some light as to why the truck still pulls to the right.
    is it due top the stock upper control arm. i also have bilstein 5100s at the top setting
    eharri3 likes this.
  2. May 9, 2018 at 1:04 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    post up your alignment #'s.
  3. May 9, 2018 at 1:10 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  4. May 9, 2018 at 1:12 PM
    tundraoverland1
    Las Vegas
    IG: sfarrisjr88
  5. May 9, 2018 at 1:23 PM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    I just had a similar issue... Turns out it was my tire. The offending tire pulls to whatever side it's on. Worth rotating the fronts to the rear to check if no one else can provide alignment advice.
  6. May 9, 2018 at 3:12 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    #'s look good. Try swapping left tire to right and right tire to left.
  7. May 9, 2018 at 3:30 PM
    tundraoverland1
    Las Vegas
    IG: sfarrisjr88
    thats what i was going to try this weekend when i have some time. if it changes and pulls left what should i do at that point?
    dcsleeper408 likes this.
  8. May 9, 2018 at 3:34 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Then its the tires.
    These were the tires you got a good deal on? Assuming no refund etc?
    Rica25 and joonbug like this.
  9. May 9, 2018 at 3:40 PM
    scs_vuth
    scs_vuth New Member
    Vuth
    Bay Area
    You can also check to see if one of the front wheel is dragging more than the other. Have both wheel up off the ground. Spin both wheel with your hands. Check and see if one side is spinning more freely than the other. If one side is dragging more, it could be your brake caliper sticking or something else.
  10. May 9, 2018 at 3:44 PM
    tundraoverland1
    Las Vegas
    IG: sfarrisjr88
    yes these are the tires i got a good deal on and nope no refund no warranty
    Rica25 and dcsleeper408[QUOTED] like this.
  11. May 9, 2018 at 3:45 PM
    tundraoverland1
    Las Vegas
    IG: sfarrisjr88
    okay i will check to see if one is dragging more than the other as well.
  12. May 9, 2018 at 4:03 PM
    MistrRoboto
    Virginia Beach, VA
    Rotate them one by one to the back to isolate the trouble maker... Then leave it back there :)
  13. May 9, 2018 at 4:22 PM
    1794TRD
    1794TRD It is, what it is!
    Little Rock, AR
    2015 Super White II TUNDRA 1794
    TRD EXHAUST TRD INTAKE Lift 3” front 1.5” rear TRD SKIDPLATE UNIFLEX TRIFOLD BED COVER UNIFLEX SWINGBOX POP & LOCK POWER TAILGATE LOCK TUNDRA BED LIGHTS LED HEADLIGHTS / FOG LIGHTS / PUDDLE LIGHTS / INTERIOR LIGHTS WHITE DOOR HANDLES WHITE MIRROR COVERS TOYTEC BOSS REAR SHOCKS CRUX AVITY-01 VIDEO INTERFACE AJT KEY FOB COVER
    Had a similar issue for a couple of years...basically from the day it left the dealership. I spent much-o money on alignments and dealership visits. every time they would say its in spec. The dealer installed a 3/1 lift before I bought it, so just figured it may have been the lift...:annoyed: I even bought aftermarket upper control arms as recommended from a reputable alignment shop due to lack of adjustment in cam bolts. it continued same old story until just recently when I purchased new wheels and tires where they offered a free alignment check. of course they said the alignment was off, so I said fix it. Another $89 later and they fixed it. come to find out the dealership that installed the lift had re-installed the alignment cam bolts backwards, which didn't allow for proper adjustment. all is well now... straight and true... :bowdown: damn dealership... Thought about getting them to reimburse me for all those alignment expenses.:argue:
  14. May 9, 2018 at 4:27 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    I'm currently trying to figure out the same issue myself. Tire rotation did not fix. Time to dig deeper.
    T2S did, however, knock something to lessen the pull to the right. Maybe the solution is beat it up on a couple more Sedona trails
    joonbug and tundraoverland1[OP] like this.
  15. May 9, 2018 at 4:48 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  16. May 10, 2018 at 8:00 AM
    tundraoverland1
    Las Vegas
    IG: sfarrisjr88
    @Watt maker @joonbug so i should take it back to the alignment shop and have them add .5* to the passenger side caster angle?
    Should i try rotating the tires at all first or just go straight to the alignment shop?
    what makes the added .5* caster angle fix the pull to the right?
    joonbug likes this.
  17. May 10, 2018 at 8:17 AM
    What about these numbers? Same issue, drifts to right, 35x12.50x20 tires, wheels 20x9 +20 6" lift stock UCA'S
    Rica25 likes this.
  18. May 10, 2018 at 8:31 AM
    tundraoverland1
    Las Vegas
    IG: sfarrisjr88
    Okay i'm gonna head back to the alignment shop this weekend and see if they can make this adjustment for me without charging me for a whole new alignment.
    so the passenger side needs to be .3- on the caster angler correct
    i just want to make sure that i tell them the correct thing
    Rica25 likes this.
  19. May 10, 2018 at 9:17 AM
    TheBeast The Beach
    mine still slightly pull to the right even after new set of tires and alignment, same for my SUV and my car. I think it's the road at this point :)
  20. May 10, 2018 at 9:40 AM
    tundraoverland1
    Las Vegas
    IG: sfarrisjr88
    Alright i will swap tires and sides and check tire pressure from side to side and see if i can pinpoint the issue and if not then i will head to the alignment shop and talk to them about my issues.
    thanks for all of the information and knowledge. i am actually saving for some new upper control arms right now actually to provide more adjustibility
    NewImprovedRon and Watt maker like this.
  21. May 10, 2018 at 10:16 AM
    I'm on market for aftermarket UCAs would this help as well? Prefably SPC adjustable UCAs
  22. May 10, 2018 at 10:25 AM
    TheBeast The Beach
  23. May 17, 2018 at 1:44 PM
    How do these numbers look? Went this morning they swapped front two tires, air pressure was good1526589751428-113070647.jpg
    No more drift to right or tugging to left on steering wheel
    Black Wolf and Watt maker like this.
  24. May 17, 2018 at 1:52 PM
    Thanks for info! Last pic I posted was a young guy, today was a seasoned vet from another shop
  25. May 17, 2018 at 2:05 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Very well said! This should be stickied!!! You should make a thread with this info for everyone. Seems to be a typical issue with these trucks with bigger tires.
    toyofish and (deleted member) like this.
  26. May 17, 2018 at 3:47 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Figured I would throw this out there. After a recent off road trip, I knocked my steering rack off a little, not much, but enough the wheel was off. I zeroed the rack out, and tweaked my alignment a bit. I’ve spent some time messing with Tundra alignments, can let go of my wheel on the highway and nothing but straight, no uneven tire wear. My alignment cams are maxed, otherwise I would go -.1 to -.2 on camber(heavy truck/outside tire wear), and stuck with my caster #s, but the split needed is very close regardless of caster #. Additionally I do not recommend anything higher than a .5 caster split, less is usually fine. Toe is at .10 per side for .20 total, I don’t mess with toe, to difficult to get spot on.
    Left Camber
    Right Camber
    Left Caster
    Right Caster
  27. May 17, 2018 at 3:52 PM
    What UCA'S are you running?
  28. May 17, 2018 at 3:53 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Zone
  29. May 17, 2018 at 3:56 PM
    TheBeast The Beach
    I like that little digital angles reader :)
    Vizsla likes this.
  30. May 17, 2018 at 3:58 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Adam...you still should get the SPCs. I'm getting them shortly. Part of my annual crappy bonus by the end of the month is going to ToyTec....!!!
