Alignment in spec but truck pulls to the right still
Discussion in 'Suspension' started by tundraoverland1, May 9, 2018.
  1. Mar 3, 2019 at 7:30 PM
    #61
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I’ve heard the SPC’s are really good or the JBA arms. I was debating on replacing mine before my alignment but there is still adjustment for the camber so I’m undecided but need numbers from members before I go to get it aligned so it’s done right
  2. Mar 6, 2019 at 12:46 PM
    #62
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I just purchased SPC UCAs from @BOSS4x4s and will install to help get things back into alignment.
    Here are my current specs with my OEM UCAs...
  3. Mar 6, 2019 at 1:25 PM
    #63
    Jebell4747
    Jebell4747 New Member
    2018 Tundra TSS
    That’s with the SPC?
  4. Mar 6, 2019 at 1:39 PM
    #64
    r1-superstar
    DB
    UTAH
    Fixed verbiage. :thumbsup: Those specs are with my current OEM UCAs.
    Watt maker likes this.
  5. Mar 6, 2019 at 2:01 PM
    #65
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    im kinda wondering the same thing
  6. Mar 7, 2019 at 3:16 AM
    #66
    Jebell4747
    2018 Tundra TSS
    They said mine is back to factory specs. I forgot to ask for a copy of the print out but I’m going to swing by another shop and have it checked ( just because it has a slight pull to the right and they have a better rep for alignments )
  7. Mar 7, 2019 at 4:28 AM
    #67
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Factory specs doesn’t mean a damn thing on anything other than a factory truck. Even the , Toyota’s tolerances are so vague, you can be “in spec” and still have a horrible alignment.
  8. Mar 7, 2019 at 4:48 AM
    #68
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Mine are within factory specs but my front tires are at a V angle so it’s NOT right
  9. Mar 7, 2019 at 5:06 AM
    #69
    Jebell4747
    2018 Tundra TSS
    Exactly, that’s why I’m going to another shop. The other shop is highly recommended and their alignments start at $150. They do use alignment
    Computers but they also go old school with levels and tape measures from what I hear. Kinda steep but hearing it’s well worth the trip
  10. Mar 7, 2019 at 5:15 AM
    #70
    Danman34
    Danman34 New Member
    Danny
    Correct. The allowed specs are way to much. Anything more than -0.2 to 0.2 on camber should be the only green spec.
  11. Mar 7, 2019 at 4:31 PM
    #71
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    So went to Firestone today after work to see about getting my alignment done because there is to much positive camber and they couldn’t do it because their machine clamps on to the wheels and it would scratch them but before they knew that they said they could fix the problem with the positive camber but after them looking at it they told me their machine wouldn’t work for my truck but to call a Firestone in a town that was about 20 minutes away so I did and they said they had the right machine to do my alignment but they would have to align it to factory specs even after I told them the problem. Is that crazy or what ???
  12. Mar 7, 2019 at 5:46 PM
    #72
    Danman34
    Danman34 New Member
    Danny
    You need to find a specialty shop. These chain stores are worthless. Techs are only trained to do it to what their machine tells them. If it’s outside of that, they don’t know what to do. I had to wind up bringing mine to a chassis and suspension shop. Those guys knew wtf they were doing.
  13. Mar 7, 2019 at 6:05 PM
    #73
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Chuck here’s mine after the SPC’s were installed
    Watt maker and r1-superstar like this.
  14. Mar 7, 2019 at 6:14 PM
    #74
    Danman34
    Danman34 New Member
    Danny
    Now that’s a proper alignment
  15. Mar 7, 2019 at 6:17 PM
    #75
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thanks.......still waiting for those pictures lol !!!!
  16. Mar 7, 2019 at 7:22 PM
    #76
    DMB4x4
    DMB4x4 New Member
    2014 Tundra SR5 CM 4x4
    Can I see a pic of your wheels/tires thinking about getting the same ones. How far do they stick out of the wheel wells?
  17. Mar 10, 2019 at 4:07 PM
    #77
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Here you go. Better late than never. LOL
  18. Mar 10, 2019 at 5:12 PM
    #78
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thanks lol !!!
    Jebell4747 likes this.
  19. Mar 11, 2019 at 7:09 AM
    #79
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Now go get those SPC’s
  20. Mar 11, 2019 at 7:48 AM
    #80
    r1-superstar
    DB
    UTAH
    They arrive Thursday, then back to the shop for alignment.:thumbsup:
  21. Apr 15, 2019 at 7:35 AM
    #81
    WHITEOUT
    WHITEOUT New Member
    2016 Tundra TRD 4x4
    K&N Cold air intake Roll-up bed cover 2.5-1 ToyTec spacer lift 20x9 Maverick D539's wrapped in 33" AMP terrain pro's Westin HDX matte black drop steps TAC Bully Bar Upgraded front grille (chrome to Black honey comb style)
    FYI I had the same issue with my 2016 trd 4x4 seems like a common issue with these trucks! 2.5” spacer lift in front and 1” block in rear 33” on 20x9’s after achieving perfect alignment specs it still pulled slightly to the right. The fix was a small adjustment to the right front caster adjustment see attached specs, it seems to have eliminated the issue and won’t wear out your tires! I hope this helps
    glowblue and (deleted member) like this.
  22. Sep 21, 2019 at 2:06 PM
    #82
    MudKing16
    MudKing16 New Member
    Jonathan
    2018 Trundra Double Cab 4x4 SR5 XP
    Stock
    Yes I finally found this thread I've been looking for. Below are my numbers from today. No lift, and running 275/55/20 Terra Grappler. When I let go of the wheel it turns to the right a little and the truck pulls pretty hard right. After their adjustment, its worse. Should my caster numbers be swapped?
    Thanks guys.
  23. Sep 21, 2019 at 2:42 PM
    #83
    Danman34
    Danman34 New Member
    Danny
    Based on this, it should be pulling to the left. If you’re steering wheel is turning when you let go it, I would start looking at your rack and the bushings. It’s most likely going out on you.
  24. Sep 21, 2019 at 6:32 PM
    #84
    MudKing16
    Jonathan
    Stock
    Really? On a truck with just under 10k miles? It has been doing this since I bought it. Should the dealer not see the bushings going bad?
  25. Sep 21, 2019 at 6:40 PM
    #85
    Danman34
    Danman34 New Member
    Danny
    They increased the left caster to try and compensate for the right pull.
    It’s been doing this since day 1? Did you not test drive it? Have you tried swapping the tires left to right to see if the pull changes? You could have a bad tire which could certainly cause pull to one side.
  26. Sep 22, 2019 at 4:57 PM
    #86
    MudKing16
    Jonathan
    Stock
    No they didn't mess with the caster. They only adjusted the toe. This is the third time I've taken my truck back to the dealership and this is the first time they have tried to adjust it. But as you see, they didn't do squat but adjust the toe a little.
  27. Jan 2, 2020 at 5:11 PM
    #87
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Hello all! I just recently got my lift completed and new wheels and tires installed, and am having the drift to the right. I did have the wheels and tires re-balanced today and swapped and the pull still occurs, so the radial pull is out of the question hopefully. I did install Camburg ucas, and 6112s in the front with 2 driver side shins and 1 passenger shim. I did go to firestone, I’ve heard mixed reviews and got 80$ off alignment for a lifetime. All help is greatly appreciated. Posting numbers.
  28. Jan 2, 2020 at 6:57 PM
    #88
    Bakelite
    Bakelite New Member
    Sam
    Bump for help. :(
  29. Jan 3, 2020 at 4:16 AM
    #89
    Danman34
    Danman34 New Member
    Danny
    Your camber is off. Should be equal on both sides and closer to 0 and not negative. Your caster is holy caster Batman and most likely pulling to the right since you have have less caster on the right than the left. You also really don’t need any more than 3* of caster. Your total toe should also be no more than 0.15. So your entire alignment is jacked up.
  30. Jan 3, 2020 at 5:17 AM
    #90
    Bakelite
    Bakelite New Member
    Sam
    Oh man - It's the second one I've had in 2 days. So avoid the big name stores like Firestone and others.
