Air bag suspension questions!
Discussion in 'General Tundra Discussion' started by CCLJ03, Apr 20, 2020.
  1. Apr 24, 2020 at 1:12 PM
    #61
    Sweepcity
    Sweepcity New Member
    Jeff
    2016 tundra limited
    If you air up a WDH that was previously set up without bags, the torsion bars are not applying as much rotational force, and the weight goes somewhere....right back into your rear axles.
    If you air up then set up your WDH you are much better off, but you're still applying rotational force to a compressible, rubber bag of air. While that is better than the previous setup mentioned it won't perform like it was ever intended to, especially under hard braking conditions.
    I personally think that a properly set up WDH should be all you need. In the OPs case he's not not using one, so bag away. His setup is the ideal scenario for the use of bags.
    I deleted my post because, It started to become argumentative, and with all the bullshit going on I’m not trying to make this like every other social media site with bickering back-and-forth who’s right who’s wrong. You’re not talking to yourself I just felt like you are speaking of a weight distribution hitch And I was speaking of a static load on a static hitch. both of which are completely different.
    StihlBuckin likes this.
  2. Apr 24, 2020 at 1:16 PM
    #62
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I'd think any would be "compatible" as long as you set it up at inflated height. I wouldn't think brand would matter. I'll never be a fan of both. I used to do it on my old Tundra, then stopped.
    Someone needs to actually get some scales and do a test similar to the one I saw on bags vs WDH, but this time use both at the same time.
    Tundyfundy[QUOTED] likes this.
  3. Apr 24, 2020 at 1:17 PM
    #63
    19TurdPro
    2019 Tundra TRD Pro
    Ah, no worries man. I don't intend to argue, I didn't think you were either.
    Sweepcity[QUOTED] and Tundyfundy like this.
  4. Apr 24, 2020 at 1:22 PM
    #64
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I only mention it because in the CURT HITCH video I posted they address this at around 1:06 saying check manual for compatability instructions. So I figured they design some to work better with airbags or have a certain set up procedure. I would expect him to say "Do not run airbags and a WDH" if it was as dangerous as losing your front wheel traction. Im not saying your wrong, its def something to think about but this isnt new technology and I think as long as he sets it up correctly as described in the video he will be in safe operating limits. Im really glad it was brought up because I learned something. Thank You!
    TechWrench likes this.
  5. Apr 25, 2020 at 7:20 AM
    #65
    CCLJ03
    CCLJ03 [OP] Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    I totally get what you’re saying. And I think you’re right - my setup really just requires a couple psi in some bags and I’ll be good to go.
    Not nearly enough hitch weight to actually affect my front end. I just want to make sure I’m nose down a smidge for TSS and my headlights.
    Tundyfundy and TechWrench like this.
  6. Apr 25, 2020 at 10:50 AM
    #66
    19TurdPro
    2019 Tundra TRD Pro
    Your situation is the perfect example for airbags.
  7. Apr 25, 2020 at 11:01 AM
    #67
    Tundyfundy
    Bay Area, CA
    Are you aware yo have a headlight adjustment dial inside the truck?
  8. Apr 25, 2020 at 7:57 PM
    #68
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    Wow, what year did they start that option. And how does it work?
  9. Apr 25, 2020 at 8:15 PM
    #69
    CCLJ03
    Craig
    Yes I’m aware! I just don’t like to be nose up and not having to adjust headlights is just a bonus.
  10. Apr 25, 2020 at 8:16 PM
    #70
    CCLJ03
    Craig
    Im not sure what year it started but all newer tundras have a little roller knob lower left dash between the steering wheel and the door to aim beams up or down. I think the roller has like 6 settings.
  11. Apr 26, 2020 at 8:33 PM
    #71
    TechWrench
    Gary
    Hawley, PA
    Never heard of it before. Kinda surprised that the FED would allow the headlights be be adjusted higher than the factory setting, and possibly blind oncoming traffic. I used to have BMW's that would automatically adjust the headlights to compensate for the vehicle ride height, but they used sensors on the front and rear suspensions that would determine vehicle trim and adjust the headlights to compensate. But the driver had no control over them.
    Tundyfundy likes this.
  12. Apr 26, 2020 at 8:35 PM
    #72
    19TurdPro
    2019 Tundra TRD Pro
    When you have weight in your bed or hitch the headlights go up. The knob aims them down, not up even more.
  13. Apr 27, 2020 at 9:55 AM
    #73
    TechWrench
    Gary
    Hawley, PA
    I understand that with a rear load, the front end will incline up, which raises the illumination pattern of the headlights. If the adjustment knob only allows the headlight aim to be lowered below the standard, level ride adjustment, then it makes sense. I just wasn't sure how the system was dsigned.
    Just playing Devils's advocate for a min, what would stop someone from setting the initial, level ride headlight adjustment too high. And then use the knob to lower them to a normal pattern. Would it be possible for them to then use the knob to raise the headlights above normal?
  14. Apr 27, 2020 at 10:05 AM
    #74
    CCLJ03
    Craig
    Sure it’s possible, but couldn’t anyone do that manually? I don’t think the adjustments being accessible on the dash makes Toyota any more liable for poorly leveled headlights.
    Anyone could just adjust the headlight too high directly on the light itself on any car to accomplish the same thing.
  15. Jun 20, 2020 at 11:47 AM
    #75
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    What are the t connectors for? I'm about to purchase the ride rights with daystar cradles. I have stock suspension. Anything else you guys recommend?
  16. Jun 20, 2020 at 11:55 AM
    #76
    19TurdPro
    2019 Tundra TRD Pro
    They make it so it equalizes the pressure between the bags.
    Pro: you only have one air nozzle to inflate.
    Con: you won't be able to compensate for uneven loads in the bed. You will also have two nozzles to inflate.
  17. Jun 20, 2020 at 12:05 PM
    #77
    Gotcha. Thanks man.
  18. Jun 20, 2020 at 1:42 PM
    #78
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
  19. Jun 25, 2020 at 9:19 AM
    #79
    Murphs
    Murphs New Member
    PM
    Tundra SR5
    air bags. I Don't have a garage where I live. Can anyone recommend an easy install set of rear airbags?
  20. Jun 25, 2020 at 9:47 AM
    #80
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    The Firestone Ride Rites are a pretty easy install.
  21. Jun 25, 2020 at 9:51 AM
    #81
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Firestone Ride Rites, 60 minutes by yourself, no garage needed and the only part that needs to be removed is the rubber bump stops. Leave the vehicle on its wheels, no need to jack up.
    Murphs[QUOTED] likes this.
  22. Jun 25, 2020 at 11:23 AM
    #82
    timsp8
    NY
    Airlift is the same regarding time and only have to remove the rubber bump stop.
  23. Jun 25, 2020 at 2:04 PM
    #83
    Murphs
    Murphs New Member
    PM
    Tundra SR5
