Air bag suspension questions!
Discussion in 'General Tundra Discussion' started by CCLJ03, Apr 20, 2020.
  1. Apr 20, 2020 at 9:25 AM
    CCLJ03
    CCLJ03 [OP] Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Looking at adding air bags to my rear suspension so I can load the 4 wheeler in the bed and tow the camper without major sag - which brand does everyone here recommend?
    Also, about how much should I expect to pay with a compressor and without? Is this a project that can be installed at home relatively easily?
    Is this combo a good option? Probably $850-$900 after tax.
    Loadlifter 5000 Ultimate plus - https://www.truckspring.com/products/air-lift/loadlifter-5000-89399.aspx
    Air lift 72000 - https://www.truckspring.com/products/air-lift/loadlifter-5000-89399.aspx
  2. Apr 20, 2020 at 10:42 AM
    art64
    art64 New Member
    I have used Firestone Ride Rite. Those come with double convoluted bags. More forgiving ride quality than single convoluted bags.
  3. Apr 20, 2020 at 10:43 AM
    CCLJ03
    Craig
    What does that setup cost? Do you have an on-board compressor?
  4. Apr 20, 2020 at 10:44 AM
    timsp8
    NY
    I got airlift with the internal bumper and the compressor. Forgot how much it was but the onboard compressor was worth it. It’s easy to do at home. Hardest part was cutting the stock bump stops and that wasn’t very hard.
    Tundyfundy likes this.
  5. Apr 20, 2020 at 10:49 AM
    CCLJ03
    Craig
    Does about $900 sound right?
  6. Apr 20, 2020 at 11:04 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Another Firestone Ride Rite fan. I went without an on board compressor. I use my bags 2-3 times/month and find it easy to use a portable hand held compressor. I paid $320 from SD Spring with free shipping. Pretty easy install.
  7. Apr 20, 2020 at 11:05 AM
    CCLJ03
    Craig
    Nice!! Do you find it hard to regulate/equalize the pressure in the bags?
  8. Apr 20, 2020 at 11:05 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Easy peasy. I opted for running the lines separately but I know some use a Y-splitter line to help equalize the pressure. I put the valves on the outside edge of my license plate.
    CCLJ03[QUOTED][OP] likes this.
  9. Apr 20, 2020 at 11:20 AM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    Tundyfundy and CCLJ03[OP] like this.
  10. Apr 20, 2020 at 11:26 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    How much does the 4 wheeler weigh, and what is your tongue weight? Airbags aren't really meant to be used with a weight distribution hitch. When you air up using a weight distribution hitch you're putting more weight on the rear axles that was transferred back into the trailer and the front wheels. You could potentially damage your truck.
  11. Apr 20, 2020 at 11:37 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Ride rites, 350 bucks installed yourself in 60 minutes. Use a 20 dollar 12 volt compressor..
  12. Apr 20, 2020 at 11:55 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    This is what I have, the compressor is dope but I would've gone with the Firestones. The internal bumper in the air bags suck ass, even with a 3" lift there's hardly any up travel before you hit it. The downside with the compressor is it won't let the bags go under 5psi, so I pull the fuse and then disconnect the quick connections on the bag when I'm not using them, makes the ride 50x more bearable with no weight since the bags can fully deflate then.
  13. Apr 20, 2020 at 12:03 PM
    timsp8
    NY
    Can’t find the one I got now but it seems like maybe about $350 each for bag kit and compressor. The on board compressor is nice because it has a remote that I can use in the cab. I don’t change the air that much though and a cheaper 12v compressor would have worked fine.
  14. Apr 20, 2020 at 12:05 PM
    timsp8
    NY
    I haven’t noticed it riding rough, but have been driving 4wds for awhile and am used to it. I do have the cb +2 shackles so about 1.5” lift and the daystar cradles.
  15. Apr 20, 2020 at 12:09 PM
    snivilous
    SW UT
    I have 3.5" lift shackles, and disconnected the bags from the stock cradles since they were limiting droop I found. Seemed like a combination of any bag pressure, lack of up travel due to the internal bumper, and decreased droop made the ride horrible. Though maybe I'm being picky, suspension that isn't comfy hitting bumps at speed doesn't do it for me lol
  16. Apr 20, 2020 at 4:43 PM
    CCLJ03
    Craig
    hell yeah sweet and simple answer. Thank you.
    jeremyd[QUOTED] likes this.
  17. Apr 20, 2020 at 4:45 PM
    CCLJ03
    Craig
    4 wheeler is about 500 pounds and the tongue weight of my camper is about 289 pounds.
    I’m not using a weight distribution hitch.
  18. Apr 20, 2020 at 4:48 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I've never heard of this. Do you have an article or something that explains this theory? THe purpose of leveling is to shift weight off the rear axle. How do you assert weight is increasing as the load levels?
    I ditto this. I'm not sure if I would buy them again as much as I offroad. I would at least get the double convoluted bagts as someone stated above. Also look into Sumo Springs!
    TechWrench likes this.
  19. Apr 20, 2020 at 4:49 PM
    Tundyfundy
    Bay Area, CA
    I bought the biggest 12v compressor from oreilly auto parts. Takes about 8 seconds to fill each bag. You dont need the big one for the bags but I like that it will fill my truck tires when I air down or get a flat or something. Takes a few minutes but the peace of mind is huge.
    CCLJ03[OP] likes this.
  20. Apr 20, 2020 at 4:51 PM
    CCLJ03
    Craig
    I’m having a hard time understanding what he’s saying, but I think he’s saying air bags increase the load on your rear axel.
    If that is in fact what he’s saying, he is correct.
    In this video they test both with scales under all axels.
    https://youtu.be/XBZu39pQ8Gg
    Tundyfundy[QUOTED] likes this.
  21. Apr 21, 2020 at 7:26 AM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    I used both rear air bags, and a weight distribution system on my 4Runner without issue. That being said, one has to set up the weight distribution hitch properly or you could do damage to the vehicle. The weight distribution system will work with airbags, if you make the adjustments to the hitch system after airing up the air bags to the ride height you intend to tow with. If you setup the weight distribution system before inflating the air bags, the weight transfer geometry will no longer be correct. Anything you do to change the ride height of the vehicle will require checking the adjustment of a weight distribution system.
    rockmup and Tundyfundy like this.
  22. Apr 21, 2020 at 7:28 AM
    Tundyfundy
    Bay Area, CA
    Agreed. They don’t run both in the video so no data on running both. This sounds reasonable. I know a hundred guys running airbags and they all love them...
  23. Apr 21, 2020 at 7:33 AM
    TechWrench
    Gary
    Hawley, PA
    When I had the 4Runner, I towed a 27' camper, two different utility trailers, and a boat trailer. Each required a different pressure setting for the air bags to attain the ride height I desired. The ability to adjust the air bags to accommodate different loads was the reason I went with them instead of heavier rear springs.
  24. Apr 21, 2020 at 7:36 AM
    Tundyfundy
    Bay Area, CA
    Yes I’d haul the same load you may not need them but they have great variability!
  25. Apr 21, 2020 at 7:37 AM
    TechWrench
    Gary
    Hawley, PA
    Now that I have the Tundra, and I no longer tow the camper (it is set up permanently at my hunting site), the two utility trailers and boat trailer do not strain the suspension enough to warrant air bags.
  26. Apr 21, 2020 at 10:09 AM
    19TurdPro
    2019 Tundra TRD Pro
    That's what I'm saying. WDH work on rotational force. The more squat you have, the harder the hitch is working. Adding in a cushion of air takes some of that away.
    Many people use them both and it's fine. My initial concern here was weight. I didn't realize he had such a light tongue weight. I was thinking he was 600 - 700lbs of cargo and 600 - 700lbs of tongue weight.
  27. Apr 21, 2020 at 1:59 PM
    CCLJ03
    Craig
    Nope the good news is it’s just a 2500# camper. Odd that it makes me sag at all really, but it does bring the nose up enough to annoy me. Haha
    Bigboitundra and jeremyd like this.
  28. Apr 21, 2020 at 7:03 PM
    TechWrench
    Gary
    Hawley, PA
    OK, now that I can see your truck and trailer, I got one question. How do you fit an ATV in the back of that bed and still tow the trailer???? My Polaris Sportsman is almost 7' long, and it looks like your bed is the shorty, only 5.5' long.
  29. Apr 21, 2020 at 7:13 PM
    CCLJ03
    Craig
    I take the tailgate off and strap the atv into the bed! I have a Honda rancher and it’s relatively compact.
    Bigboitundra likes this.
  30. Apr 21, 2020 at 7:19 PM
    TechWrench
    Gary
    Hawley, PA
    OK, then back to the original issue. If you feel the rear sags too much with both the ATV in the bed and the camper connected, then a set of air bags are probably your best answer. You can air up when towing, to maintain proper ride height, and air down when not needed. The amount of load will still affect the front end because of the weight after the rear axle will cause it to lift the front a bit. But, with the air bag system lifting the rear end, at least you will ride level.
