Aiming Morimoto XB led headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by Ladderman30, Feb 26, 2020.
  1. May 7, 2021 at 2:29 PM
    redrum448
    redrum448 New Member
    I'm
    Sure that's how they come from the factory then. I'd like to see what they look like a bit wider though....
  2. May 8, 2021 at 8:29 PM
    2turbz
    2turbz New Member
    2011 Tundra Trd 4x4
    Full disclaimer I know nothing about these units specifically but is it possible that is intentional to not blind oncoming cars and give you the most light possible on the lane you are in?
  3. May 10, 2021 at 3:52 AM
    redrum448
    Well the "step down" is 100% intended to not blind on coming cars but my point is the step down from both lights should not be that close together it should have a wider spread
  4. May 10, 2021 at 4:40 AM
  5. May 10, 2021 at 5:45 AM
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
    I was showing you through PMs, but these headlights are adjustable! You can widen the beam pattern yourself with a screwdriver with the adjustment on the rear of the housing. :) Widen them however far apart you would like!
  6. May 10, 2021 at 5:55 AM
    redrum448
    yes thanks youve been a huge help!, I was just relaying that to everyone here
  7. Jan 14, 2022 at 12:41 PM
    ThisGuy03
    ThisGuy03 New Member
    Las Vegas, NV
    ‘17 CM LTD TRD 4x4 MGM
    King 2.5s..TC UCA..35x12.50-18 M/T..AMP Steps
    I am going to attempt aiming this weekend. I didn’t realize the step down thing was necessary! Any pre recommendations for horizontal swath width? As a reference starting point? I usually set my auto leveling adjuster to 2.5, right in the middle. Thanks!
    2017 CMAX with 3.5” lift.
  8. Jan 16, 2022 at 11:52 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    When I purchased and installed mine about 2 years ago the cab dial to raise and lower the beam based on your load worked the opposite of what it is supposed to. There is another thread on here discussing this issue. Morimoto was going to address and fix this issue and notify customers when replacements were available. I never heard a word from them or HR. I am assuming the problem still exists. You just have to be aware of it if you use this adjustment. More passengers/load use a lower number.
  9. Jan 16, 2022 at 12:19 PM
    ThisGuy03
    Las Vegas, NV
    this isn’t a prob. I have the v2 that recently came out. I was asking about the step down and swath adjustment.
  10. Feb 21, 2022 at 3:58 PM
    Vockroth
    Vockroth New Member
    Steven
    Santa Clarita, California, USA
    2008 Tundra Double Cab Limited 2WD Arrest Me Red
    Late Model 18" Factory Wheels | Michelin LTX M&S P275/65R18 116T Tires | TRD Sway Bar |Factory Running Boards | Ready Lift 66-5075 2.4" Front Leveling Kit | Bilstein B6 4600 Shocks and Struts | Curt Mfg 31198 Front Hitch | LLumar Formula One Stratos 30% Ceramic Tint Front Side Windows | K&N 33-2387 Filter Element | Morimoto Head Lights and Fogs | Snug Top Hi-Liner | Bed Rug | Anker ROAV T2 R5114 FM Transmitter | Intro-Tech #56060046 Custom Auto Shade | Ozium Air Freshener 4.5oz, (fits in ashtray hole)
    This is my 2008 Tundra's Morimoto headlight projection after adjustment. The height of that line in the wall is the height of the center of my headlights. Look for the blue tape markings. My headlights suck. They are pointing too far down. The Right Hand beam is way larger than the left. I'm sad in the pants! I have complained to Headlight Revolution they pretty much said this is normal.
  11. Feb 21, 2022 at 4:11 PM
    Vockroth
    Vockroth New Member
    Steven
    I couldn't get the Toyota Dealer to adjust mine. They said they weren't Toyota so they won't touch them.
  12. Feb 21, 2022 at 4:21 PM
    Vockroth
    Vockroth New Member
    Steven
    I unbolted the window washer bottle and moved it out of the way. Then I used a ratcheting combination wrench. I drove to the adjusting site with a loose washer bottle. It didn't move or fall over.
  13. Dec 11, 2022 at 9:37 AM
    ditdah
    ditdah New Member
    Kenneth
    2008 Tundra DC Limited
    6” Procomp stage 2 lift. Fabfours front and rear bumpers. Warn 9.5 XP. Trailready BL20 wheels. Coachbuilder shackle, steering and carrier bearing kits. OME CS055R rear springs. Hellwig 7889 rear sway bar. TRD Sport Front Sway Bar. TRD CAI. TRD dua Exhaust.
    08 Tundra. Just got the amber XB’s. I was surprised to find the leveler motor plug filled in with an epoxy or plastic when I got them. I was under the impression these lights came with leveling motors. I took the effort to get the leveling switch and harness. I emailed Morimoto and they advise that the lights do not come with a leveling motor. Completely took me by surprise.
  14. Dec 11, 2022 at 1:49 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Weird.
    They still advertise them as being headlight leveler "compatible", but they for sure used to come supied with the motors. One of the reasons I went with the Morimotos, to retain that function.
    Maybe they are having trouble sourcing chips.?
  15. Dec 11, 2022 at 8:01 PM
    ditdah
    ditdah New Member
    Kenneth
    According to Morimoto, they haven’t included them in their headlights for 2 years now (for 2nd gen Tundra).
    I too wanted to use that function.
    I “think” maybe there is that difference between the 2nd gen tundra lights and 2.5 gen trucks (leveling motor included or not)…so reading reviews here it was just assumed by me and I never made that differentiation. Also, as you said…they used to include it…but quietly stopped. Never caught that they stopped including that feature.
    Another “misunderstanding on my part…the light pattern is different for gen 2 vs gen 2.5 trucks. Gen 2 trucks get the LED’s while gen 2.5 get the LED projectors. The projectors have that crisp horizontal line as you see in most or all of the alignment vids…while the lights for the gen 2 are not nearly as defined/crisp. Still like them…still huge improvement on stock halogens. Just a little disappointed I never caught onto these differences/changes.
  16. Dec 12, 2022 at 7:46 AM
    COTundie
    Trey
    Pretty things
    That's really disappointing to hear. If they have in fact removed the functionality, are they not obliged to update their advertising? In your shoes I would probably be heated enough to request a partial refund for selling me a product that was not as advertised.
    Just for reference, I've only had mine (2nd Gen/2012) for like a year and a half, and they have the motors built in and ready to go. All plug-n-play... As advertised.
    I will admit that my headlights are kinda different it seems. While all of the other Morimotos I've seen have an orange reflector, mine have a clear (or white) reflector which lights up orange. Maybe I have some early version they found buried in the back.
    Also strange, I swear I've seen multiple forum members with the amber DRL versions which still had the integrated leveling motors. These hadn't quite been released when I purchased my white DRL Mori's. If the Amber's aren't even 2 years old, how were they still coming with the levelers.
    Maybe someone with the amber DRLs can confirm what my memory seems to think is truth.
    To my recollection, the 2nd Gen offering have always had the free-form reflector system and were never available with projectors.
  17. Dec 12, 2022 at 11:46 AM
    ditdah
    ditdah New Member
    Kenneth
    Yeah…was emailing headlight revolution in October. I was asking about if the leaking housings and reversed leveling motors were fixed. They advised that both problems are resolved for the v2 lights.
    Seems I’m not getting the full story from someone.
  18. Dec 12, 2022 at 12:28 PM
    Jorgesworld86
    Jorgesworld86 New Member
    Orange County,CA
    2013 Tundra Limited Rock Warrior
    Just installed mine last week. They are working perfectly and the leveling dial works with them.
  19. Nov 28, 2023 at 2:36 AM
    #49
    jham101
    jham101 New Member
    When leveling the head lights are y’all doing it with the high beams off? So level the beams to headlight height and width of the vehicle at 25ish feet with no high beam
  20. Nov 28, 2023 at 6:37 AM
    #50
    COTundie
    Trey
    Pretty things
    Yes.
    Main beams (or dip beams for brits) only. No highs
    tnbndr likes this.
  21. Dec 1, 2023 at 3:34 AM
    #51
    jham101
    jham101 New Member
    So I installed new headlights and fogs. Huge upgrade. Worth the money I would say. One interesting hiccup in the install process. The fog lights wouldn’t power on. I called morimoto and they said it was a polarity issue that occurs occasionally. I shaved off the the clip on the plugs backside and reversed the clip which solved the issue.
  22. Dec 1, 2023 at 6:03 AM
    #52
    AlexFIA
    AlexFIA New Member
    Tundra Rock Warrior
    I have had zero issues with mine and not only changed the look but increased lighting significantly from my foggy old headlights. My leveling motor also works without issue.
  23. Dec 6, 2023 at 12:13 PM
    #53
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    Got mine installed last wknd. Only issue was the leveling motor dial reversed now. 6 is now level and 0 is the max lowered. Doesn't bother me enough to deal with as the motors work fine, just the reverse for numbers/ setting on dial.
  24. Dec 6, 2023 at 2:04 PM
    #54
    Yep....it has been that way since they came out starting with the 2nd gen trucks.
    Medicineman[QUOTED] and COTundie like this.
  25. Dec 10, 2023 at 5:35 PM
    #55
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Me too. The leveling feature works fine on mine. I bought them during the Black Friday sale so I'm guessing they are the latest version.
  26. Feb 2, 2024 at 11:10 PM
    #56
    Petrolero
    Petrolero New Member
    Brandon
    2010 Sequoia Platinum
    I just finished this install on a 2010 Sequoia. The vertical beam adjustment is easy to access from above with a long Phillips screwdriver as others mentioned. But my beams converge way too much. Has anyone adjusted their beams horizontally and can explain how to do it?
    General comments: I love this upgrade! These are far brighter and whiter than halogens and the DRLs and sequential signals significantly modernize the appearance. I specifically like that these do not require deleting the headlight washers (like the Vlands and Form(?) ones do). In Colorado, they're very helpful at times. Looking forward to installing the XB fogs.
  27. Feb 3, 2024 at 10:26 AM
    #57
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    The horizontal adjustment is in the upper corner of the fixture, and it's not as straight of a shot to access as the vertical adjustment. I used a small 8mm box-end wrench to adjust mine. Not difficult at all.
    Petrolero[QUOTED] likes this.
  28. Feb 4, 2024 at 6:36 AM
    #58
    COTundie
    Trey
    Pretty things
    One can use a somewhat large Philips screwdriver vertically (through the top), so you dont need to try an get a wrench on the "head". You'll notice the "teeth" looking down from above. The Phillips interacts with these teeth.
    Probably wouldn't work well with the interchangeable tip style screwdrivers, but the old-timey ones work great
    Thumper_6119[QUOTED] likes this.
  29. Feb 4, 2024 at 6:55 AM
    #59
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    FWIW I had to spin the screw way more than expected to get the lights to adjust
  30. Aug 9, 2024 at 9:59 AM
    #60
    ditdah
    ditdah New Member
    Kenneth
    Just some FYI…my lights were aligned and I’ve had them nearly 2 years now. Last week I went up a long forest road to do a hike. The road was “rough”…but typical of a forest service road…maintained with minimal pot holes and minimal rocks.
    last night while driving at night, I noticed the “hot spots” in my lights were off…in particular, the driver side was VERY low. I’m estimating it is several feet low. Instead of the hot spot being 3-4ft high at 50’ distance…the hot spot is now on the road about 15’ ahead.
    anyone else notice the alignment being thrown off after traveling on a rough road?
    I will adjust them tonight. Will update with any observations.
    Edit: Only the driver side was low. It took a LOT of adjusting to bring it up to the correct level. Using a ratchet wrench…it was somewhere over 40 “ratchets”…which probably came to maybe a quarter turn per “ratchet”. It was a lot.
    raising the hot spot…like I mentioned…at 25’ it was on the pavement between the wall and the truck. Crazy.
    The adjustment bolt didn’t seem unusually loose or anything. Never heard of lights going out of adjustment by driving over rough roads…
    I’ll keep an eye on it and report back if it does similar again.
